Results 1 to 16 of 16
Thread: 2011 Everlast PowerMTS 160 and 200S Synergic Mig/Tig/Stick DIGITAL WELDER
    Jan 2008
    Cal-i-forn-i-a like Swarzenegger
    The PowerMTS series, with MIG, TIG, and stick capabilities, is a new line from Everlast for 2011. Previously we announced the portable PowerMTS 400. Now, we are announcing the introduction of PowerMTS 160 and 200S. Both are extremely portable and lightweight. With a euro quick connect on the MIG, and built-in TIG gas valve, the unit is completely self contained. The units will hold up to a 11 lb roll of wire. The PowerMTS 160 features digital 160 amp MIG with arc force control. Additionally, the PowerMTS 200 features synergic function of the 200 amp MIG function. Simply select wire diameter, wire type, and wire speed control is auto set. If desired, the 200S can be operated in regular mig mode as well. DC tig function feature down slope and post flow control. Stick function is smooth and with low spatter.
    These units are ideal for portable repair or light fabrication. The PowerMTS series can give you the flexibility you need to go anywhere, and weld almost anything.
    PowerMTS 160 retail 949.00 with accessories
    PowerMTS 200S retail 1249.00 with accessories
    Nov 2008
    Re: 2011 Everlast PowerMTS 160 and 200S Synergic Mig/Tig/Stick DIGITAL WELDER
    It has a wave form control as well, which is sometimes referred to arc force, inductance, or slope on mig, and dig on stick.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Smith Oxy Fuel setup
    Everlast PowerPlasma 80
    Everlast Power iMIG 160
    Everlast Power iMIG 205
    Everlast Power iMIG 140E
    Everlast PowerARC 300
    Everlast PowerARC 140ST
    Everlast PowerTIG 255EXT
    Feb 2005
    Louisiana
    Hey Lugweld, I checked out Everlast's site for these, but I didnt see them listed unless I missed them. Are they on the site?
    A few of my toys !
    LinuxMint
    Manjaro
    Miller Roughneck 2E
    Lincoln WeldPak 100
    HTP MTS 160
    Chicago Electric 80amp Inverter
    Victor O/A
    Nov 2008
    Not yet, We are adding them, but we will have to wait a few days to get them up. But in the meantime, you can pm me or ask what you are looking for here.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Feb 2005
    Louisiana
    My HTP MTS 160 in shop for repairs. If its terminal, or more expense to repair than its worth, I may be considering one of these in the future.
    A few of my toys !
    LinuxMint
    Manjaro
    Miller Roughneck 2E
    Lincoln WeldPak 100
    HTP MTS 160
    Victor O/A
    Nov 2008
    I think you will find these to be quite exceptional and well designed.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Feb 2005
    Louisiana
    Basically my questions would be wire size capabilities, duty cycle, input amp draw, weight, and accessories included of each unit.
    A few of my toys !
    LinuxMint
    Manjaro
    Miller Roughneck 2E
    Lincoln WeldPak 100
    HTP MTS 160
    Victor O/A
    Nov 2008
    No problem.
    Duty cycle:
    160; 30% @ 160 amps, 60%@ 115 amps
    200S; 25% @ 200 amps, 30% @170 amps, 60%@ 115 amps
    Voltage:220V
    Input Amps:
    160; 27 for MIG, 22 for TIG, 31 for Stick
    200S; 37 for MIG, 29 for TIG, 33 for stick
    Weight:
    160 25 lbs approx
    200S 30 lbs approx
    Wire sizes .023-.040 for both, with aluminum drive rolls. .045 is possible with steel. 2-12 lb rolls (up to 8 inches)
    200 S is synergic function mig with automatic setting of voltage based off selected wire diameter and metal type. ONly manual manipulation of the wire speed is required. The unit automatically compensates the voltage. Manual overide is a function (ALT) so that it can function in a normal mig mode. Also includes inductance (wave form) control.
    160 is a standard functioning mig with wave form
    Both feature 2T/4T function of MIG/TIG with both featuring down slope and post flow controls for both. TIG is lift arc, with arc force control for Stick.
    Torches include Genuine 8 ft trafimet MIG torch, 300 amp stick electrode holder, 200 amp trafimet style tig torch.
    And both feature burn back control.[/LIST]
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Feb 2005
    Louisiana
    Thanks Lug, thats info I was looking for. One other question. Max amps for functions of each: Tig? Stick? and Mig? of each unit?
    A few of my toys !
    LinuxMint
    Manjaro
    Miller Roughneck 2E
    Lincoln WeldPak 100
    HTP MTS 160
    Victor O/A
    Nov 2008
    MTS 160:
    MIG 25-160, TIG 10-160, Stick 10-160
    MTS 200S:
    MIG 25-200, TIG 10-200, Stick 10-170 Amps
    Stick volts 58, with MTS 200S having VRD.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Feb 2005
    Louisiana
    Ok, thanks a bunch Lug. Waiting to see outcome of my HTP and then will decide. Thanks a lot for the info!
    A few of my toys !
    LinuxMint
    Manjaro
    Miller Roughneck 2E
    Lincoln WeldPak 100
    HTP MTS 160
    Victor O/A
    Jan 2008
    MTS units went into production !
    Thank you all who ordered them !
    Jan 2008
    update: Units should ship out end of the month right before the Chinese new year.
    Apr 2011
    The Boonies of Texas
    Hi Oleg,
    What is the status of the MTS units. I did not even know about them until I found this thread.
    Thurmond
    Miller Bobcat 3 Phase,
    26 series gas cooled TIG torch
    Miller Suitcase X-Treme 12VS
    17 Series Tig Torch for Solar Panel Powered Welding
    Oxy/Acetylene Torch rig
    EVERLAST PowerUltra 205P
    Jan 2008
    Units in stock ! Will ship all preorders on Monday
    Jan 2008
    2011 MTS200S on sale ! we need room for 2012 models.. pretty much same unit .. few minor internal difference.
    call for a special price
Page generated in 1,713,258,470.54547 seconds with 19 queries
