I never know if these threads should go here or in the appropriate manufacturers section but seeing as it's not an operational problem, Welding Projects & Pictures it is 'cause it was yesterday's project and I got pictures.
I picked up a Millermatic 30A wire feeder a couple weeks ago to add to the Airco MIGet unit I have http://weldingweb.com/vbb/showthread.php?t=30514 that's been sitting idle since I checked it out to make sure everything works a-OK. Time for it to earn its keep.
The MM30A just happen to come with (4) three phase, 250amp Airco power supplies (rebadged Miller CP250s), a Chemetron WC-50S wire feeder, Linde MIG 31 wire feeder and (2) Airco AHF-R2 suitcase feeders as well as (2) flow meters/gas hoses, a 300amp Bernard gun, a 400amp ProFax gun and a bunch of work leads/clamps. All working but we'll leave all that for another time.:roleyes:
Anyway, the MM30A has seen its share of action and was covered with years of caked on dirt and grime so it was time for a 'freshing up'.
All broken down and ready to get started.
The drive head main shaft exhibited an unacceptable amount of slop and although I figured it was a worn bushing, it turned out to be more the fault of the shaft as can be seen here.
One end built up using the Sycrowave 180SD and 3/32" ER70S-2 filler, 3/32" red tungsten, #4 cup, argon @ 12cfh, DCEN with amps to max and peddled as required. Looked a couple times and meter read 39 and 52 amps after running a bead.
Main shaft following some time in the Enco lathe. Obviously my machining skills aren't any better than my welding and although it ain't pretty, it's back to spec diameter (.625") where it needs to be. If I had the ability to cut keyways I would have opted for a complete new shaft as I have the required material on hand. Although I did not change the bushing, the shaft 'repair' removed over half the slop to where it is now acceptable for me.
Stand by for some shots of the reassembly.
