I am welding up some 1/8th inch by 2 inch by 4 inch HRS coupons for TIG welding practice. Scratch start, around 85-90 amps, 3/32 gold band tungstens, #5 gas lens cup/gas lens collet body, 15 CFH of argon. I am using 1/16th inch ER 70s2 filler. Welding butt joints, non beveled, with a 1/16th gap or slightly less. My amps are just enough to get complete penetration without falling through/over penetrating. But my welds look like a dogs butt from the top side. They are flat, undercut, they don't have that stack of dimes look and just look over heated. I am thinking I need larger filler.
So here are my questions:
1. is there a rule of thumb for selecting filler rod for TIG? or is it more like gas welding where rod size is a variable to be solved for?
2. Keeping in mind that I don't have a foot pedal, I am having no problem TIG welding on thicker material and getting nice looking beads (nice-ish maybe?
) But on 1/8th material all my beads are coming out either way too hot looking or cold/under penetrated. What's the secret on the thinner stuff? would moving up to a 3/32 or 1/8 filler rod help this? I am thinking yes, but need to make a trip to Airgas on Monday to get larger rod.
3. This plate I am practicing on seems to develop new mill scale after running a few beads on it. I am grinding the mill scale off and cleaning with acetone to start with. What is the practice for re-cleaning in between passes?
