Results 1 to 4 of 4
Thread: New to this forum looking to fix my lotos plasma cutter.
    Sep 2014
    I learned iron work at high school... I am a person prone to repair anything, and work on anything. I am an M.D. surgeon, acupuncturist and researcher on cancer and AIDS using electro-therapy on my patients, plus ozone, diet and several other ways to cure and control those diseases. In my spare time I like to fix cars, build swimming pools, repair and sell PC's and weld Mig Arc and cut metal. Since my using of a metal plasma cutter (I though) was limited to sporadic use I bought a Lotos plasma cutter... What deception, after a few metal cuts, this machine caught fire and found a short from the cable feeding the machine to the coil that sends the voltage for cutting... result I have a 400 machine unusable... and I am planning to fix it testing every component...
    Piedmont, SD
    Re: New to this forum looking to fix my lotos plasma cutter.
    Cut your losses next time around and purchase a quality machine. If the price of a name brand plasma cutter is too high for infrequent usage, try going with a good quality Oxy/Acet outfit or nibbler/shear. It isn't that Asian sourced plasma cutters and welders are so low quality as it is the importers are only looking at price at the expense of quality.
    Lincoln PrecisionTig 275
    Miller 251
    Miller DialArc 250
    Bridgeport mill
    Hossfeld bender & dies
    Logan shaper
    Jet 14 X 40 lathe
    South Bend 9" 'C'
    Hypertherm 900
    Ellis 3000 band saw
    21"Royersford Excelsior
    Two shops, still too many tools.
    Dec 2003
    Fairfield,CT
    Welcome Dr.
    www.tjsperformance.com
    Dynasty 300 DX
    HTP 240
    HTP Microcut 380
    Hyperthem 85
    Bpt. Mill/DRO
    4' x 8' CNC Plasma Table
    Instagram: tjsperformance
    Jan 2011
    Coronado. CA across the bay from San Diego, CA
    Welcome Aboard, glad to have you with us.
    Seconding the advice of WyoRoy, cheap tools are often the most expensive to use and maintain.
    I offer three choices: Good, Fast, & Cheap. You may pick two.
    Hobart AC/DC StikMate LX
    Harbor Freight AD Hood
    Harbor Freight Industrial Chop Saw
    DeVilbis 20 Gallon, 5 HP Compressor
Page generated in 1,713,306,552.79288 seconds with 18 queries
