Been lurking trying to fix a colossal tech Cat 416 D there is one relay that is broke in half only thing holding it together is the clear plastic cover. I have emailed the guy from Ebay (usaprovidersinc) and no replies. The numbers on the relay is WJ175 (Jqx-38FA) 40A 250 VAC 28 VDC of course Made in China. I have not plugged it in not sure what it does and dont want to start a fire . I have searched the web put cant find this relay my soldering skills are not the greatest dont want to just throw this in the trash.
Thanks
http://www.PlasmaMetalCutter.com
GiantTech Cut40D
GiantTech Cut50D
GiantTech CT520D
GiantTech Tig200s
GiantTech Arc200
GiantTech Tig200PACDC
Miller MM210
No Brand Chinese Chop Saw
No Brand Chinese 4" Angle Grinder
Well I fired it up . It will work for about 30 seconds then pop the breaker (dedicated 20 amp circuit) not sure if I have the amps set to high (dont have the manual) I am debating running the 50 amp circuit. If I can get this working just for tig and arc (want to learn that ) I am thinking of buying a good Plasma Cutter . What gives the most bang for the buck ?
Hypertherm Powermax 30 or Thermaldynamics Cutmaster 39 are both very good units for very reasonable prices. I have used the Cutmaster 39 and it was a dream. Dont have experience with the Powermax 30 but hear it is very good and more portable. If I were to buy another plasma unit, it would be one of these. They are more than a chinese unit in price, but you would be getting more for your money.
A few of my toys !
LinuxMint
Manjaro
Miller Roughneck 2E
Lincoln WeldPak 100
HTP MTS 160
Chicago Electric 80amp Inverter
Victor O/A
GiantTech Cut40D
GiantTech Cut50D
GiantTech CT520D
GiantTech Tig200s
GiantTech Arc200
Miller MM210
I like it, it does what I need, but it does lack a feature I like that other units have. Example would be pilot arc. The one feature I miss most. Other than that, it does a good job for a reasonable price for my requirements.
A few of my toys !
LinuxMint
Manjaro
Miller Roughneck 2E
Lincoln WeldPak 100
HTP MTS 160
Victor O/A
Giant Tech has been great getting this thing running since I am new at it my cuts are not the greatest I practiced on a piece of 1/8 or 1/4 angle iron and it cut like butter after I ran a 240/30 amp line the pics are my first cut then my second (I cleaned it up before I took it )
Last my welding cart I built 2 yrs ago
Hobart Handler 140
Chinese Multi Machine
I have a colossal tech cat520D. It blew a varistor while I was cutting. It is the blue one with a red resistor beside it near the copper coil on the top board close to the front of the circuit board. Their in your picture. I need the numbers on them. I think it may be 391k on the varistor mine burnt and I could not get the number. I would really appreciate it if you could help.
Gianttechguy do you make units?
Current welder
Hobart Handler 187
Dead welders
HF 151 dual mig
Craftsman Welder 20511
Craftsman Welder 80amp Flux
I killed them LOL!!!!
I have a Colossal Tech Cat 520D. It blew two electronic parts while I was plasma cutting. The parts are that blue varistor and brown-orange capacitor at the base of that very large and long copper coil on the middle board in the picture above (post #4). To those of you who have one of these Colossal Tech machines with a similar layout, can you provide the identification information on those two parts? I'm going to try to repost the above picture with the parts circled.
The Giantech guy hasn't been around here for a loooooong time.
The units are imported from China.
They are basically a Zeny plasma, just like all the other hundred no named units.
Ryan
CK WF1 TIG wire feeder
Miller Spectrum 375 Xtreme
Optrel e684
Miller Digital Elite
Miller Weld-Mask
HTP Pro Pulse 220 MTS (Anniversary Edition)
1962 Idealarc TIG 300 300
1974 Idealarc TIG 300 300
1988 HF Power MIG 150
2015 Lotos Ltpdc2000d plasma/Stick/TIG
Hi guys newb hobbyist here.
I own a Colossal Tech WS200A tig/stick welder and I've lost the manual for it does anybody know where i can download one ?
I appreciate your help
Thanks
Bob
