Page 3 of 3 FirstFirst 123
Results 51 to 58 of 58
Thread: Miggy Got 'Capped'!
  1. #51
    west texas
    Re: Miggy Got 'Capped'!
    Quote Originally Posted by spray cowboy View Post
    Duane,
    Is there no issue going from the 35v caps to the 50v ones?
    More volts is better, only problem is the higher the voltage the bigger the cap is going to be for a given number of uf.
    If you have the room go for it, welders are hard on caps.
    old Miller spectrum 625
    Lincoln SP-135 T, CO2+0.025 wire
    Miller model 250 and WP-18V torch
    Craftsman 100amp AC/DC and WP-17V torch
    Century 115-004 HF arc stabilizer
    Home made 4 transformer spot welder
    Home made alternator welder
  2. #52
    Jun 2014
    Oregon
    Bumping this thread up, it's great information. I think the caps are weak on my black face 200. It's starts to spatter pretty good on tap 5 and above. Also feels like a huge jump from tap 4 to 5. I have 8 15000uF 45 VDC caps in it. I think they are original, so I'd like to switch out.
    Looks like a good Mallory replacement is CGS153U050V4C 15,000uF, 50/65 VDC surge.
    Can anyone point me to a supplier for these? Maybe one that is less than $20 each? They don't seem to be available anywhere.
    Thanks for any help!
    edit: Miller links for future use:
    http://miller4less.com/info/pdf/2011PartsGuide_91.pdf
    http://miller4less.com/product_info....oducts_id=3227
    Millermatic 200
    Lincoln SP-100
  3. #53
    May 2008
    Orange, TX
    $20 each isn't that bad and any less is a bonus.
    These don't meet your less than $20 each criteria but are the same physical size as the originals.
    http://www.tedss.com/2020003649
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
  4. #54
    city of Four Flags
    Do caps go bad from use or simply age?
  5. #55
    May 2008
    Orange, TX
    Yes.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
  6. #56
    Jun 2014
    Oregon
    Duane , can I just swap on 6 of the 20,000 2 inch caps to replace my 8? Would save me $50 doing it that way.
    Millermatic 200
    Lincoln SP-100
  7. #57
    city of Four Flags
    Yes.
    Gotta love your answers
    Maybe one of these days I'll pull the wrapper off the old 200 and see what the caps look like.
  8. #58
    May 2008
    Orange, TX
    Quote Originally Posted by pcoplin View Post
    The logic behind the increased quantity is reducing the filtering requirements (charging/discharging rate or speed) of each unit but I'm sure 6 of the 20k units will work just fine for a long time to come.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
Page generated in 1,713,272,697.82886 seconds with 18 queries
