Page 2 of 84 FirstFirst 12341252 ... LastLast
Results 26 to 50 of 2076
Thread: Blacksmithing and forging
    Feb 2008
    North of Philly
    Re: Blacksmithing and forging
    I'll add the link to Steve's forge station.
    http://weldingweb.com/vbb/showthread.php...ar-Attachments
    Ronald Reagan
    Feb 2008
    North of Philly
    Ronald Reagan
    Feb 2008
    North of Philly
    Wroughtn_harv's propane forge build.
    http://weldingweb.com/vbb/showthread.php...-propane-forge
    Ronald Reagan
    Feb 2008
    North of Philly
    I'll add the link to my latest small blacksmithing projects.
    http://weldingweb.com/vbb/showthread.php...little-forgery
    Ronald Reagan
  5. #30
    Mar 2014
    Laurel, Mont, USA
    I do a lot of blacksmithing with my iron art work. I was commissioned to make these shelf brackets.
    The main straps are 1 1/2 x 1/4 and the support curves are 1 x 1/4. The main straps are 14 inches long on each leg. I forge broke the edges and forged the curve for each. I drilled the holes, no points for punching the holes. I blind plug welded the rivets and then hot textured them.
    The whole works was hot waxed and then burnished with a rag.
Size:  58.3 KBName:  20150628_132539.jpg
Size:  60.0 KBName:  20150628_132546.jpg
Size:  41.8 KBName:  20150628_132604.jpg
Size:  49.4 KBName:  20150628_132611.jpg
  6. #31
    Jan 2008
    Lansing, MI
    Nice!
  7. #32
    Dec 2012
    Claflin, KS
    Been lurking on this sticky since it started, anyways came across 2 Kirby vacuum blowers for sale would like to pass them on if anyone's interested or if they are of value I may just pick them up any info or interest is appreciated.
  8. #33
    Feb 2008
    North of Philly
    Ronald Reagan
  9. #34
    Missed that one when I was searching old anvil links... some interesting tools and hold downs. Thanks for the link.
    Feb 2008
    North of Philly
    Feel free anyone to post links to any other smithing related threads I may have missed. I don't have to be the only one to add links to this thread. I'm sure there are a ton of other ones, either smithing projects you or others have done, or anvil/blacksmithing tool related threads on here I haven't dug up yet. Every so often I stumble upon another one and try to add it. I'd like to make this as comprehensive as possible since the search function on this site sucks big time.
    Ronald Reagan
  11. #36
    Jan 2013
    ...Shoulder of Orion...
    Impressive double-wide Railroad Rail Anvil. Nice welding pointers and descriptions from the fabricator.
    Part 1 (of 4)....
  12. #37
    Feb 2008
    North of Philly
    This thread on roses/flowers should probably be added to this list.
    http://weldingweb.com/vbb/showthread.php...ose&highlight=
    Ronald Reagan
  13. #38
    Feb 2008
    North of Philly
    rahtreelimbs railroad track anvil thread.
    http://weldingweb.com/vbb/showthread.php...-Finally-Done-!!!
    Ronald Reagan
  14. #39
    May 2007
    SoCal
    How DO they put faces on anvils?
    Here's one example.
    Job 28:1,2
    Danny
  16. #41
    Feb 2008
    North of Philly
    I'll add the link to the thread I just started on forged bottle openers.
    http://weldingweb.com/vbb/showthread.php...bottle-openers
    Ronald Reagan
  17. #42
    Feb 2008
    North of Philly
    Norin_rad's forged grilling fork and chipping hammer.
    http://weldingweb.com/vbb/showthread.php...hipping-Hammer
    Ronald Reagan
  18. #43
    Jul 2011
    here's my first "for regular use" forging project. but in reality most was welded. only the "dogs" were forged. For having 0 real training I'd say it didn't turn out to bad. Just needs to be functional right?
    24" Deep x 36" wide. Final height is yet to be determined, as the fire place it is going into doesn't exactly have a level floor. Made with 3/8"x2" flat stock.
    There are no problems. There are only solutions. It's your duty to determine the right one.
    Hobart Handler 210
    Airco 225 Amp MSM Stinger
  19. #44
    May 2007
    SoCal
    Happy Anniversary to the thread!
    So, we can scratch tungsten-carbide off the materials list...
    Job 28:1,2
    Danny
  20. #45
    Interesting... my first approach would have been to reshape the grinding tip on the grinder. Apparently breathing any grinding dust from that process would not be a good thing.
    Jan 2013
    DIY Propane Forge, powered via a Hybrid JetBurner Torch. The tech literature on the T-Rex style Mach burners looks very hot.
  22. #47
    Here's the Peter Wright anvil I acquired this summer. Finally got around to finding a block of oak to mount it. The stump is tapered on the bottom so that I can pick it up with my forks.
    The rivets in the band are just for decor.
  23. #48
    Lis2323, nice ! I like the taper to use that mechanical stuff to lift where you only need one finger to move it,
    Great hold down setup too !
  24. #49
    Aug 2012
    AR
    Great looking anvil...looks to be in fine shape. You'll really enjoy using it.
  25. #50
Page generated in 1,713,297,182.86136 seconds with 19 queries
