Results 1 to 25 of 26
Thread: 347 filler on 304 SS?
    SoCal-LA
    Hey guys.
    I have been doing the research and the chemistry of ER347 filler looks to be compatible with 308 for welding 304 alloy stainless steel. Is there any downside to using 347 other than cost?
    TIA.
    Apr 2012
    Athens - Greece
    Re: 347 filler on 304 SS?
    Not really.
    Aug 2006
    San Dimas, CA
    From Burns Stainless;
    2. What size filler rod should I use? - For welding 18g, 16g and even SCH 10 stainless steel, we recommend a 0.030 diameter rod of the appropriate base metal. We recommend 308 rod for welding 304 to 304 as well as 304 to 321. We recommend 347 rod when welding 321 to 321 and when welding mild steel to 304, a special 309 rod for dissimilar metals is recommended. We have found that 347 rod can be used for most 300-series stainless steel welding applications.
    http://www.burnsstainless.com/WeldingFAQs.aspx
    Apr 2012
    Athens - Greece
    347 is essentially 304 with small additions of niobium to stabilize it. Stabilization of a stainless steel essentially means adding an element that will form carbides when exposed to higher temperature. Otherwise the chromium forms carbides thus reducing the corrosion resistance.
    347 is used mainly when welding 321 (321 has small additions of titanium to form the carbides) or 347. The reason 321 is not used so much as a welding consumable is the fact that Ti is easily burned in the arc making it a less than ideal choice.
    Although 347 could be used for welding 304 it is less than ideal for welding 316 since it lacks the molybdenum that gives 316 its superior pitting resistance.
    I hope this was of some help.
    Feb 2012
    ny
    Quote Originally Posted by taz00 View Post
    I hate being bi-polar it's awsome
    My Heroes Have Always Been Cowboys
    Sebeka and Bemidji MN
    Now Mike, are you saying that it wasn't of help?
    Looked pretty straightforward to me...I think at one point my brain switched to pistol calibers and then back to stainless
    Syncro 350
    SoCal-LA
    Thanks guys.
    I have been using 347 filler required by the customer on 321 to 304 applications and it flows like butter. A whole lot like Super Missile Rod(not quite the match), but a lot cheaper. I have one part that landed in the shop that several others gave up on. Includes a purge, heat sink, and a poor fit. Free flowing filler like 347 would help greatly. 308L just does not want to get out of it's own way it sometimes. But aside from that 347 just seems to be fast as hell and stable.
    I am trying to put together a set of documents to substantiate my choice. I am still crunching the data on this doc. http://www.aws.org/wj/supplement/WJ_1984_07_s231.pdf
    SoCal-LA
    And that is what I am hoping for, that the addition of stabilizing components just makes it a better choice for 304. And this is for tig applications.
    SoCal-LA
    So you were thinking 347 magnum eh?
    I hear it wets out good
    Syncro 350
    Feb 2012
    ny
    Found this college video of Dave and his buddy.
    Apr 2012
    Athens - Greece
    I did a quick read on the AWS article, interesting but could not find any reference to 304 welded with 308.
    In any case a chain is only as strong as its weakest link.
    Welding 304 with 347 will not give you any advantage since it will be the base metal that will govern the final result.
    If that were the case then you could get even better results welding with some nickel alloy.
    Ease of use is another matter though and since metallurgically 347 will not cause any problems I see no reason in not using it if you find it easier to work with (aside from cost)
    Quote Originally Posted by weldermike View Post
    Oh good lord....I'm sorry I even watched them! LOL
    Lost more IQ points watching them than when I watched Mr. Tig
    Syncro 350
    Jan 2014
    Hallieford, VA
    In case anyone is interested, I have about 2 dozen cans of NOS USA-made 347-15 stick electrodes (SMAW). Six to 10 lb cans, 10"-14" lengths, depending on manufacturer (Mc Kay, Arcaloy, Lincoln, etc.,), All sealed in undamaged cans. Most are 3/32"
    If interested, PM me.
    Miller 350LX Tig Runner
    TA 210, spool gun
    Lincoln 250/250 IdealArc
    ESAB PCM 500i Plasma
    Kazoo 30" vert BS
    Kazoo 9x16 horiz BS
    Clausing 12x24 lathe
    20T Air Press
    Laredo, Tx
    Thanks guys.
    have you tried 308LSi? I've read on Welding Tips n Tricks that the added Si helps with impurities while at the same time lowering the melting temp just a smidge and allow it to wet out a smidge better than 308L. I haven't tried it out though. It's even cheaper than regular 308L, diameter for diameter, from what I've seen.
    Sep 2014
    Structurally, I repeat, STRUCTURALLY, all 300 series stainless steels (with the exception of 330 grade) can be welded with any other 300 series filler (again, with the exception of 330). It's when you get into the other desired properties of the specific grades of stainless that you start mixing and matching filler metals with the base metals (ie; strength at elevated temperature, resistance to acid/caustics/corrosives, food grade properties at high temps, etc).
    200 series are also weldable with 300 series fillers, and 400 series are weldable with 300 and 400 series fillers. Sometimes, when certain 400 series (ferritic-type) are welded with 400 series fillers, preheat is required.
    -Hillbilly
    SoCal-LA
    No I have'nt. Sounds promising. I can readily buy 347, and got a good price from my laws.
    SoCal-LA
    Happy to say I ordered the ER347 filler and holy cow is it nice.
    Feb 2012
    ny
    Well then lets see some kick butt weld pics broski! I always enjoy looking at your welds, but they only appear once in a very blue moon.
    SoCal-LA
    Emm ok, these I am working on today. Got to use the 347 second image. Me like.
    Fillet weld-.030" 304 ss, Er308L filler with argon backpurge otherside.
    Single groove butt weld-.040" 304L ss, Er347 filler, backing block only to catch gas.
    Oct 2007
    Near Dayton, OH
    Hey guys.
    TIA.
    You're on solid ground shovelon. I've known some welders to use 347 when doing quick and dirty (and not to code) boiler tube work. The added Niobium helps soak up carbon contamination from soot and other crap that finds it's way into the weld pool. I'm not recommending it, but more than one guy has told be that if the welds are showing porosity using 308L TIG rod, that 347 will get the job done.
    The greater 'ease-of-use' is just a free benefit.
    Benson's Mobile Welding - Dayton, OH metro area - AWS Certified Welding Inspector
    SoCal-LA
    Quote Originally Posted by A_DAB_will_do View Post
    Thanks! That is what I was looking for.
    Niobium is a new one for me, never heard of it.
    Found this interesting about it:
    "Niobium is an effective microalloying element for steel. Adding niobium to the steel causes the formation of niobium carbide and niobium nitride within the structure of the steel.[21] These compounds improve the grain refining, retardation of recrystallization, and precipitation hardening of the steel. These effects in turn increase the toughness, strength, formability, and weldability of the microalloyed steel.[21] Microalloyed stainless steels have a niobium content of less than 0.1%.[55] It is an important alloy addition to high strength low alloy steels which are widely used as structural components in modern automobiles.[21] These niobium-containing alloys are strong and are often used in pipeline construction."
    Syncro 350
    SoCal-LA
    Typical niobium content of 347 is .05%, so that makes sense for grain stabilization and thus puddle stability. Cool. Also looks like a better filler all the way around than 308L for grain refinement.
    Feb 2012
    ny
    Nice work Terry!
Page generated in 1,638,396,425.75801 seconds with 11 queries
