Page 5 of 5 FirstFirst ... 345
Results 101 to 103 of 103
Thread: Building A Tig Water Cooler For Dummies!!!
  1. #101
    Feb 2016
    Re: Building A Tig Water Cooler For Dummies!!!
    Tested my home built cooler last night.
    My goals were:
    1. Fit in bottom of welder cart
    2. Inexpensive, but reliable
    3. Quick to build
    4. Easy to remove from cart and switch between air and multiple liquid cooled torches.
    I used a carbonator pump and tank and basically just re-plumbed it so the carbonator tank functions as a reservoir and added a filter and bypass valve with pressure gauge. I used carpet cleaning quick disconnects that I found on Ebay. I started to add a filler cap to the tank but just used the pump to fill the res with 2 gal of coolant. Since it only has one very small opening to atmosphere I don't expect to lose volume very quickly. I don't usually weld for long periods so I decided to try it without a heat exchanger and see it there is enough thermal mass in 2 gal of coolant to get the job done for me. After about 30 min of welding aluminum at 150amps last night the coolant tank rose about 4 degF. I think it will probably work unless I end up doing a large aluminum project on a hot summer day.
  2. #102
    Jun 2020
    I appreciate this is an old post, but my god @code4 this is stunning! next level.
    it’s inspired me that’s for sure, I would love to see any build pics?
    Quote Originally Posted by CODE4 View Post
    I built my own cart using a standard Procon pump, Marathon electric 1/3 HP AC motor, and stainless 1/2" tubing and fittings. The reservoir is a piece of 6" sanitary tubing that holds about 2 gallons. I have a temperature gauge and pressure gauge on the system as seen in the pictures. Currently no heat exchanger, and with the moderate welding I do at the house, I have not had a need for one yet. I may plumb a transmission/oil bar & plate cooler in line in the future if needed.
  3. #103
    Sep 2018
    Boyne city, Michigan
    Code 4
    That looks like total aircraft quality workmanship, job well done!
Page generated in 1,713,287,164.61594 seconds with 19 queries
