Results 1 to 25 of 37
Thread: Worth it to upgrade?
    Feb 2007
    Marion, OH
    I've been TIG welding since 2007 when I picked up my Miller Econotig in college. It has payed for itself many times over by saving me money on my projects and earning money on odd jobs here and there. I mostly weld aluminum; intercooler piping, intakes, fuel cells, radiators, etc. I've gotten myself into some light production work recently welding up fuel cells and found the Econotig to be a bit lacking when it comes to adjustability. I'm a bit of a perfectionist and constantly trying to find ways to improve my welding; every bead I run needs to be a little bit better than the last and I feel the welder is starting to hold me back.
    I've been trying to find a used Dynasty 200DX for a decent price with no luck. I'm now considering just buying one new, but $3800 is a decent chunk of change right now with all my other hobbies. How much of an improvement would the welder be over my current one? Am I going to see a significant savings on electric? I really like the idea of being able to take it anywhere and do projects in other peoples garages using just about any power source. I wish I could take one for a test weld, are there any welding shops around Ohio with demo units? I guess I'm just trying to decide if the upgrade will be worth the price...
    Feb 2007
    Marion, OH
    Re: Worth it to upgrade?
    I've attached a pic of the fuel cells I'm welding up in batches of 10-15 right now.
    SoCal-LA
    Oh my gosh, YES!!!!!!
    Save you time and money right off the bat. You just can't fathom how quickly the puddle will form, and hold it's shape. One thing I did not like about Econotigs were the limited duty cycle and short range in the pedal.
    I would say keep your Econotig as a backup, or use as the machine to hire a part timer to tack your parts for you while you lay down pristine beads with a new Dynasty.
    Laredo, Tx
    I've not used a Dynasty 200DX, but I really like my HTP Invertig221. Lots of features for the price. I'm very happy with it. ~$3000 will get you a water cooled setup complete.
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
    Feb 2007
    Marion, OH
    Well, I did it. After several days (weeks?) of hemming and hawing, I pulled the trigger and bought a new 200DX from Cyberweld with the contractor pack AND welder cover. $4100 shipped... Now I've got to unload my Econotig.
    I sure hope this thing is worth the money!
    Sebeka and Bemidji MN
    Man I'm jealous Have fun with the new machine!
    Syncro 350
    WOW ! If you did those with a econotig, you will be in Heavan with a DYNASTY ! It's only money ! I would think you would also have a power savings on your electrical bill too.
    CT
    how much do you want for the econotig??
    Miller Multimatic 255
    Feb 2007
    Marion, OH
    I've got it up for sale for $1000 OBO. Average market value on these looks like ~$800-1000.
    Feb 2007
    Marion, OH
    Well it looks like the Econotig is sold for $800 this weekend. Luckly, the 200DX will be here tomorrow!
    Anyone have some setup info for welding 0.120" 5052 sheet in the configurations shown above? I would like to try to leave the laser cut edges unprepped with the exception of an acetone preclean and a quick wire brushing after tacking...
    Laredo, Tx
    Awesome. I'm sure you'll be absolutely thrilled with it. Gotta leave digital features.
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
    SoCal-LA
    Quote Originally Posted by LimitedSlip7 View Post
    You can just weld AC on the default settings, which is 70 or 75% balance, 120 htz. Me, I turn down my htz to 100, but I just like the sound better.
    You using 5356 for the filler? I am doing some tanks of the same style, 1/8 5356. Watch your craters.
    Pa
    Limitedslip: Badass fuel cells, I am sure the dynasty will serve you well, it's almost like the econotig was holding you back.. Get ready for a very fast growth!
    Millermatic 211
    Miller Syncrowave 350lx with cooler and tigrunner
    Thermal Dynamics cutmaster 81
    1955 National Cylinder Gas O/A setup with original patina
    SoCal-LA
    For what it is worth, I jumped on the Dyn200 and ran some seams on a tank. Big difference from plate. I lowered balance and increased freq. Surprisingly the increase in freq kept the cloud to a minimum, and the puddle right in the joint. Had to lower and could lower amps some more even Here is what I liked.
