Hobart champion 10,000 welder with Koehler
49K views 113 replies 9 participants last post by  drussell0104
I picked up a older Hobart championship 10,000 today, it has 1625 hours and a Koehler engine, but runs I was told as the battery is dead and I could not test it. It has been sitting for 8 months to a year, so I did not want to jump it off without changing the oil,filters, and gas along with checking fuel lines etc. However the welder came with 80-100 ft of leads and a 50 or 80 ft ground, have not measured. My thinking is that was worth the 250 alone, they did say this welder had a surging problem when welding as In the arc burns through the base metals. So I'm not sure if it's the engine idle, or the board. If you have any recommendations or info on fixing up these let me know id appreciate the help. Oh, and if you have any idea where I can get an outer shell for one.Id love to know as this one is covered in a weld mark she'll which confused me at first and I still have no clue how that came to happen[emoji15] Here are some pics let me know what you think. P.S here's a trailer I'm gonna pick up for $350 looks like it'll be good to just keep this machine on and to haul a 4-wheeler or something what say y'all?.
#2 ·
I don't really see anything major wrong with the sheet metal cover that can't be fixed with a vigorous sanding and shooting a couple of coats of primer followed by a couple of coats of paint won't solve.
Good call on waiting for the oil and filter change and general check up before start up on it. No telling what you might find while giving it a good going over first. Tip it to one side so you can siphon out all the gas into a bucket so you can so what all comes out. I put a larger gas filter on my Bobcat which has the same engine as your Champion. You might look and find one with a clear outer shell so you can see when it starts to stop up.
Pull the plugs and turn it over a few times too, before trying to start it, to make sure there is no water in the cylinders. Check the condition of the plugs while you are at it, or just swap in a fresh set.
#6 ·
I pulled the plugs they were bad, replaced the air filter, and bought some 10w-30 Honda brand oil, and a kohler oil filter. I pulled the hood tonight blew it out of with air and dam this thing is dirty. However saying that all the wires look great no rat nests etc. Just years of accumulated dirt and dust. I did start it tonight to make sure it turned over, the welder fired up with a little gas in the carb ran for a few seconds and died. I pulled the carb and the seals are bad along with I believe the float is sticking. So I'm just gonna rebuild the whole thing. The gas was terrible I mean nasty :/I didn't change the oil yet as I don't like the way they have the drain plug. I'm going to get a piece of 3/8 galvanized pipe and run it out with a 90 on the end and plug it that way so it will be a hell of a lot better to drain when needed. The oil had gas in it also I smelled it tonight. Oh and it needs a new battery also. The gas tank was bone dry I threw in a couple of cups of ethanol free gas in it to turn it over. I'm gonna replace the fuel hoses also they aren't terrible but I'll feel better knowing its new. Now I can't decide whether to sand or sandblast it, because your right there's no dents except a minor one where the fan vent is no big deal. I measured the leads tonight also which was 100ft of stinger lead and two 80ft grounds.
#4 · (Edited)
Willie, if it is still in the warranty period, that broken/bent choke knob voided the warranty.:cry: It's an unauthorized alteration to the control features, so warranty voided:nono:. Good thought though.:waving:
You should also take the sheet metal off and check for rodent nests or anything else that should not be in/around any of the rotating parts before you try to crank it over. Blow it out with compressed air and give it a good eyeballing for anything that seems out of place.
#5 ·
With the welder working, you can use it to modify/improve the trailer to better suit your needs, like adding lead wraps and making a place to secure some torch bottles, raising the rails and adding more vertical supports to the rails. Make sure to check the tires for age cracking and repack the wheel bearings for good measure, too.
#7 ·
Oh I definitely plan to customize it to my tastes first thing is to grind out the ****ty welds on the fenders and re weld and also any other that doesn't meet my expectations. Then I'm going to raise up the sides and build a support for oxy fuel bottles and build some lead wraps that have a locking mechanism some way. I will add some cable to the wench or just replace it with a electric one have not decided on that. But it will be primed and painted after a good grinding and sanding. I plan on painting welder orange and black so may do the same with the trailer.
#8 ·
Don't forget to repack the wheel bearings, so you know they are good to go:). If it doesn't have one, get a good spare tire for the trailer. Then make a place to mount it on the trailer, with a locking mechanism. You don't want to have to leave it on the side of the road while you go to get a flat fixed.:nono: You might come back to find it's been stripped of everything that can be easily gotten off.:cry::( Or you may only find the PLACE you left it, and no sign of it anywhere.:angry::blob2:
A wheeled tongue jack is a good idea to have on it too.
#9 ·
It does have a huge *** hitch on it and I mean it hs to be over kill for that little trailer but it's nice none the less .! I have never re done wheel bearings or even dealt with them other than maybe in skates? I will build on a spare tire holder:) don't want it walking or rolling off. Any ideas on a way to keep leads on the trailer without them walking off also ? And if you know where I can get a new faceplate that would be nice too? Thanks
#11 · (Edited)
I would agree. If your engine drain is like mine(very likely), it has a yellow cap to remove and then push in and turn 1/4 turn to open the drain valve. You can get a short piece of hose that slips over the part the cap fits on and extend it out to your catch bucket. I have a clear piece of hose about 5' long and eliminates any mess. I can use the same hose on two of my riding mowers that also have Kohler engines. Look into that before deciding to alter your existing set up, it's cheaper and easier to do, and works just fine.
