Results 1 to 25 of 36
Thread: Cutoff wheels...1/16" or 0.045"?
    Aug 2012
    AR
    I've been using a lot of 1/16" thick, 4 1/2" cutoff wheels lately. Most of the cutting with the 1/16" cutoffs has been on 1/8" up to 1" mild steel (A36) bar and rod, plus some sheet from 1/8" up to 3/8".
    It seems that the 1/16" cutoffs are becoming fewer in stock at lot's of places and the thinner 0.045" cutoffs are becoming more common. Have any of you found the thinner 0.045" to be as durable and why does is seem that more of them are being used?
    Some say the thinner 0.045" wheels have to cut less metal, therefore are quicker to cut than the 1/16" (0.0625"). It's hard for me to believe that 2/100's of an inch would make a lot of difference. I personally would think the thinner cutoffs would be somewhat more dangerous at the high RPM's of an angle grinder.
    Jun 2013
    Northwest Arkansas
    Re: Cutoff wheels...1/16" or 0.045"?
    For me anyway, I've always liked the thinnerwheels as they do seem to cut faster. Especially on stainless, they seem to zip through like butter without a lot of heat buildup.
    Sent from my SGH-T989 using Tapatalk
    Nov 2013
    I use .045 diablo disks from home creepo
    Miller trailblazer301g
    Lincoln sa200
    Miller251
    Miller spectrum 625
    Victor oxy-acc
    2002 Chevy duramax 3500 dually 4x4
    Jan 2014
    Palmer AK
    .045 Dewalts.
    IMO
    Just a couple welders, big hammers, grinders, and torches.
    Work will free you.
    Men in dirty jeans built this country, while men in clean suits have destroyed it.
    Trump/Carson 2016-2024
    Feb 2010
    BA, AR
    Using 1/16" disk you cut 38% more material than 0.045". I preter the last one
    Mauricio
    Mar 2014
    Quote Originally Posted by dcoffmanjr View Post
    Is it safe to cut stainless with an abrasive wheel?
    Chris
    Nov 2012
    new york city
    with cut-off wheels thinner is better. as for cutting stainless, my chop saw was on another job and i try not to cut stainless on the band saw so i broke out the cutoff wheel to cut some 2x1/8" flats for a security frame with no problems.
    i.u.o.e. # 15
    queens, ny and sunny fla
    Costa Rica
    .040 Metabo Slicer.
    Bubble gum
    Tooth pix
    Duct tape
    Black glue
    GBMF hammer
    Screw gun --bad battery (see above)
    Jun 2013
    Northwest Arkansas
    Quote Originally Posted by Chrisn View Post
    Chris
    Never had an issue with it. And thanks to all the low dollar shops, and abundance of field work,we use abrasive wheels exclusively at work. The wheels we use are marked as steel/stainless
    Aug 2012
    AR
    Looks like no one is having problems with the 0.045" cutoffs. My main concern was with them possibly breaking easier than the 1/16" ones. Of course with the thin cutoffs, you can't go "King Kong" with them.
    Chrisn, there are cutoff wheels labeled for use with stainless, as dcoffmanjr mentioned above.
    Sep 2011
    I like the thin cut-offs less heat and alot easyer on your tools.
    B.J.
    Jul 2013
    La Porte, TX
    Chris
    Builds up a little more heat but never had a problem.
    Quote Originally Posted by Burpee View Post
    .040 Metabo Slicer.
    Me too. They last longer than any others I have used. Northern tool carries them.
    Gravel
    The difference between theory and practice is that in theory there is no difference.
    Jul 2013
    La Porte, TX
    Thinner ones are easier to break. With any of them it is important to maintain the same angle throughout the cut so as to not introduce any side force or binding.
    Gravel
    Jun 2011
    marlow, ok
    Quote Originally Posted by Gravel View Post
    Easier said then done for some people. I have a hard time free handing straight lines
    1982 miller blue star 2E ac/dc
    Harbor freight flux core pos
    Victor oa
    Mar 2004
    Chris
    welding, plasma cutting and grinding chromium alloys can produce chromium six. A mask and good ventilation is recommended.
    Jul 2013
    La Porte, TX
    Quote Originally Posted by steven325 View Post
    I don't cut long straights often. If I have to cut a long piece of sheet I'll snap or draw a line and make several shorter cuts. It isn't perfect but it is much safer than binding a blade and snap... OUCH!
    Your results may vary.
    Gravel
    .045 is the way to go Walter, Flexovit razor blades or Norton stainless cutting wheels followed by Metabo super slicers.
    Aug 2012
    AR
    Usually when I cut bar or small dimension plate, I use the white paint markers. It makes a line that is just a wee bit wider than a 1/16" wheel, so as I cut, I can get a glimpse of white on both sides of the cut to stay on track. For long cuts, I usually make a shallow scoring line first, then follow up with a deeper cut. Seems to help the wheel follow the path it's supposed to. The white is also easier to see in the shade.
    Mount Tabor VT
    I got by accident some 14" 3/16. That was awful, it takes a lot of horsepower to drive a blade that wide. I've not seen .045
    I think the thinnest 14 inch wheels you can get are 3-32 inch thick.
    Nov 2013
    Livingston, New Jersey, United States
    So what is the best?
    J. R. Bauer
    Aug 2012
    AR
    The 1/16" and 0.045" I was referring to was for 4 1/2" angle grinders, not 14" chopsaws. A 0.045" in a chopsaw would probably explode.
    Nov 2013
    Yes I run 4 1/2 angle grinders.
    J. R. Bauer
    Feb 2014
    Ukiah,Ca
    Here at our shop in the winery business we use Walter mainly and they are by far the best for us. We have used Norton,Standard Abrasive, Radnor,Weiler and Gold by carborundum abrasives. The Walters seem to hold up the best and have the best results on SS and Aluminum. You pay a little more for them but get longer life out of them as well. So they are good enough for me at work so use the same brand at home for my small business. Walter makes great Chop saw blades as we use those as well and a lot of their sanding disks as well. Im not just saying Walter is the best , but they have shown how well they hold up to the hard abuse of SS and I cut, grind and weld it daily here at work. Them some at home as well.
    As for grinding on Steel the Standard Abrasives stuff holds up pretty good and half the price as the Walters so we tend to use them for our little bit of steel use.
    Galen
    Miller TrailBlazer 302 EFI
    Thermal Dynamics 252i w/WeldCraft WP 9F tig torch and foot control
    Thermal Dynamics Pak 52
    Millermatic 250 w/Spoolmate 30a
    Lincoln SA-200 gas driven welder from grandfather
    Blacksmith shop
    Aug 2012
    AR
    I haven't seen any Walter cutoff wheels in the stores, but have seen them online. I am not familiar with them, but sounds like they are worth a spin (pun intended .
    Probably will order some and try them out. Thanks.
Page generated in 1,627,764,522.30792 seconds with 11 queries
