Page 101 of 118 FirstFirst ... 519199100101102103111 ... LastLast
Results 2,501 to 2,525 of 2938
Thread: Blacksmithing tools
  1. #2501
    Re: Blacksmithing tools
    Quote Originally Posted by Need Advice View Post
    I think that set of tongs are the same ones i posted.
    If you aren't buying them from Ken's Custom Iron, you're buying stolen IP. Read the description carefully and you'll often see that the knockoffs come with an aluminum rivet. Ken came up with the idea and has a long history in the blacksmithing community. The people trying to make money off his reputation are communist hacks preying on the uneducated and cheap.
  2. #2502
    Sep 2021
    USA
    Quote Originally Posted by VaughnT View Post
    Thanks for letting me know. Yes the rivets i saw were the color of aluminum. I'll get mine from Ken.
    Lincoln Pro MIG 180
    Chicago electric 225 Arc
    Harris oxy fuel
    Everyone who calls on the name of the Lord will be saved. Romans 10:13
  3. #2503
    Sep 2021
    USA
    Ken's Custom Iron's set does cost a little more but i don't want to contribute to thieves. Im cheap but not that that cheap.
    Lincoln Pro MIG 180
    Harris oxy fuel
  4. #2504
    Fredericksburg, VA
    What is your time worth? Are you willing to destroy at least one set of tongs while making them? As a beginner, you are likely to make mistakes that can ruin the material and develop bad habits.
    The best thing you can do is find a local blacksmith and take a class. If you can't find one on Facebook or Google in your area, go to the ABANA website and look for one.
    https://abana.org/
    Millermatic 252 MIG
    Miller Dynasty 200DX TIG
    Altas 12x36 Metal Lathe
    Bridgeport Milling Machine
    www.psacustomcreations.com
  5. Likes Lis2323, VaughnT liked this post
  6. #2505
    Sep 2021
    USA
    https://abana.org/
    That's not going to work for me. I'll have to rely on video instruction instead. I can learn from my mistakes. I made a bottle opener and the inside of the hole was rough and had what appeared to be a cold shut. I assume it happened because of one of two reasons. Either i forged it too cold, or its because i used the wrong kind of punch to punch the slot, or both perhaps. I used a regular chisel as a slot punch and the corners were sharp instead of rounded. Next time i try a bottle opener i will use a actual slot punch and if that doesn't work i know i forged it cold.. Another problem i had is i didnt have a horn to shape the hole. My homemade anvil horn needs grinded to a point. I never got around to finishing it. I might buy a hardy cone. The reason i never finished shaping the horn is because i burned up my HF 7" grinder on a job i did. A 4.5 isnt fast enough for such a big job.
    Lincoln Pro MIG 180
    Harris oxy fuel
  7. #2506
    Aug 2012
    AR
    Does anyone know what the 3rd pair of tongs that have slots cut into them are for? I've never seen tongs like that before.
    When you assemble the slotted tongs, there will be two opposing slotted jaws. If you put a curve, convex to the inside, in each jaw you can hold flat bar stock. The jaws will have to be fitted for a firm grip. This is a pair I made for 1/4" flat bar stock.
    Name:  Tongs - slot jaw 04 resize.jpg
  8. Likes VaughnT, Need Advice, whtbaron, Shootr liked this post
  9. #2507
    Aug 2012
    AR
    Thanks, so i guess welding on them is out of the question. I'll have to heat and beat like Shootr said.
    You can weld them, just don't dunk hot, high carbon steel into a quench like water. Let the steel cool to warm to the touch if you need to dunk it.
  10. Likes Need Advice liked this post
  11. #2508
    Sep 2021
    USA
    Thanks. Come to think of it I did weld a horn on my anvil. Its made from some kind of high carbon steel or alloy because its hardened steel. My horn hasn't cracked yet and i beat on it pretty hard. I didn't quench it though. I didn't preheat it with a torch but it was still pretty hot from cutting the bevel when i welded it. I cut a bevel on the horn so i would get full penetration
    Lincoln Pro MIG 180
    Harris oxy fuel
  12. #2509
    Fredericksburg, VA
    Which part of my advice will not work for you?
    Finding a local blacksmith?
    Taking a class?
    Looking at the ABANA website for a local guild?
    In person instruction?
    Spending the money for instruction?
    Millermatic 252 MIG
  13. Likes VaughnT liked this post
  14. #2510
    Sep 2021
    USA
    Taking a class?
    How many people come here to learn things about welding? Would you tell them to go to welding school? Its just a hobby. I appreciate your suggestion but like i said it wont work for me.
    Lincoln Pro MIG 180
    Harris oxy fuel
  15. #2511
    Invest in a quality grinder. My first Metabo is over 35 years old and still going.
    Since then I added 4 more METABO'S including a variable speed compact die grinder.
    Get a variable speed one and you'll extend the life of wire wheels. The slower speed makes a huge difference.
  16. Likes Need Advice liked this post
  17. #2512
    Fredericksburg, VA
    I am a hobby welder as well.
