i test guys like you all the time,,6g great position i love it,to easy,.first ,dont look at stainless like its harder ,cause far from it ,its beautifull stuff to weld ,and lot more fun!the key is stainless ,is all about contamination ,how to avoid it,6g stainless we have 4 or 5 6g stainless,but all 6g prcedures we we have are 100 percent back puge,simple rule with stainless is wat ever your weldind has to be very kleen,always! make sure when you test with stainless,before you do anything make sure that you have NO tools that are not made of stainless, i.e wedges ,wire brush, ect make sure they are all stainless,nothing around you that may intrduce carbon,it's a great material to weld you just have to take your time ,keep kleen,and most ,don't over heat,shorter passes ,stainless if it overheats ,its contaminated,first thing to go is your chrome,if that happends its over ,tip,set your machine so the torch has,,asecond roughly of prepurge gas,so your well sheilded wen you start welding,then set the machine so you have around 8 seconds of post purge,,wen you stop welding,,DONT take the torch away from the weld area till the gas stops,this is a very good habit to start ,treat stainless just like titanium,,contrary to watever you heard about having a nice weld wen you seethe nice rainbow colour,this is the stupidest advise ive heard ,,read up on your metalurgy,you'll understand,,colour is bad ,colour means contamination,,it means the heat is effecting the chromium,but unlike titanium,you can generally remove it with a wire brush,never weld over top of any ranbow colour,,so the main thing you need to do most of all,,slow down,take your time keep kleen,,let it cool down after every weld ,d you'll enjoy welding ,,,speed kills,,,best of luck,,,,mojo
