Results 1 to 4 of 4
Thread: Classic 300D help!
    Apr 2013
    Australia
    Classic 300D help!
    My 300D shuts off and puts it's engine protection light on after I have done about 3 passes on an 8" pipe with 1/8 7018. It has just started to do it. Tomorrow I will try and put more oil in it but on the dip stick it reads in the middle. Anyone else had this problem? The PC board is pretty much brand new. Has around 100 hours on it. Perkins engine.
    Any help would be great! Thank you
    May 2008
    Orange, TX
    Re: Classic 300D help!
    Could be a defective oil pressure or coolant temperature sender.
    If you know the oil pressure is good and know that it's not overheating, disconnect each sensor one at a time to see if/which one is triggering the engine protection system to narrow down the cause.
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Apr 2013
    Australia
    Righto ill give that a try today! Thanks
    Apr 2013
    Australia
    I have another question on my welder. Classic 300D. It's not the welder that I need help but the volts it puts out. As I have recently moved to Australia I needed Aus outlets while out on site. I had an electrician instal an outlet on it. The max that say is 230v with a 10% fluctuation safe zone which will make it 240 at a safe volts. I tested it and it's coming out with 268v even when I put a load on it(grinder). I am wondering if I can somehow turn the volts down on it? Thanks for the help
Page generated in 1,659,935,341.36729 seconds with 12 queries
