Some of you might have seen my post in the Miller section about researching & bringing to life an old Arc Pak 350. Well, today I ran my first ever TIG weld without any filler and i`m hooked. I had no idea what to expect as i`ve never handled a TIG torch or so much as seen someone TIG weld before. I just ran a couple quick clean beads across some 3/16" mild steel with pure argon and about 60-70 amps estimated.
So some of the questions I have are:
How do you guys hold the torch? Do you try to rest your forearms, or would I be better off trying to hover free hand from the start? I realize that many welds I might do will not have any place to rest my arms, so it might be best to learn a more difficult technique to begin with.
What kind of distance should I expect to keep the electrode from the work piece?
Gas flow, i`m running about 15 CFH pure argon right now on my initial tests and the welds look great.
It seems to be quite a learning curve from MIG or my personal favorite - stick welding.
And the last thing - when moving the torch, should I try to keep it in a very uniform firm straight line, or do any sort of weaving, circling, or movement - moving in a clean straight line alone seems to hold a nice puddle.
If anyone has any suggested reading, please pass it along - I do a ton of reading & research on any subject that interests me.
I have also had alot of trouble finding any photos or videos of people TIG welding to see their technique, stance, and so forth.
