Hi Guys -
I'm new to the forum and have already gained huges amounts of knowledge from everyone on here. I just picked up an older Miller 225v Thunderbolt, and I need to figure out how to wire up a plug that will work. It came with a 3 prong 240v plug. Long story short, I'm renting and don't want to try to rig a plug in the garage for the welder, I have a 5k watt generator with a L1420P female plug which is rated at 125/250v. Can I make an adapter for the two different plugs so i can hook it up to the generator? I'm looking at the plugs and the welder plug is a 3 wire set up with green, red, and black. And it looks like the plug off the generator is a 4 wire set up. Is there any way I can make an adapter to go in between the two? and if so can someone help me out (visually)? So I can start using this bad boy
Thanks
Thanks
