Page 87 of 91 FirstFirst ... 37778586878889 ... LastLast
Results 2,151 to 2,175 of 2256
Thread: Blacksmithing tools
  1. #2151
    May 2007
    SoCal
    Re: Blacksmithing tools
    I shaped some small pieces of flat bar to keep it more or less in one spot, then drilled some holes for a couple of eye bolts.
    That made it easy to fit two bolts and two bits of chain around the waist to hold it down.
    The last thing I will do when I get to it is to weld the eyes of the bolts shut so they don't distort over time with use.
    Job 28:1,2
    Danny
  2. #2152
    Fredericksburg, VA
    Yeah, I need to bite the bullet and splurge on some
    Trying to figure out what to make with last 2 pairs of blanks. I'm not sure what I'd use scrolling tongs for at this point. ]
    In regards to scrolling tongs, if you are frugal like I am (cheap). You can grab a set of old needle nose pliers and grind down the jaws into a set of scrolling tongs.
    You might be able to find some cheap.long reach ones at Harbor Freight or the pawn shop.
    That will help to keep your hand away from the heat.
    Miller Spectrum 625 Plasma
  3. Likes Shootr, tanglediver liked this post
  4. #2153
    Friends were garage sailing today and left this for me at my shop door....
    perfect for oiling the wheels on Shootr’s new forge!
  5. Likes Shootr, whtbaron, tanglediver liked this post
  6. #2154
    Fredericksburg, VA
    They must have blown through town.
  7. Likes Lis2323 liked this post
  8. #2155
    Aug 2013
    Shetland Islands
    [/QUOTE]
    Looks like a Russian anvil. I like it.
    Spent some time forging Bolt jaw tong blanks today
  9. #2156
    Tool maintenance is one of those things that never ends.
    This time.... I'm maintaining my home-made blacksmith apron!
    I know, sexy stuff, right?!?!
    What started life as a Tillman 48" welder's apron got a lot of improvements made by my own hand. I went into it knowing that the leather Tillman uses is sub-standard, but it was the only economical leather I could access and already came with straps attached. All I did was reinforce the stress points where the straps come in to the body and re-vamp the lower straps so they were actually more functional. Some parachute cord and brass grommets made a world of difference!
    Sadly, the leather has started doing exactly what the leather has always done. I don't know what Tillman is using, but the stuff turns hard and brittle once you've got some sweat into the material. My first Tillman apron died in a year because the stiffened leather started tearing around the stitching for the shoulder straps -- hence why I reinforced those areas. Yesterday, as I went to put it on for show-n-tell, I noted that my improved version was stiff as a board and starting to tear.
    On the lower half were no sweat reaches, the leather is just as soft and supple as when I first bought it. The top half, though, needed some revitalization.
    I tried giving it a little light scrub with some soapy water last night, but after hanging it up to dry overnight, I found it still stiff as a board this morning.
    As the old saying goes, if a little doesn't do it, double down!
    Hopefully, the "degreaser" soap isn't just good for washing dishes.
    I guess the real question is what kind of oil/dressing to put on the leather. It'll have to either fully saturate the dermis or it'll need to be applied to the inside surface to block the sweat from getting to the leather. If the latter.... will it be rubbing off onto my super-sexy Three Rivers Forge t-shirts? Will the oiled leather transmit the heat straight through like wet leather does?
  10. Likes Shootr, whtbaron liked this post
  11. #2157
    Aug 2012
    AR
    Those are nice looking tong blanks. Do you make smithing tools such as those tongs and sell them locally? Not asking to buy any, as I smith myself and make my own tongs, just curious.
  12. #2158
    Aug 2012
    AR
    Vaughn, I would suggest you wash or clean your leather with saddle soap, then after it dries rub some boot leather treatment in the areas that tend to stiffen. That often helps keep the leather soft. Also, there are several kinds of boot leather treatments ranging from a silicone-based to oil types. You might give them a try, starting with the lightest like the silicones, then if they don't work, go to heavier stuff like the oils.
    Some of the cheaper, thin leathers will also stiffen with heat. I have one like yours and it does get stiff in a few places. No way I can afford one of the $150-$200 aprons! Besides, the thicker, high quality aprons tend to be too hot to wear, so I like the thin, cheap kinds! LOL
  13. Likes VaughnT, whtbaron liked this post
  14. #2159
    I'm in the same boat. Paid a small fortune for a custom-made apron and the guy made it so thick and heavy that you don't want to wear it in the shop. Plus, it's just so pretty you really don't want to get it dirty!
    I'm thinking about driving down to Tractor Supply to see what they have on hand. I'd like to get the apron done today so it can hang up to dry overnight.
    Over the next few months, I'll have to research more into oil-tanned leathers to see what I can pick up that's light and flexible like the Tillman is. Nobody needs a thick leather apron in the blacksmith's shop, but they do need something that's durable and will last. I think the suede that Tillman uses is actually causing a lot of problems because the fluff tends to wick the sweat and grime deep into the leather rather than repelling it.
    A good apron should last a lifetime, not need to be replaced every year or so.
  15. Likes Shootr liked this post
  16. #2160
    Arizona
    I don't have much that is leather (mostly canvas) but what I do have I use baseball glove conditioner on it.
    Yeswelder MIG-205DS
  17. #2161
    Aug 2012
    AR
    Over the next few months, I'll have to research more into oil-tanned leathers to see what I can pick up that's light and flexible like the Tillman is.... I think the suede that Tillman uses is actually causing a lot of problems because the fluff tends to wick the sweat and grime deep into the leather rather than repelling it.
