Page 4 of 31 FirstFirst ... 2345614 ... LastLast
Results 76 to 100 of 775
Thread: Welding table picture thread
  1. #76
    Jan 2011
    Coarsegold, CA
    Re: Welding table picture thread
    oh, I didnt realize you were putting it on casters... I would definitely make the frame a lot stronger then. Your casters are going to put a moment arm on those uprights and make them prone to flex. I do agree that 6 casters is too much to try to push around.
    I don't post much, but I read this forum every day...
    4x8 Bulltear Gantry Kit CNC Plasma
    Hypertherm 85
    Millermatic 251
    Dynasty 350
    Turnpro 7x12 Miter Bandsaw
    ...one packed garage ><
    https://www.facebook.com/ApocalypseFabrication
  2. #77
    Nov 2012
    Wasilla, Alaska
    Not done yet but it is useable. Now it's time to finish the shelf and work up a table for the saw.
    Miller Dynasty 200DX
    Miller 252
    Miller 250x
    Miller Syncrowave 250
    Miller AEAD200 Legend
    Miller 375 Xtreme plasma
    Lincoln WeldPak 100
    Victor O/A
  3. #78
    Aug 2013
    Elkton, Va
    Nice tables everyone
    Miller Legend AEAD 200LE
  4. #79
    May 2013
    Central Florida
    Just when I thought my table was perfect for me and would never need to be re-built, this thread shows up.
    You all have done a very nice job and there are some really cool ideas here.
    BTW- Still have not had the time to finish the leveling feet
    TOO MANY TOOLS & NO MORE SPACE
  5. #80
    Jul 2013
    Delmarva
    Quote Originally Posted by Burpee View Post
    6G? Not bad at all. It's all about the gadgets and clamping devices. "Any dork can build the table".
    LOL This dork sure wouldn't want to drill and chamfer all them holes.
  6. #81
    Utah
    Nice table. Clean and useful, but man, that vice looks heavy.
    What size holes did you drill, 5/8"?
    How did you line them up?
  7. #82
    May 2013
    Central Florida
    Quote Originally Posted by Robert Hall View Post
    The vise is not that bad, it is a cheap (but nice) Wilton I picked up from a tool store in Tennessee for about $40 because the box was wet.
    The holes are 9/16" because that was the smallest annular cutter we had for the mag drill at work. I got half way done and the cutter decided to explode after hitting a hard spot in the material. Had to switch over to the 100lb Milwaukee with a twist drill to finish the rest.
    I kind of layed out a grid pattern between the under table supports and the holes are 3" apart. After using the table for a couple of projects I should have put a hole in the "dead space" between the other holes because there is always that time where one is too close and the other is too far away.
  8. #83
    Feb 2009
    Coastal NC
    Quote Originally Posted by AKmud View Post
    I think 5/8" is the standard but I'm not sure.
    Late response but, I appreciate the info.
    Here's the beginning of mine, just got it back last night. Not the greatest pictures but, you get the idea. 2'x3'x1/2" with 5/8 holes. I'll be doing the same layout for my 2'x3'x1" plates as well, at least one of them.
    A lot of nice looking table. Hopefully mine will look half as good as the ones in here.
  9. #84
    Mar 2012
    [QUOTE=Jimmy_pop;4080071]I'd really consider how you are planning on using the buildpro tables. If you are looking at them as an option for precise manufacturing, I'd keep looking. I have experience with their tooling and have looked at their table for the last 3 years while it is on display and for sale at the IMS in Phoenix. I would classify their tables as hobbiest level. Their HD clamps for the Acorn tables are bomb proof. loved them.
    i was told the same thing. table looks really good but its not worth the money. take the time, build your own and save some money.
  10. #85
    Nov 2013
    Iowa, USA
    Top is 3/4" 4' x 8' it has a 4" channel iron frame with one support in the center the long way.
    I also welded two chains to the table and welding vice grips on them so I don't have to hunt them down.
    If I need to move it I use the forklift
  11. #86
    Southwestern,NY
    Here's my table it's 2ft 6in wide x 5ft 8in long and the top is 3/8in also it stands 39 inches off the floor. It has a small 24 x 24in fold away cutting table on the side. I know 39in off the floor is pretty high but it's comfortable for me to use.
  12. #87
    Utah
    That cutting table is slick!
  13. #88
    Veri nice all the table
  14. #89
    Moved to sunny Northern CA
    On it's way, should be here in <10 days:
    3' x 6' plus a bunch of fixturing devices.
    Oh boy! Oh boy! Oh boy! Oh boy! :-)
  15. #90
    Australia
    I notice on this page that one builder has 9/16th holes and the other is using 5/8? Any reason for the difference? I'm looking at putting holes in my table.
  16. #91
    May 2013
    Central Florida
    Quote Originally Posted by RSD View Post
    I made mine 9/16" because that was the only small bit we had for the mag drill at work, if it ever becomes a problem I'll drill them to 5/8". I mainly use the cheap HF drill press hold down clamps but can also use milling machine hold down tooling.
    LuMax, please post some pics of that table in it's new home
  17. #92
    Mar 2013
    Quote Originally Posted by OUTBACK FORGE View Post
    And another vise I added to it.
    I have that exact vice.
  18. #93
    Nov 2006
    Alaska
    Wow! lots of nice tables. I'll post mine for giggles, lightweight is what I wanted so it's all alum 3'x4' with a pretty basic 3"x3"x1/4" angle frame and a 3/8" top. Lucked out and the top 6061 plate was within a few 10K" of flat so I just screwed it down. Works very well for me and I can load it in the back of the truck myself without getting a hernia . A few internal clamp points would be nice but so far I'm good with a 6" edge all around. Plumbed a few air fittings in and all my primary tools are handy.
  19. #94
    It's here! W00T!
  20. #95
    Sep 2009
    Sedona, Arizona
    cool!
  21. #96
    Southwestern,NY
    nice table!!!
  22. #97
    Costa Rica
    Outback wins, for sure.Ultra-coolness.
    Bottom line ?
    The top frame is channel. PERIOD. Either put 6 little tacks(1/2"long) on the plate or bolt it down.
    If its 1/2" thick---or more... a 4 x 8 is 640 lbs so, unless you're going to take it to the flea market just sit the damn top on the frame( channel right ?) lever it around and forget it.
    It won't fly away.
    Bubble gum
    Tooth pix
    Duct tape
    Black glue
    GBMF hammer
    Screw gun --bad battery (see above)
  23. #98
    Tustin, CA
  24. #99
    Jul 2013
    La Porte, TX
    Quote Originally Posted by kazlx View Post
    Beautiful! Now I just need your address and the hours your house is available for burglary.
    Gravel
    The difference between theory and practice is that in theory there is no difference.
  25. #100
    Got it up on its feet today with the help of a shop crane and heavy chain.
    Spent a good deal of time cleaning the heavy anti-corrosion oil off of it.
    I do believe that my garage is now "full".
    All of the big or heavy things are on casters, so when I start a welding project I simply back the car out and move everything into place. It all tucks away pretty well when I'm done.
Page generated in 1,624,105,592.29038 seconds with 12 queries
