Page 2 of 2 FirstFirst 12
Results 26 to 40 of 40
Thread: "There's a Hole In My Bucket Dear Liza, Dear Liza. . .
    May 2008
    Orange, TX
    Re: "There's a Hole In My Bucket Dear Liza, Dear Liza. . .
    Quote Originally Posted by farmersamm View Post
    I probably got it all upside down Duane
    I wanted to see how the MIG handled the cracks in Post #4. Pics 1, 2, 3, and 4. It looks like the plate was replaced, but then I don't see the joint as welded.
    Sorry
    Yeah the bucket was upside down at that point and sorry, I was cooking along and forgot to take some shots of the cracks welded up. I ground them way out and gapped the cracks by cutting them with the 3" cutting wheel. As for the MIG, she did good with the multipass welds.
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Aug 2008
    I think I see now.
    You know me, I'm always suspicious of wire machines when it comes to heavier thickness material. I like to see how it looks.
    I know there's big, really big, machines out there that handle it like a piece of cake. But I always want to see the medium range machine results. And I'm not even sure if your machine is in the "medium" range. That's how unfamiliar I am with the wire process.
    Did you have to turn the gas up to work outside?
    Only reason I haven't even considered MIG, is my working environment. Too doggone windy. Some days a stick weld looks like pewter (gray weld) because the wind is so high it blows the shielding away.
    http://www.farmersamm.com/
    May 2008
    Orange, TX
    I think I see now.
    The MM200 handled the 3/16 and 1/4 material with no problem and as I stated in my response to Stick-man, .045 wire would have been better than the .035 I used so a few more multiple passes were required. Even .045 would have required multiple passed where the new back plate tied into the lift arm brackets and to fill in the ground out cracks at them as well.
    As for the gas, yes, I turned it up a little higher to 30cfh for working outside and to help keep the gun nozzle a little cooler running in the hotter globular transfer mode. I did have to grind out a few welds and 'backtrack' due to a gust of wind that would carry the C-25 away and leave a 'burnt surgar' pitted bead before I let up. The shop apron where I was working is a little protected and if it was giving me constant fits I would have broken out the Syncrowave 180SD and used stick (6013 & 7018). Would have had to go get some more rod as Brink, ME had been doing a lot of practicing with his Weldanpower 150.
    My 1st generation MM200 would have to be modified to allow switching polarity to run flux cored so I wouldn't be able to go that route. I could try dual shield but like I said, the shop apron is a little protected so it's not that bad running MIG out there most of the time.
    I'll get some clearer closeups of some of the beads and post them.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Feb 2010
    Southern Indiana
    What was your cutting method to get rid of the old ugly stuff? Did you use a plasma cutter? How well does that work on heavy rusted steel? I'm also working on a front backhoe bucket right now, but its not quite as bad as that one was.
    Oh, and darn fine repair work.
    Miller 250x & Lincoln V205-T
    Smith Oxy-Prop torch
  5. #30
    Feb 2010
    I could have done that with my weldpak 125 with 025 wire
  6. #31
    May 2008
    Orange, TX
    Quote Originally Posted by Chuck View Post
    Used the PakMaster 100XL for most of the cutting. 3" cutoff wheel for the rest. Turned the 100XL down to slice the bottom portion over the 3/8" plate w/o cutting into the 3/8". Turned it up to V out the thick cracked edge from both sides and it sliced thru like a hot knife thru butter. No popping rust with plasma like there can be is with O/A.
    Thanks for the compliment.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
  7. #32
    Dec 2008
    looks great! I wish I could fix unmolested buckets, the ones I work on have been patched and welded by quite a few "welders" before me, you did a nice job man!
    "Obstacles are those frightful things you see when you take your eyes off your goal" -Henry Ford
  8. #33
    Soda springs,Id
    Great job, Duane!! And yes, It's good to know there's still folks out there willing to go the extra mile on a barter deal. I'm sure you both feel you got a good deal.
    Mike
    Ol' Stonebreaker
    Hobart G-213 portable
    Miller 175 mig
    Victor O/A setup
    Makita chop saw
  9. #34
    Edmonton,Alberta
    There is no hole any more...good repair Duane
    Leigh
    Lincoln Classic 300D
    Lincoln SA 250
    Red d arc 300 diesel
    Ranger 305
    Miller 302 Trailblazer
    12V Extreme Suitcase
    Miller 200 DX
    Victor O/A torches
    3 dodge dually cummmins
  10. #35
    May 2008
    Orange, TX
    Well the owner just got his loader/backhoe back this past weekend as the guy from work that hauled it back and forth had been using it and he (owner) was very pleased so I'm happy. I'm told even his wife was impressed.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
  11. #36
    Jun 2004
    Beeville
    Great job Duane!
    RD
    1984 Chevrolet C30 welding truck
    1966 Lincoln SA200 Continental F162
    1942 Lincoln SA200 Hercules IXB-5
    1991 Lincoln LN25
  12. #37
    Feb 2010
    I love threads like this. To me, this is what welding is about. It is both a practical skill AND an art.
  13. #38
    Apr 2010
    Dang what a nice fix
    What would SATAN do ??
    Miller Trailblazer 302 AirPak
    Miller Digital Elite
    Optrel Welding Hat
    Arcair K4000
    Suitcase 12RC / 12 VS
    Hypertherm PM-45
    Rage 3 saw
    Rusty old Truck
  14. #39
    Dec 2009
    Stevens Point, WI
    Nice work and what a great friend!
    You did it wrong though, you are supposed to use it, break it, and then give it back.
  15. #40
    May 2008
    Orange, TX
    Quote Originally Posted by killdozerd11 View Post
    Thanks. I can't believe that was 8 years ago! Time flies when you're having fun so I must be having a blast.
    Quote Originally Posted by VPT View Post
    I'll have to let my Dad know that he taught me backwards.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
Page generated in 1,627,614,534.34456 seconds with 11 queries