    I agree with you on the probable wicking by the suede wicking. As for checking on other leathers, I don't know where you live, but some larger cities have a leather goods/leather hobby workers stores that will sell full or part skins, Tandy is one of them I believe (or at least they used to sell skins). You could cut out your own custom fitted apron. Entrynet orders for leather is iffy since you can't feel or see the actual leather.
  18. #2162
    Arizona
    Back from a nice long weekend to celebrate our anniversary - before I left I painted the forge frame white with high-temp spray paint. Today I put a blindfold on and laid out a bunch of pinstripe masking tape to "add interest". Then shot it with black high temp paint.
    Doggo is unimpressed, but what the heck - I always wanted to try it. Next up is plumbing, then the insulation, and should be finished.
    Yeswelder MIG-205DS
  19. Likes psacustomcreations, VaughnT, whtbaron liked this post
  20. #2163
    LOL... a guy bet me I couldn't paint a fender blindfolded once when I was doing it full time... he lost the bet. Can't say I ever saw anyone deliberately mask a pattern blindfolded before though.... cool idea.
    Cut 50 Plasma
  21. Likes Shootr liked this post
  22. #2164
    Apparently what you might need is a bunch of mink... or fake mink oil from pigs ( I had no idea I had such a precious resource when I had a barn full of pigs). Canola oil or olive oil might be the easy place to start, but they have draw backs as well. https://www.libertyleathergoods.com/leather-oil/
    Here's some home made recipes you might find interesting... https://www.bobvila.com/articles/hom...r-conditioner/
    Cut 50 Plasma
  23. Likes VaughnT liked this post
  24. #2165
    Feb 2019
    Snyder TX
    Pure neatsfoot oil from Amazon. Cowboys use it on saddles & tack.
    https://www.amazon.com/Fiebings-Neat.../dp/B000HHLX98
  25. #2166
    I always used a can of mink oil to rub on the leather baseball gloves.
  26. #2167
    Fake mink oil, -60 degree weather in a can.....looks like you have all the natural resources in Manitoba. Just need a good marketing guy. LOL
  27. Likes whtbaron liked this post
  28. #2168
    Ended up buying a jar of.....
    It didn't do diddly for the truly hardened parts of the leather bib, but the parts that were still relatively soft are now relatively soft and oily feeling. I also noted that it didn't penetrate all the way through the leather. While I put on gobs, the chrome-tanned middle portion of the dermis seems to act like a barrier. The only option is to put cream on both sides and melt it in with a heat gun.
    The good news is that I'm talking with a rep at Springfield Leather to see about getting some good hide.
    It's a bit aggravating, honestly. While I knew that the Tillman wasn't the best leather you could ask for, all the work I put in to reinforcing the weak points amounted to nothing. The leather it literally tearing right beside the reinforcement patches that I spent all that time sewing on. Now I'm going to have to start all over again.
  29. #2169
    Well, the rep at the leather company isn't being much help.
    He's "made quite a few aprons for blacksmiths, farriers and barbers" and then starts to tell me all about how I need a leather that's exactly the opposite of what I said I loved about the Tillman. There's a big difference between making an apron and having to wear that apron for hours at a time, being slow-roasted by the blasted thing because it's heavy and hotter than the forge itself.
    In all the years I've been using the Tillman aprons, there's never been a single instance where something has penetrated it -- including exploding cut-off disks. No matter what anyone tells you, you simply do not need an apron that's thicker than the Tillman if you're going to be working in a smithy. Yea, sure, you'll have to go a little thicker just because the grain of the hide is still on (compared to the Tillman's cheap suede), but that doesn't mean you need to jump up to some Rhinoceros skin.
    Yokel's going to tell me I need to up my game to a thicker hide like I don't know exactly what I have to deal with when I'm in the shop! So aggravating!!
  30. #2170
    hmmm.... might have to grow thicker skin. I wonder what baby oil would do? Guys used to use it to protect vinyl dashes from UV.
    Cut 50 Plasma
    Arizona
    I wonder if other trades, like a shoe repair shop or saddle maker or something. Someone who works with leather but may also branch out to customer requests. Even if they can't do up an apron, maybe they know enough about leather to help you find what you need.
    We have a Tandy leather here - it is pretty cool to be able to touch and feel the different types and thicknesses of the hides.
    Yeswelder MIG-205DS
  32. #2172
    Arizona
    Some of it reminds me of damascus patterns...Could be better, could be worse
    Yeswelder MIG-205DS
  33. Likes whtbaron liked this post
  34. #2173
    Arizona
    I cut and completed the chamber today. The bottom has a layer of the ceramic board with fire bricks on top. The rear has firebricks, but used the board on the inside. The roof and sides are just the board (all 1/2" thick).
    I made a sliding panel with the last bit of the board to close off the opening. Not sure how to cut it to make it the most useful in different configurations. The dotted lines is what I'm leaning towards - if I slide the big panel to the left slightly, and the little one to the right, I'd have a nice 3" x 3" (or whatever a good size would be) opening. If I need larger, just slide the panels apart further.
    Yeswelder MIG-205DS
  35. Likes psacustomcreations, whtbaron, VaughnT liked this post
  36. #2174
    That forge is coming along great, Shootr.
    You do need to have an opening of some sort so the pressurized air can escape. I always recommend a rear-facing opening so the dragon's breath coming out the front isn't so bad. Nothing worse than reaching for your work through a foot or more of super-heated flames jetting out!
  37. Likes Shootr liked this post
  38. #2175
    Aug 2012
    AR
    Looooooong tongs!!
    The forge is taking on the aura of a work of art! Shootr, you may not want to forge with it and keep it clean, LOL
  39. Likes Shootr, whtbaron liked this post
Page generated in 1,618,235,290.82316 seconds with 15 queries