    1/8 5052 sheet
    1/8 5356 filler
    Amps 190
    Balance 70
    Freq 140
    Start (default) at 3/32
    #6 gas lens
    15 cfh argon
    3/32 ceriated tungsten
    Soft squarewave(again default)
    Your results may vary.
    Feb 2007
    Marion, OH
    I've been using 3/32" 4043 on my previous tanks, but I'm wondering if I shouldnt switch over to 5356. I weld the tanks up so that there are only two stop points on the seams and taper off to prevent any craters.
    Are you using the entire 190 amps when welding? You must be hauling ***! I haven't welded up any tanks yet with the new welder, I'll probably be starting on them tonight.
    I did hook everything up on Sat and laid a few quick beads on a 6061 coupon with 4043 filler. Welds looked good but came out a little grainy. Coupon was sanded and the filler was wiped down with acetone. Gonna play around with it tonight and try some brand new filler rod instead of the stuff that has been sitting around for a few years.
    Pa
    I'm sure he's not using the whole 190amps probably 120-140 to start the puddle then pedaling from from there.
    SoCal-LA
    Yes, you should definitely switch over to 5356. 4043 is way too dependent on base metal dilution for any strength. You certainly don't want to have the seam split later on. 5356 is a high strength filler, is more ductile than 4043, and exhibits some exothermic property to the puddle due to the magnesium when welding. But it holds it's shape quite well when you run hot and fast. It also will not speckle from silicon surfacing either.
    The ones we weld are 1/8th 5052 using 1/8th 5356 filler. I will PM photos to you.
    Feb 2007
    Marion, OH
    Well my Dynasty 200DX was stolen two days ago along with ~$3k worth of other tools. It really ****ing sucks. Everything was in a good friends garage and I don't think that their homeowners insurance is going to cover it. I'm not sure if I want them to even make a claim as it jack up their premiums.
    I'm in the middle of a welding project that I've got a lot of money tied up into, so I don't have much of a choice except to go buy another welder. Doesn't look like there are many used welders on the market, so I'm probably going to buy new again. Any recommendations? Any deals that you know of? I noticed Miller changed their Dynasty and Syncrowave lineup a bit, what improvements have they made?
    Thanks
    Nov 2013
    N.B. Canada
    ARE YOU SERIOUS? wtf ,bunch of rats!!!!
    May 2015
    I am really sorry to hear about your misfortune. If you are staying within the dynasty 210 dx budget I would recommend that you look at ESAB Heliarc 281I. I believe one can be had for under $3500. And goes up to 280 A which will be very helpful for your aluminum welding. It also has a 40% duty cycle at 250 A. ESAB currently has 100 day money back guarantee. If you don't like the machine for whatever reason you can send it back and get your money.
    MA
    Quote Originally Posted by Weld_ View Post
    If you have the power available and a place to keep it permanently why dont you just buy a syncrowave off craigslist for 500-1000?
    After reading this I am going to up my security, i am so sorry about your tools.
    Laredo, Tx
    The Dynasty 210dx seems like the ticket right now, based on features. BUT, the HTP 221 goes on sale starting November.
    HTP Invertig 400
    HTP Invertig 221
    HTP ProPulse 300
    HTP ProPulse 200 x2
    HTP ProPulse 220MTS
    HTP Inverarc 200TLP
    HTP Microcut 875SC
    Mount Tabor VT
    That stinks!
    I love the 280DX. I've not done fuel cells. Terry is the expert, but I've heard no mention of 4943 filler. It is stronger than 4043, melts at a lower temperature, so less distortion, and much easier wetting action. If I were you I'd ask Shovelon about 4943.
    May 2015
    Apparently it's on sale already. $200 off the regular price but not for the dual voltage model.
    May 2010
    Sparks, NV
    Quote Originally Posted by sparky24 View Post
    Miller 330ABP's don't go missing out of garages. We should add that as another benefit of transformer machines.
Page generated in 1,627,435,255.93397 seconds with 12 queries
