Page 2 of 2 FirstFirst 12
Results 26 to 43 of 43
Thread: Squaring a trailer frame - having problems
    Aug 2008
    Re: Squaring a trailer frame - having problems
    Mixing concrete, and setting gateposts. Time for a break says me
    On the subject of squares vs. diagonal measurements vs. other means.
    A square will give you a very false reading if the steel isn't absolutely straight......from end to end, and everywhere in between. Just think how much an 1/8" bow in the center of your main rail would throw the square off. You'd be squaring in the corner, but squaring to the actual bow in the steel. Corners aren't reliable when dealing with long members.
    345 method is pretty much the same, it relies on a measurement over a small area in one corner. If the steel's not absolutely straight, you got error.
    The diagonal isn't perfect, but because you're measuring over a larger area, you're also compensating for some of the small errors in straightness of the steel. It sort of averages the thing out so to speak. It has some serious limits too.....if the distance is way too long it will show error in the droop of the tape etc. But all droops being about equal on the two measurements, you're still real close to what you want. If you're dealing with a long build it can be easier to mark off a small area in equal lengths (L & W) either square or rectangular, then square the smaller area using the diagonals.
    It's sort of a best effort thing. You try to get the most accurate representation you can get.
    But I go at most things sorta *** backwards anyhow
    http://www.farmersamm.com/
    Aug 2008
    Bit of cherry pie, some tea, and the concrete mixer is fueled up and ready to go again
    Sebeka and Bemidji MN
    Quote Originally Posted by Bistineau View Post
    If the corner to corner measurements are 136 3/4" each way, then what's the problem? It's as square as it needs to be. Not really gonna get any closer. So yes, Shoot the engineer and get on with production. While your at it, tell the perfectionist in you to go take a break and while you move forward with the build or your gonna do him like the engineer.
    Excellent advice for many builds whether in steel, wood, concrete, etc.....
    Syncro 350
    Jun 2010
    Water level base. Steel may be warped from tacking or cutting. Lay a full sheet of plywood on top for a square if you still don't find a happy medium.
  5. #30
    Why would you use a water level on a 5 x10 trailer frame? 24x24 I can see it. Just get something thats12 feet long and straight and level off it. Its a trailer not a paper machine base after all.
  6. #31
    May 2010
    Port Orchard, WA.
    Everybody uses a total station to build trailer.
    Donít pay any attention to me
    Iím just a hobbyist!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
  7. #32
    Northern Cal., Shasta County
    I measure other people's trailers all the time checking for square. Nothing worse than a frame that's off by a couple thou..
  8. #33
    Jun 2010
    I mentioned water level because he said he was on a slanted driveway. So I would start with a perfectly flat starting point. Then I mentioned the plywood as a cheap huge square.
  9. #34
    Jul 2011
    Bossier Parish La.
    Quote Originally Posted by blackbart View Post
    It really doesn't matter if it is level or not, like Farmersamm pointed out, as long as it is flat it's good. Being level will not do anything to help with getting it square. Likewise it could be built on the most level surface you could ever hope for, and still be out of square. It could be built totally vertical and still be made square, so level has nothing to do with it. Once built, the trailer will most likely be out of level for most of it's existence from then on. But if correctly designed and built, it should still remain FLAT.
    He says it measures out at 136 12/16", so that tells me he has it square enough. Unlike Sandy above ^^, most of the population don't check trailers for PERFECT SQUARENESS. If it's square enough, then it's square enough to perform it's intended function. It could be made in an octagon shape with none of the 8 sides being the same length, and as long as the distance from the coupler to the axle on each end is the same, then the trailer should still track straight behind the tow vehicle.
  10. #35
    I guess he should scrap it and make the next one round.
  11. #36
    Jul 2011
    Bossier Parish La.
    Yeah, but then he would be more concerned with trying to make it PERFECTLY CIRCULAR . Probably tougher to do than square.
  12. #37
    Jul 2014
    I know the only thing I can make round is my waist line and even it is a little oblong !
  13. #38
    Jun 2010
    Bisteneau is correct, being flat is more important than level. Just don't use a level on any other part of the layout. Sometimes it's easier to work from a level base but not needed.
  14. #39
    Syncro 350
  15. #40
    Jul 2013
    La Porte, TX
    Isn't that cubed?
    Gravel
    The difference between theory and practice is that in theory there is no difference.
  16. #41
    Quote Originally Posted by Gravel View Post
    Isn't that cubed?
    Cubed and then squared is a sixth power....I can't weld that
    Syncro 350
  17. #42
    Jul 2013
    La Porte, TX
    Rookie!
    Gravel
  18. #43
    Rookie!
    After the 4th dimension, my ground gets tied in knots...
    Syncro 350
Page generated in 1,632,255,587.69502 seconds with 12 queries
