The amp ranges are as follows: 115VAC= 30-135A range, 230VAC= 30-175A range. To me, it looks like a MM135 and MM175 (with higher rated output and thicker single pass performance) combined into one machine.
Thanks chris, good info. The bottom end is the same 120 or 230 but you would have a nice machine that can go anywhere with a few cord adapters. Weight could be an issue for some. Not for me, someone wants something welded it comes here. I think the 210 is no doubt heavier than the DVI ??
For your applications and what you posted earlier
Looking at the specs in the '06 Miller book, the DVI and 210 are capable of the same single pass (3/8") performance. The one thing it doesn't touch is the 60% duty cycle of the 210. Any other thoughts?
I'd really think about the 210 if I were you.
Somewhere I posted a little blurb on my experiences with the 175 but long story short, if you are going to do any substantial work with materials in the 3/8ths range a 210 might save some frustrations. More money was my hold back originally but I wished I'd made that less of a priority now. Not that there is anything wrong with the 175 but the stats on a 210 are better and the low end is still down there with the 135, DVI and 175.
Anyone can take two coupons of 1/2 inch stock and turn out a pretty fillet weld with a wide class range of machines and proclaim that as its capabilities. It's quite another to butt two honking pieces of iron together (spelled heat sink) and start burning them in. I've bogged the 175 down on a few occassions and the scary part is that that is NOT a clear cut line as if it just shut off at some certain point. Manufacturers and salesmen can say what they want but I really don't believe any machine just runs up to a point then cuts off. They, at least mine, starts giving erratic performance that isn't all that recognizable well before it reaches the thermal cut-off point.
So food for thought==if you are just going to do an occasional 3/8ths plate onto a piece of 3/16ths and run a 4 inch bead==you're good to go. If you are going to go out there and try and fish plate up an oily painted backhoe boom==you're gonna get in trouble.
I think these types of unknowns and variables are what scares off guys like txredneck and others when we ask "will this work for 1/4 inch?" :waving:
