Results 1 to 17 of 17
Thread: What did I get?
    Apr 2014
    Central PA
    What did I get?
    Recently bought a table of "welding stuff" at auction. Most is stuff I can use, which is why I got it. Some has me stumped. Hopefully, the collective experience here can help me out.
    Apparently torch related is a brass-looking cone shaped part labeled
    National Welding
    13102074
    Something corroded looking labeled
    National
    Mixer
    50-MA
    52-MA
    PAT 1882420
    which seems permanently attached to a tip labeled
    National
    G-1
    PAT 1958085
    I also ended up with Harris Stay-Silv 15 silver bronze alloy and some copper braze labeled 101 Ag Alloy. Are either of these useable with a propane torch (no oxy)?
    Will 1016-D2, 11018M, 6012, or 3081-16 work with AC?
    Is there an easy way to identify mystery rod? It's about 4mm thick (rod, not flux) and old and grey. It probably got damp at some point. There is no readable stamp on the rod anymore.
    Thanks in advance for what help you can provide.
    Jan 2014
    Palmer AK
    Re: What did I get?
    Don't sound like you got much of a bargain.
    You had better not of given much for those welding rods.
    If they are not sealed, but damp and crumbly, they are worthless.
    Can you get some pics up.
    Than we can appraise them.
    ~John
    Just a couple welders, big hammers, grinders, and torches.
    Work will free you.
    Men in dirty jeans built this country, while men in clean suits have destroyed it.
    Trump/Carson 2016-2024
    Apr 2014
    Central PA
    Re: What did I get?
    metal sticks of some sort, not sure what they are
    Copper braze
    mystery rod that might be useable?
    Mystery rod that is likely unusable for anything
    Another mystery part, new in bag
    Apr 2014
    Central PA
    Re: What did I get?
    Not sure what this is, labeled National Welding 13102074
Size:  120.7 KBName:  IMG_0943.jpg
    Mostly all 10016-D2
    Two parts stuck together, presumably part of a torch set up
    Nickel alloy for cast (these seemed to arc fine on steel in my untrained hands)
    Apr 2014
    Central PA
    Re: What did I get?
    Not sure what the orange-coated stuff is, looks like some sort of coating around the same brazing rod
    More 10016
    6010 in terrible condition, useless to me anyway
    Mixed together to make life more interesting
    Apr 2014
    Central PA
    Re: What did I get?
    Tips and chipping hammers
    Sorry it took so long to post the pics. The 6013 and nickel both seemed to arc nicely when I tried them the other day. The lot came with two fixed hoods, too (not that I needed them, but who's complaining). The red packs are mostly 6013.
    Costa Rica
    Re: What did I get?
    You must be a purchasing agent for a govt. entity.
    Bubble gum
    Tooth pix
    Duct tape
    Black glue
    GBMF hammer
    Screw gun --bad battery (see above)
    west texas
    Re: What did I get?
    Those 10016 rod should be 100,000 psi tensile, all position, i dont think its a high deposition but is used for thick steel.
    Should work on AC or DCEP.
    I would use them like a hard facing rod.
    old Miller spectrum 625
    Lincoln SP-135 T, CO2+0.025 wire
    Miller model 250 and WP-18V torch
    Craftsman 100amp AC/DC and WP-17V torch
    Century 115-004 HF arc stabilizer
    Home made 4 transformer spot welder
    Home made alternator welder
    Northern Cal., Shasta County
    Re: What did I get?
    Some HVAC guys use the stay-silv 15.
    Re: What did I get?
    That stay silv in todays market is about $3.00 per stick. It was a buck a stick in the old days and then around $50 a pound. There are 26 sticks to the pound. How much did you spend ? If not too nosy.
    Apr 2014
    Central PA
    Re: What did I get?
    $58 for the lot, included fixed helmet, another without headgear, some scrap metal, 2-3 chipping hammers, and the lot in the pictures. Ideally, someone local can make use of the torch tips and whatever else that stuff is. Might try to sell the stay silv to one of the local hvac companies if no one here wants it.
    Jan 2014
    Palmer AK
    Re: What did I get?
    You did ok.
    That wasn't a bad buy....
    Try and salvage some of those stick rods.
    Work will free you.
    Aug 2011
    Cape Cod, MA
    Re: What did I get?
    You did fine, the Stay-Silv and the Nickel cast iron rod are worth that by themselves. The torch tips in the first pic in post # 6 look like they fit the mixing chamber in post #4. Now to find a handle that fits them...
    The steel electrodes (8010 and 10016) look like obsolete junk. Scrap them.
    The rods in the Eutectic boxes may be worth something. Any numbers on them?
    John
    A few welders
    A lot of hammers
    A whole lot of C-clamps
    Nov 2010
    NH
    Re: What did I get?
    Quote Originally Posted by Burpee View Post
    Heehee
    Re: What did I get?
    The greenish rods and possibly the orange ones are likely flux coated brazing rods they are still useable but you might want to dry them and use additional flux.---Meltedmetal
    Jan 2013
    s.Illinois
    Re: What did I get?
    Quote Originally Posted by Sandy View Post
    I got a handful of that stay-silver from the fitters at work, can they be used for tig welding? And what would be the best use for them? I thought about trying cast iron with them.
    Precision tig 225
    Millermatic 185 w/ spoolgun
    Lincoln 140
    Dewalt cold saw
    Feb 2010
    Northern MN
    Re: What did I get?
    Quote Originally Posted by vettersjake View Post
    They are silver hard solder, used for soldering copper pipe fittings in high pressure applications like AC refrigerant lines. They will work on steel if you set the joint up for brazing and use the right flux. Not sure they would be very useful on cast.
Page generated in 1,713,294,707.75693 seconds with 19 queries
