While I had it out in front of the barn I figured I would go ahead and fill up the gear box with some new oil.It holds exactly 1 quart.Well I did that and something come up and had to run to town and when I got back out to the barn about 4 hours later you can probably guess what I saw,about 1 quart of 85W/140 gear oil on the ground.A fescue seed or something has got up in the seal or it's just dry rotted where it has set outside the barn for over a year and a half because I didn't use it at all last year.I'll either have to replace the seal,big job considering having to borrow the tools to do it(blade nuts require a 1-11/16" socket and blade pan requires a 1-1/2" socket).I have a 1/2" drive,1-1/2" socket which I could use to take the pan with blades attached off(just have to put boom on tractor and turn bush hog upside down).I'm going to try what the John Deere mechanic suggested first before I go to turning it upside down and taking the pan off.He suggested putting John Deere Corn Head grease in the gear box.It's a grease that stays solid then liquifies with movement and then goes back to solid with no movement.I had read comments from other websites about using corn head grease in bush hogs and they were all positive,one guy said he put it in there 10 years ago and has had no problem with his gear box on his bush hog.So I went and bought 3 tubes,just $3.75 a tube and put it in there and mowed just a little around the barn,started raining is why I quit so I didn't get to check out to see if any come out.Gear box is quiet,can't hear it at all over tractor motor just the whirring of the bush hog blades.I did weld on the corner of the bush hog that has the least damage to to see what setting's I can use,like I said earlier,not good at stick welding at all.A good experienced stick welder could make it look like it's ready for paint.I wish I could just use my mig welder,would be perfect for the amp setting's it has.I just welded the one corner,4th pic above in previous post to to see what it would do.More concerned about taking care of gear box at the moment.
