Page 2 of 5 FirstFirst 1234 ... LastLast
Results 26 to 50 of 103
Thread: Building A Tig Water Cooler For Dummies!!!
    Jul 2013
    La Porte, TX
    Re: Building A Tig Water Cooler For Dummies!!!
    Gravel
    The difference between theory and practice is that in theory there is no difference.
    Utah
    I found my some stainless bungs on Amazon, but I have some local places (hardware stores, but not big box) that have them too.
    Dec 2011
    Can someone tell me what size/kind of fittings a Procon pump uses?
    No but the shurflo pumps are 3/8" npt.
    The B size LH thread adapters from Western are here:
    http://www.brwtechnologies.com/mobil...ductCode=A-405
    Home depot sells 1/4" to 3/8" adapters
  5. #30
    I have not figured out what sort of panel mount hose fittings will work though. I would like to oversize them to avoid any added circuit resistance.
  6. #31
    Utah
    That was the hardest part for me.
  7. #32
    MikeGyver has some snazzy quick releases on his; I will dig back through the aluminum cart thread.
  8. #33
    Laredo + Midland/Odessa
    Quote Originally Posted by atg View Post
    I used quick-release fittings from HTP---work great on the HTP Arctic chill cooler. I have the old fittings saved in a plastic baggie if anybody needs fittings
  9. #34
    Mount Tabor VT
    Quote Originally Posted by Gravel View Post
    I like the idea. Keep in mind that yhe tank doesn't have to be big. 1 cubic foot holds 8.34 gallons if I remember correctly. The Miller ones I have looked at hold between 1 and 3.5 gallons.
    Looking forward to lots of good reference material here when I get ready to build one.
    231 Cubic inches per US gallon. A cubic foot is 1728 Cu In 1728/231= 7.48051948051 Gallons Any rectangular tank is in inches L x W x H /231= gallons. Cylinders is Radius x Radius x 3.1416 x length/231= Gallons.
    The one recommended for my Dynasty 280 DX is 1.3 gallons.
    The coolant used sells for $30 per gallon. Don't go with a huge tank.
    For a while I used sink water. My flow rate was about 3 gallons per hour. It worked fine. That's what Zapster's machine uses all the time.
  10. #35
    Jul 2013
    La Porte, TX
    Yeah, for some reason I keep swapping gallons/sq ft and pounds/gallon...
    Gravel
  11. #36
    Dec 2011
    Got the tank built today. Went 8" X 8" 11 ga. stainless. Worked out OK. I started walking the cup using 4043 1/16" filler rod..........switched to freehand.........ended up just freehand and fusing the corners. Using open corners this worked out well.
    The first pic shows all sides (except for the top) tacked on the inside this allowed me to fold up all the sides making things pretty accurate.
    The 3/8" bungs are actually a cast stainless pipe coupling cut in half.......worked out real cheap. The cap is a 3/4" nut and bolt.
    I am leak testing it overnight.
  12. #37
    Jul 2013
    La Porte, TX
    Nice job! Sorry I haven't been able to talk. You can call me any time this weekend.
    Gravel
  13. #38
    Feb 2009
    Chicago
    Looking good....**** if I can get some stainless sheet I may tackle this one too just for fun.
    Hypertherm Powermax45
    Esab ET220i
    Razorweld 195 Mig
    Razorweld 200ac/dc Tig
    Tormach 770, Tormach xstech
    Carbide3d Nomad3
    Sherline 4400 CNC Lathe
  14. #39
    Jul 2011
    Looks great RTL
    TA Arcmaster 300
    CM3
    XMT 304
    S22P12 suitcase feeder
    X-Treme 12VS
    Optima pulser
    TA161S
    Maxstar 150STL
    Hypertherm PM45
    OP setup
    Stihl 020AVP, 039, 066 Magnum
  15. #40
    Jun 2013
    Northwest Arkansas
    Quote Originally Posted by rahtreelimbs View Post
    4043 filler? Typo, or welding genius?
  16. #41
    Sep 2014
    In the 209
    It's the non-ferrous stainless filler rod. You've never heard of it?
    OP, sweet project
    Teach Ag Mech - Mike
    At Home:
    Lincoln Electric AC225
    Miller Challenger 172
    Gas Axe
    Work:
    eclectic bunch of 90's vintage blue boxes
  17. #42
    Dec 2011
    Quote Originally Posted by dcoffmanjr View Post
    Had aluminum on the brain. ....meant to say 308 stainless.
  18. #43
    May 2006
    Northern California
    I have two coolers. One is a Bernard 2500 that I rebuilt. It has a radiator and a 6" electric muffin fan since the new Procon drive motor had only one shaft. The original motor had a fan with a dual shaft motor but it wore out so I just used the single shaft motor with a fan. It works great.
    My other one is home-built with ah 1/8" Wall SS tank. I made it too large (15 gallon) but I never run more than 5 gallons in it. It's also got a Procon pump and motor. There is no radiator and it has never needed one. You could weld all day with my Syncrowave 200 and ithe coolant would never even get warm. If I were to build another one, I'd make it no larger than about 5 gallons. That's all that you really need.
    I formerly used Miller Coolant but gave up due to the cost. Nowadays, I use distilled water with a quart of GM Dex Cool. I've yet to have a problem. There are pressure gauges on each unit and they run 50-60 psi. That seems to be OK since I've yet to overheat a torch in more than 15 years.
    I built the carts out of bed frames. The picture was when I was testing both units. I alternate them now and change them from time to time.
    Miller Millermatic 252
    Miller Syncrowave 200
    Bernard Cooler
    Lincoln AC-DC 225
    Victor O-A Set
    High Hopes.
  19. #44
    Plano Texas
    Nice. I like the small footprint.
    Very small foot print. It fits underneath the welder on the portable cart.
    Some of the ones I see above, you'd need a separate cart to haul them around.
  20. #45
    Dec 2011
    This is where I am at now. I have the the shroud mount built and the base as well as the tank. All I need now is the pump and motor.
    I am mounting this on a separate cart......this is the reason for the dinse and gas line connection on the front of the panel.
    I guess my aluminum welding is getting there.
  21. #46
    Mar 2013
    So Cal
    I ran my machine for years on a total loss system.... I rigged a regulated water source, connected to the machine and out to the flower beds. I ran the water pressure at a point where discharge water was slightly warm when welding at a high setting.
    It worked fine and had zero issues.
  22. #47
    Mar 2013
    So Cal
    Looks like a cool setup for a converting an small aircooled rig to liquid.
  23. #48
    Nov 2012
    charlotte, nc
    Lets say you have the sheet metal to make the liquid tank but have to buy everything else.
    How much time and $$$ is spent making your own?
    there are chineesse tig water coolers on ebay for $375, they are the same ones that everylast and longevity sell.
    Help me determine what savings if any are achieved by DIY?
  24. #49
    Jan 2010
    You might want to move that fan out to were the blades are even with the shroud. The blade location were its at now; will make noise and chop air but not really move a lot of air. You could remake the bracket and flip the fan over so that the blades are level with the shroud since the direction of air flow make no difference.
  25. #50
    Dec 2011
    Quote Originally Posted by gmakra View Post
    Thanx!!!
Page generated in 1,713,294,965.76914 seconds with 18 queries
