Results 1 to 24 of 24
Thread: Miller 250 AC/DC HF Restoration and Manual assistance please.
    Jul 2014
    Shawano, Wisconsin, United States
    Just picked up this unit for a mere $75. It is an Airco, but i know it's the same machine as the Miller 250 AC/DC HF. Now I am attempting to make it function. It came with no cord, leads, torch,pedal. I have removed the case and blown it out, nothing appears burnt, no leaking caps, BUT the amperage control does not move. I am hoping that the sliding core in the transformer is just sticky from a long period of storage and not welded together...any manuals and advise is greatly appreciated.Name:  wel3.jpg
Size:  40.8 KBName:  wel1.jpg
Size:  40.5 KBName:  wel2.jpg
    May 2008
    Orange, TX
    Re: Miller 250 AC/DC HF Restoration and Manual assistance please.
    Welcome to the forum.
    Model# 2.5A/DDA-24-HF-B or 2.5A/DDA-24-PHF-B?
    SN?
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Jul 2014
    Model# 2.5A/DDR-224-PHF-B
    Serial# P349413
    May 2008
    Orange, TX
    224 or just 24? Should be just 24.
    I suggest you contact Miller Customer Service (920-734-9821) with your Model/SN and ask if they'll email you form SPM-312 and Circuit Diagram No. A-592-A03 (that should be adhered to the inside of the housing wrapper).
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Jul 2014
Size:  32.3 KBName:  1.jpg
Size:  27.8 KBName:  2.jpg
Size:  25.8 KBName:  3.jpg
    Jul 2014
    I found the amperage control issue....someone welded these tabs and installed a setscrew on each side locking the amperage setting. Why on Earth would someone want to do that? This unit came from the local high school...Name:  setscrew.jpg
    Thermal Arc Fabricator 211i
    Hobart Stickmate LX
    Airco 250 AC/DC Heliwelder
    https://www.facebook.com/scrapmetalm..._type=bookmark
    May 2008
    Orange, TX
    I stand corrected on the Model No.. Perhaps my info is a misprint. ???
    On the "fixed" amperage setting, if it came from a high school perhaps the teacher fixed it at that setting for a specific material that he/she taught (if you could call it that) welding technique with. Who knows? Your guess is as good as anyone's.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Jul 2014
    Thanks Duane. Will be getting in touch with miller one of these days. Gotta go pick up a plug and make a cord. Flip the switch and see if it's worth further investment(ground, stinger, torch, and pedal. I'm so exited....like a fat kid in a candy store!
    Hobart Stickmate LX
    Jul 2013
    La Porte, TX
    I understand your excitement. I just bought a Dialarc HF.
    Hey Duane, your PM space is full.
    Gravel
    The difference between theory and practice is that in theory there is no difference.
    May 2008
    Orange, TX
    Quote Originally Posted by Gravel View Post
    Should be good now.
    Thanks.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Jul 2014
    I'm going to wire the beast directly to the breaker box. I am thinking 100A breaker and 4/3 wire. Overkill or just right??? I hear these are pretty power hungry.
    Hobart Stickmate LX
    Jul 2013
    La Porte, TX
    My Dialarc HF will run full out on a 60A breaker but I don't know how long.
    Hard wire on a 100 w/#4 will be nice.
    Gravel
    Hi Christopher! Nice catch!
    I have one of the same model on its way that I have never seen up close. Is the fitting on the lower right Argon output and the one above input?
    What is behind the caps for water in+out?
    Thanks,
    Fred
    May 2008
    Orange, TX
    Quote Originally Posted by fred g View Post
    Yes.
    Nothing as it doesn't have the optional valve for a water cooled torch.
    Syncrowave 180SD
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Mar 2012
    Hi Christopher,
    These will last forever. I just noticed that this one seems to have the selenium power rectifier, that could go bad over time.
    Things to look for are leaking caps on the HF, relay contacts wearing out (one is 24V DC and I think the other is 24V AC) and replacing the smaller selenium rectifier that controls the "start" mode of HF with a simple 50A bridge. Gotta love that massive switch they use to turn it on- looks like a standard light wall switch, except huge! While doing repairs I fired mine at night and when I hit that switch there were definitely some sparks just turning it on.