Repacking wheel bearings is a pretty simple operation. If your unsure of it, get someone who knows to show you how, while you do the work(hands on, best way to learn). A pound of wheel bearing grease only costs $3-4 and can do the bearings at least twice. A wheel bearing failure on the road is worse than a flat to get you going again, an ounce of prevention here is worth MORE than a pound of cure. I've had to deal with it on the side of the road before, not my truck or trailer either, but the guy had no clue what to do and I was riding with him. If your can rebuild a carbuerator and make it run right, then you should do fine with wheel bearings with a little instruction. I can probably talk you through it if you want.
#14 ·
The last one that I saw blown up, was a mismatch of the drain plug location and the hole in the frame.
The drain pipe consisted of a 4 or 5 inch pipe an elbow and a plug.
The galvanized pipe vibrated and eventually made the threaded hole oversize,it didn't turn itself out.
The constant vibration made the aluminum sort of flow.
The oil leaked out and an engine with about 50 hours on it, threw the rod through the crank case.
#15 ·
Well.. Now that's a dam good reason to not do it! Never thought of the threads becoming oversized due to vibration. Thanks a lot ! Any ideas on how to make it easier to change due to the drain plug being In awkward place specially right at the bottom under the starter in about 8 inches. Right down on the bottom of the floor
#16 ·
Gas in the oil is/can be an indication of a DEFECTIVE fuel pump on these Kohler power plants. Ethanol fuel also causes some “rubber” issues.
#21 ·
A carb issue doesn’t ‘normally’ provide enough gasoline to cause the oil to become diluted and have the gas smell. A broken diaphragm in the fuel pump allowing raw gasoline to be sucked into the crankcase does.
#25 ·
On my ranger 9 which has an onan engine there is a short hydraulic hose with a cap for an oil drain. The hose is only about 8 inches long. I would think that would be the best way to extend your drain.I have seen plenty of pipes and pipe fittings snap off from impact or vibration but have yet to see a hose break on the fitting unless it was smashed directly on the fitting.
#29 ·
If you can find a hydraulic fitting cap you will have a hex head instead of a pipe cap which is just round.
#30 ·
I can't find any parts for this machine itself hardly I find plenty of kohler parts for the engine though it seems well supported but I can't find crap out about the actual machine other than a write up of the specs on hobarts website. I stumbled upon a product called a fumoto qwik valve. All the reviews I read praise it. It comes with a extension of hose it also opens like a valve on a air compressor it's pretty slick. Ever heard of it and I'll have to decide which is easier/ more safe by Monday.
#31 ·
Not entirely familiar with that brand of valve but I have seen others. They usually are like a mini ball valve with a detent that you have to overcome to turn it. On mine the hose sticks out past the frame a bit. I bought the welder used so I'm not sure if its factory or not. I would use a cap since there's a possibility of sliding something into it and maybe breaking a valve .
#34 ·
That’s great! How long did you let it run? Keep an eye on the oil level and smell just in case the fuel pump also has an issue.
#37 ·
Not sure gonna grab some rods at work before I leave today and hook the leads up but I put it on a volt meter last night and it went from 35-70 erratically then no volts cleaned the studs tried again same thing. The open voltage on that machine should be 75. Also a red light was solidly on in the upper right corner of the pcb
#44 ·
If you look you should be able to find an idle solenoid that pulls in to bring it to idle. it's about the size of a "D" cell battery, with a linkage sticking out the end. Make sure the wires to it are connected good and the solenoid is free to move, it may be locked up. Check for voltage to the wiring to it when running.
#45 ·
Yea I saw it its directly on the carb the jet is behind it when you pull it. It has a red wire which I assume is the hot but no ground also there's no place to plug s ground just the red wire. The solenoid moved when I pushed it directly from behind when I pulled it so I assume it's good? It moved in and out anyways. I don't have a volt meter I'll have to see if I can borrow one from my neighbor. Or buy one I just never have much use for them until now
#62 ·
I know the real raggy looking line is just a cover but your fuel lines look pretty rotted. Did you check the 2 white colored fuses on front of the machine.
#63 ·
The ones up top are brand new fuel lines so they can't be rotted and the others don't have any cracks etc the very bottom one isn't that great though. I need to get some new line for it anyways I'll grab some tommrow. And there isn't any white fuses ? There is the cb 1-4 with white buttons but no fuses ?
#77 · (Edited)
Here is a post that might interest you regarding the cleaning of your rig. Read post #7.
http://weldingweb.com/showthread.php?313271-Cleaning-your-welder&highlight=cleaning+engine+drive
Contact member 7A749 with a PM to ask about his recommendations on doing this. I believe he buys, cleans/fixes up welding machines and resells them. Hope this helps. Here's another one you can check out about cleaning.
http://weldingweb.com/showthread.php?320211-Washing-welder&highlight=cleaning+engine+drives
There is another link in that link too. So look at it while you are at it.
#67 · (Edited)
The orange fuel in the cup may have been some residual old fuel left in the tank/lines that has now cleared out. I don't understand what you are referring to as something not spinning. Do you mean the idle solenoid? Does it get power to it when set for idle/run? electrical contact cleaner can be purchased at electrical supply houses, think about where electricians shop for their supplies.
