Results 1 to 19 of 19
Thread: Opinions on Mag Drills
    Ok, my ancient Milwaukee mag drill died a horrible heavy equipment related death a while back and I have a job coming up where Im going to need a new one. Up to 1.25" holes in 1.5" plate. Annular cutters and coolant will be a must. So... what are your recommendations? I know theres some nice ones out there.
    Jul 2013
    La Porte, TX
    Re: Opinions on Mag Drills
    My only experience is with Milwaukee and I haven't had any issues. Even with the beat up one I bought used.
    Gravel
    The difference between theory and practice is that in theory there is no difference.
    Jul 2014
    Bulldog Heaven at the end of my chain
    With the experience through the years I've had with Hougen, I'll never have anything but another Hougen.
    Slob
    Purveyor of intimate unparalleled knowledge of nothing about everything.
    Oh yeah, also an unabashed internet "Troll" too.....
    What's your budget, how much use? There's a lot of variables. Is weight much of a factor, maximum hole size?
    Sep 2014
    We have jancy slugger brand mag drills that i find are the best. We also have Milwaukee that do a good job but i dont like them as much. We also have right angle mag drills that make it much more compact if you need to get into tight spaces.
    Apr 2008
    NW ON Canada
    Hougen gets my vote. I used a Hougen yesterday, drilling 7/8" holes in 3/4" a36 plate.
    Jason
    Thermal Dynamics Cutmaster 52
    Miller Bobcat 250
    Torchmate CNC table
    Thermal Arc Hefty 2
    Ironworkers Local 720
    Tennessee
    I would say Hougen, Jancy or Milwaukee, you can't go wrong. I heard Milwaukee is the best built, but that's one guy's opinion. I just bought a Hougen from Ohio Power tool.
    "Stick-man"
    Nov 2007
    Pittsburgh Pennsylvania
    I have used Jancy, Milwaukee, and Hougen. I prefer the Hougens.
    Ya gotta spend money to make money!
    I'ved used the hougen and the milwaukee at work. definitely would take the hougen any day...easier to deal w/ than the milwaukee and bits cut better in my experience(a lot better). had to drill a railroad tie a while back and the hougen went right through....milwaukee wouldn't ever bite. think i broke 2 bits trying w/ it. and it definitely wasn't worn out b/c everyone always chose the hougen first out of the two if they needed a mag drill for anything. milwaukee is also just way to big imho. talk about pain in the *** when you have drill horizontal. the spring back on the hougen is nice too. hated having to always lock the head on the milwaukee after you raised it up. also, I might not remember correctly but hougen has safety feature where the drill won't run if it detects magnet isn't bonded well. milwaukee has the safety light but i believe you can still run the drill even if it isn't bonded well to the surface. only thing that was kind of annoying w/ the hougen was having the lubricant bottle hooked up to. just made a giant mess all the time.
    believe the hougen was the hmd904
    Nov 2012
    charlotte, nc
    Just got a evolution 42 mag drill to drill holes in a welding table
    I can do about 40 to 45 holes per hour that are 5/8 (16mm) in size
    Seems to work well, but I really wish the retraction was spring loaded like most drill presses.
    For some reason I though it would be variable speed, but it is just one speed.
    I'm using the evolution annual cutters as well.
    I have not used other mag drills. For $700 I was expecting a little more.
    $700 on amazon
    Jul 2014
    Quote Originally Posted by AluminumWelder View Post
    $700 on amazon
    FYI:
    Don't let "Evolution" cutters run hot as in cut dry. Keep them lubed with something. I purchased a set of them from 7/16-1-1/4 in 2" depth and they shatter very easily if run for seemingly seconds if the coolant flow stops.
    I yakked at the vendor for about 15 minutes before sending the set back for a refund. They were replaced with Jancy "Sluggers" in the same size and zero problems including a couple of resharpenings.
    Slob
    Jan 2012
    On Tour
    Hougen is a great set of machines, the coolant feed systems are crap, but the drills are amazing. Just get a case of spray coolant.
    Hougen annular cutters on milwaukee's seem like a good compromise, but the Milwaukee has too much end play causing early failure of annular cutters. Any chatter whatsoever is going to destroy a cutter in seconds.
    Constant Current Weldor.
    Aug 2006
    St. Paul Park MN
    The Magtron I have is big and heavy but I sure like the high and low speed + variable speed.
    Feb 2013
    Otley, Iowa
    Quote Originally Posted by Davidbrown View Post
    I just got a pretty good deal $420 for a used Hougen 10914. Was wondering about the coolant setup. Anybody actually use it and like it?
    Esab Caddy Mig C200i
    Thermal Arc 186
    HTP Microcut 625
    Jul 2014
    I've had two Hougen's; a 904, and an HMD 505. Never used coolant with the 904 but just a squeeze bottle of oil. I have gravity feed for the 505 and really like it and it's never given problems. I don't use Hougen's or anyone elses water based emulsion coolant/lubricant but stick with machine tool lubricant and this is based upon seeing others run water based products and rust being present.
    Slob
    Jan 2012
    Colorado
    I have the Milwaukee 4270-20. Scored on Craigslist for 400 bucks. Don't have any complaints.
    14' PowerMig 210 MP
    13'Burntables 5x10 CNC Table
    14' SAE300 HE on a 12' Ram 4500 60 CA 4x4. Custom bed/bottles/reels.
    87' SA250d, 78 SA200,11' Ranger 250 GXT AC/DC
    Thermal Dynamics Cutmaster 81
    12' Lincoln Precision Tig 225
    08' LN25
    Sep 2014
    It uses a rare earth magnet to hang by.
    http://www.amazon.com/Metabo-MAG-28-.../dp/B007NVUT1E
    Sincerely,
    William McCormick
    Sep 2014
    I saw it in a tool supply in Brooklyn the other day, we all thought it was an electromagnet. We were thinking of ways to kill the boss with it, or a nasty customer, Haha just for laughs. But it is a rare earth magnet that holds it up.
    Sincerely,
    William McCormick
    Apr 2010
    12V71
    Between the 3 or 4 top-tier choices it would be a
    matter of ergonomics, and:
    fluid equipped, upper capacity, and 'ease of shift'
    to a twist drill chuck, and tapping head.
    Don't shop price - shop product.
    Opus
Page generated in 1,713,306,517.56449 seconds with 18 queries
