Lincoln Pro Mig 140 very weak arc
4.7K views 3 replies 3 participants last post by  ecerna64
I have a Lincoln pro mig 140 Code # 11634 Just quit welding only have very little sparks when trying to start a weld. Wire is feeding ok just not getting a strong weld like before any suggestions. I have checked all connection on the ground and the gun seems to be in good order.
Thanks
#2 ·
Sounds like a loose connection. Check the connections at the cap and on the back side of the terminals.
Look at the rectifier too to see if you burnt up a diode.