    Keep in mind that the HF control start plug (upper right) must have the pins shorted for HF to fire on this machine.
    Got mine for $100 with a cart and 50 feet of 6-3 SOOW, so it was worth the money just for the cord.
    Enjoy,
    Tim
    Jul 2014
    Been a while and thought I'd post an update. Rigged the unit with a temporary cord and fired it up. Everything is working so far..well at least on the DC, I have not even tried AC yet. Burns rods clean and smooth. Scratch start tig works well. Only real issue I have is the gas solenoid seems to be stuck open. It just blows gas all day. Just picked up some nice long leads for it. Now I can stick anywhere in the driveway. Working towards doing some AC tig once I get everything worked out. Anyone have a spare gas solenoid for these things?
    Jul 2014
    Well, the timer never moves, but if I turn in to zero I the solenoid closes. It appears someone has put a pair of pliers to it once before so it's the obvious culprit. When I get some time I'm gonna open the case and poke around with my meter and be sure relays are all good. Then hopefully get some flea bay parts and be good to go. Thanks for the info.
    Hobart Stickmate LX
    Mar 2015
    I picked one of these welders up last Sunday. Got everything cleaned up and wired in. Was able to get a nice weld in AC/DC-/DC+. The caps for the HF section have oozed out, so I've got replacements order for that. I don't believe the HF works as it should be. (I did set the arc gap though) Anyhow, I'm setting this unit up as a workhorse for everything around the house/shop. I have a TIG torch setup on the way as well as a regulator. Going tomorrow to look at/buy a cooler setup for it as well.
    Anyhow, I'm sure I can get the HF stuff sorted. The torch I bought has a switch on it as well. But my real question is, can a pedal be retrofitted into these units? I see the Miller RFC-23A is the pedal of choice for the Dialarc 250. But I know there's no provision for remote current controls on this unit. Is there a means of adding it to this welder? Or has anyone split up the internal wiring to feed 110V to the HF side and Low voltage to the gas solenoid. (Alternatively, I could swap out the solenoid to a 110vac I guess) I've been reading about SSVR's which I could use a 10K foot pedal to control and vary input voltage to the transformer that way. But I'd be more interested in constructing something "factory" for it.
    Mar 2015
    So I was able to find a parts manual on this welder. Luckily it has a schematic at the end.
    Here's the factory wiring:
    Now, I've purchased a SSVR setup to control it. It uses a 10k ohm pot, which happens to be the same value as all the TIG inverter welders from china. So I'll use one of those to control it.
    So this is what I've come up with so far on how to adapt a pedal. I also plan on adding a DPST switch as well. One side of the switch will revert from foot pedal to a 10K resistor to allow the welder to be switched between normal and pedal mode. The other side of the switch will be used to power the 110v circuit tapped from a leg and neutral. But I'm trying to figure out how I need to make this happen from the schematic. I see from the schematic there's a tap on the welder side of things at 25 and 28. I know TD1 is the timer for postflow as well. I will use the microswitch to plug into the remote HF start on the pedal. (RC1) I'm just trying to figure out how to feed the Gas solenoid/timer/HF side of things 110v but still work the relays. Any thoughts?
    Mar 2015
    Oh and I understand the varying the input voltage will mean the dial will still set the upper limit output. So if I set it to 150 amps, full pedal will only deliver 150 amps.
    CT
    4 wire seems like overkill to me. I am running 6 wire with a 100 amp breaker. I can't imagine the dialarc draws any more than a sync 250.
    Miller Multimatic 255
    Mount Tabor VT
    Dunno, It isn't a Dialarc. I'd check the nameplate, or the manual.
    Jan 2008
    Lansing, MI
    No, it's not a Dialarc, it's just an HF 250.
    Probably calls for 100+ amps for full!power operation.
    Best guess without looking it up.
    Oct 2021
    Michigan
    Because it came from a high school and they didn't want the kids messing with it I imagine. That gets done alot where shops, etc. don't want operators messing with settings, speeds, feeds and so on
Page generated in 1,638,156,917.47080 seconds with 12 queries