    The advice I gave you to help with blacksmithing is exactly the advice I used in my welding and the example I posted about my TIG welding. I tried it on my own with terrible results. I found a local welder and welding shop and visited them. I showed him what I did and the settings I was using. I paid him a nominal amount and he showed me how to improve my technique. A couple of years later I was fortunate on that my regular job paid for me to go to a one week TIG welding school.
    Good luck with your future endeavors. I will not give you any more advice.
    Millermatic 252 MIG
  18. Likes Shootr, Lis2323, VaughnT liked this post
  19. #2513
    Arizona
    One of the best $50 I spent was an ad on craigslist for a private welding lesson. Dude came by on his way home from work, spent a couple hours talking, showing me how to set up my equipment, straightened out my bad habits, etc.
    I'm still looking for a 'smith willing to either come here or go to their forge for the same.
    Yeswelder MIG-205DS
  20. Likes VaughnT liked this post
  21. #2514
    Arizona
    There are plenty of analogies that come to mind as to how an investment in basic assistance from an experienced individual saves time, let alone saves your love for a hobby...
    Golf lessons - It's impossible to learn to swing a club watching videos, but a local club pro, for $50, will put you on a path to better results in about 30 minutes.
    Photography - Everyone takes pictures, but an hour with a serious amateur, let alone a pro, provides a perspective of your current habits and abilities that may or may not be working and how to better them.
    Hands-on guidance is an investment in sanity. It is no fun beating your head against the wall because things aren't turning out as good as you want. Just look at my lumpy head sometime...the ideas, web links, and honest critiques from the people on this forum has made my hobby more enjoyable than I ever imagined it could be. And I'm an ooooold dog learning these new tricks.
    All that's being said (IMO) is you may find more, quicker satisfaction with your efforts if you take a little time to be guided by a knowledgeable person before bad habits have to be unlearned.
    Yeswelder MIG-205DS
  22. Likes psacustomcreations liked this post
  23. #2515
    Sep 2021
    USA
    I didnt say your advice was bad advice. Maybe one day i'll have a chance ton follow your advice but right now its impossible.
    Lincoln Pro MIG 180
    Harris oxy fuel
  24. #2516
    Sep 2021
    USA
    I plan on it. I plan on getting a quality 13 amp 6" grinder.
    Lincoln Pro MIG 180
    Harris oxy fuel
  25. #2517
    Sep 2021
    USA
    I agree with the advice too. That would one of the best things i could do.
    Lincoln Pro MIG 180
    Harris oxy fuel
  26. #2518
    Arizona
    First project of the weekend: cut down the stand for the anvil. Originally figured it'd be handy having it same height as the bench. Nope. Now it's much more comfy, and hopefully less tiring.
    Yeswelder MIG-205DS
  27. Likes whtbaron liked this post
  28. #2519
    Aug 2012
    AR
    Shootr,
    The "normal" recommended height for the face of an anvil is about knuckle high with your arm hanging down. That being said, some folks like their anvils a bit higher or lower, which is more comfortable.
    A good way to test the height is to get a soft board no more than 3/4" thick, pine maybe, and place it on the anvil. Get your favorite forging hammer and strike the board several times like you would when forging. Look at the hammer marks. The indentation should be the same shape as the hammer face. If there is a crescent shape mark deepest toward your body, then the hammer is striking too high and the anvil is too high and needs to be a bit lower. If the crescent mark is away from you then the hammer is striking too low, and the anvil needs to be slightly higher. When you find the "sweet" spot, then you will not have to fight it trying to keep from leaving hammer marks on your work.
    Comfort is another factor. You will soon find that if the anvil is off on height, your wrist and elbow will let you know.
  29. Likes Lis2323, Shootr, BD1 liked this post
  30. #2520
    Arizona
    Thanks! It's about wrist-high now - easier to trim more off than add some back amiright?!?
    Yeswelder MIG-205DS
  31. #2521
    Shootr,
    Great summary from shortfuse ^^^^^
    I also like to keep a small anvil “high” for those small delicate jobs.
  32. Likes Shootr liked this post
  33. #2522
    Aug 2012
    AR
    Yep!! (you "can" add some plating to give it a bit of a lift....LOL")
  34. Likes Shootr liked this post
  35. #2523
    Fredericksburg, VA
    Shootr,
    Here is an example of what short fuse is referring to.
    I did that same exercise several years ago using a piece of 1/4" plywood.
    Millermatic 252 MIG
  36. Likes Shootr, shortfuse liked this post
  37. #2524
    Sep 2021
    USA
    I'm kind of excited about that bucket of tapers idea. As soon as i get some proper tongs and some steel im going to do that. I'm going to brush up on my welding too. Repetition sounds good. I found this article on another website.
    https://www.iforgeiron.com/topic/505...or-a-beginner/
    Lincoln Pro MIG 180
    Harris oxy fuel
  38. Likes Shootr liked this post
  39. #2525
    I read that molding clay is better to strike then on wood. Besides the imprint, the clay will move the same as hot steel.
    You can do a search about this. It's really interesting how it works.
Page generated in 1,713,259,943.27968 seconds with 20 queries
