Results 1 to 24 of 24
Thread: First Handrail Job-nailed it!
    Los Angeles
    Took me a while to figure out the dimensions and angle but I think I nailed it!
    MM211 (Sold)
    Klutch 120v Plasma cutter
    New Mexico
    Re: First Handrail Job-nailed it!
    Good Job!
    Sebeka and Bemidji MN
    Needs a gusset
    Syncro 350
    Jul 2013
    La Porte, TX
    Did you have help mounting that thing?
    Gravel
    The difference between theory and practice is that in theory there is no difference.
    Los Angeles
    Quote Originally Posted by Gravel View Post
    4 city inspectors came though :0
    MM211 (Sold)
    Jul 2013
    La Porte, TX
    Gravel
    Jul 2011
    Bossier Parish La.
    It must have taken months of measuring and calculations to achieve such a high degree of success on the first ever try. Nice job, bet your relieved all that work is FINALLY finished, you can now relax knowing it's over with.
    About those four inspectors, one had to check to be sure it was at the right height from the floor, the second had to insure it was at the correct angle, the third was to make sure it was offset from the wall enough and the fourth to make sure it wasn't off set too much from the wall. There needs to be one more to come see if it is anchored securely to the wall, so you might not be out of the woods yet.
    Sep 2006
    NJ, USA
    Quote Originally Posted by Bistineau View Post
    In addition to the Inspection of Adequecy of Anchoring (I-A-A), there is also the needed Inspection of Grip Dimension (I-G-D) and the Inspection of Grip Extension Beyond Beginning and End of Stair Treads (I-G-E-B-B-E-S-T).
    Only partly tongue-in-cheeck, as all of the mentioned 'inspections' actually are or should be checked/inspected. Stairs and handrails and guard rails can be rather picky to do to 'code'. BTDT.
    btw Ed, where are the pics of the welds?
    May 2010
    Sparks, NV
    I missed the word "rail" when I first read the thread title...
    Vermont
    Yet you opened the thread anyway.
    Craftsman 90 amp Arc welder
    May 2010
    Sparks, NV
    Quote Originally Posted by lighttekku View Post
    Oh course. Heh...
    Sep 2005
    Cave Creek AZ
    Nope, you didn't. It needs to have either a volute or a lambs tongue on each end, or a return to the wall per code, so that it doesn't hang up on clothes? It also needs to extend one tread length beyond the stair in both directions, and remain at the same height above the floor, measured at the tread nose. It should be a stretched Z shape, not straight. It also looks to be 2"+ diameter, the limit for graspability per UbC is 1.5" diameter.
    You asked for it.
    Man what did you use to lift it ? No room for a crane. The jobs that men do.
    Jan 2014
    Hallieford, VA
    AND, like the ATF, the 5th and 6th guys check and double check to ensure that it is the right address.
    Miller 350LX Tig Runner
    TA 210, spool gun
    Lincoln 250/250 IdealArc
    ESAB PCM 500i Plasma
    Kazoo 30" vert BS
    Kazoo 9x16 horiz BS
    Clausing 12x24 lathe
    20T Air Press
    Sep 2011
    UPDATE: Owner decided on something more basic!
    Jul 2011
    Bossier Parish La.
    Quote Originally Posted by storeman View Post
    NO, the fifth inspector is there ONLY to check for security of anchorage. You are bringing up a job for the SIXTH & SEVENTH inspectors. Don't want to overload inspector #5 on checking addresses too.
    Jan 2014
    Hallieford, VA
    #5 is a woman, good at multi-tasking.
    TA 210, spool gun
    Kazoo 30" vert BS
    Kazoo 9x16 horiz BS
    20T Air Press
    Apr 2010
    Broccoli1
    OSHA Safety Orange - nice touch - you can't be too careful with something that
    doesn't come with an operator's manual.
    Whenever I build unique projects that has capped ends - I'll throw in a handful
    of nut and bolts to make noise if the object is ever removed/surplused.
    Hand rails are low hanging fruit.
    The idea: is that curiosity will take over, and it will be cut open when scraped.
    The nuts and bolts are the lure so the truly 'rarefied' time-capsule contents can
    be 'appreciated'.
    Opus
    Vermont
    Broccoli1
    be 'appreciated'.
    Opus
    That's a really cool idea. It would be cool to add a picture and maybe a short bio of the builder, would be a unique find.
    Jul 2014
    You asked for it.
    Yea i was thinking the same thing but didn't want to be the first to rain on this love feat!!
    Jun 2007
    id like to see a skateboarder grind on that sucker
    Nothing Ever Got Done By Quitting, Never Give Up.
    Los Angeles
    Just in case anyone was worried, no I did not build this awesome handrail
    Just found it on the ol' interwebs and found it rather amusing
    MM211 (Sold)
    Jul 2014
    I looks more and more like a HOTDOG just stuck there,the Wienie rail!
    Jan 2008
    Richmond, Virginia
    A weenie-wail. I can hear the music now. (In my head, can't get it out...)
    Syncrowave 250 w/ Coolmate 3
    Dialarc 250, Idealarc 250
    SP-175 +
    Lincwelder AC180C (1952)
    Victor & Smith O/A torches
    Miller spot welder
Page generated in 1,627,399,677.28233 seconds with 11 queries
