I bought a 145 amp wire feed Century from Sam's 12 years ago for $550. I was skeptical of the quality but talked to my local shop first and they said it was fine for home use. 12 years later it still runs great. I use flux core and air shielding and they both work just fine, no problems what so ever. Last week I had the need to weld aluminum. I bought the teflon liner, rubber roller wheel, a 20 cu ft argon tank and a 1 pound spool of wire. Everyone told me that it would wad up and would not work. Well i set the roller wheel to real light, just tight enough to push the wire. I also kept the 10 foot cable real straight to avoid excessive bends. It welded like a champ. Not a single bird nest, smooth feed and great looking welds. The biggest thing I found was the AL needs to be spotlessly clean before welding. Even a little bit of oxidation or debris will mess up the weld. For small jobs I would have no problem saying "go for it". No spool gun needed on small jobs. For the money and around the shop use this welder has been just great.
