Page 2 of 2 FirstFirst 12
Results 26 to 30 of 30
Thread: Not just another welding table-cart.
    Jul 2014
    Bulldog Heaven at the end of my chain
    Re: Not just another welding table-cart.
    Quote Originally Posted by GunGeek View Post
    I looked at some. Is 200-300 a standard price on those? Do you have anywhere that has them a bit cheaper.
    If you have to purchase new, I suppose. Ebay seemingly always has them used. You only need a single valve unless wanting to extend the legs individually. A single valve will allow all four legs to extend equally.
    Slob
    Purveyor of intimate unparalleled knowledge of nothing about everything.
    Oh yeah, also an unabashed internet "Troll" too.....
    I would want each leg to be able to move independently to get a true level. So a valve would be needed for each leg. I could aways open all of them. I am thinking I want power up and down instead of springs nut then that gets a little complex.
    Jul 2014
    What you would need for ease of operation is a pumping unit with four four way blocked center or return to tank solenoid valves. This will give total and independent operation to each of the four legs for leveling purposes. Four toggle switches incorporated to operate each leg separately would be the easiest and least expensive way to go.
    Slob
    May 2012
    Ontario, Canada
    If it's for use on the farm, I would want more ground clearance.
    I would think the first time you tow it over the grass / field / down a rutted lane you bottom out.
  5. #30
    Quote Originally Posted by 12345678910 View Post
    11, 12?
Page generated in 1,713,306,293.72617 seconds with 18 queries
