Results 1 to 6 of 6
Thread: Welding a crappy casting?
    Dec 2005
    Sacramento
    Ok guys I am a novice TIG welder, and I am having some issues with welding these crappy castings that these kids keep bringing me. Specifically blow off valve flanges that need to be welded to inter cooler piping. I get them done, but they look terrible since I am having to fill holes in the castings. Is there any trick to it or do I just tell these guys buy a real flange?
    I am using a Dynasty 200DX so I am able to adjust for the oxidation, but is there something else I should do?
    "If you live in Sacramento you have seen my work."
    Jun 2010
    raleigh nc
    Re: Welding a crappy casting?
    the flange / bov probably comes as a set from the cheapest region of ebay...
    I am in for the answer as I never thought the castings would be so poor.
    The BOV's I have worked with have always matched a standard flange - small piece of 3/8 - 1/2" aluminum or steel with 3 or 5 holes drilled in it.
    miller syncrowave 250
    hobart handler 140
    home made 400 amp engine driven in progress...
    May 2008
    MN
    On cast aluminum I usually start with these settings
    75% electrode neg
    60-120hz, some castings seem to respond better to the softer arc of the 60hz but very rarely do I go tha low.
    4043 filler
    Clean with lacquer thinner
    1/8 tungsten 2% lanth
    I will set the machine at the max amps (200) and just use the pedal to get just what I need. I will also work into the hea a little slower then if I was working with solid aluminum. I can't say I have ever had a aluminum casting I was not able to weld because of quality.
    -Dan
    Owner
    DW Metalworks LLC
    Miller Trailblazer 302
    Miller 8RC Feeder
    Miller Passport Plus
    Miller Dynasty 200 DX W/Coolmate 1
    Hobart Handler 135
    Hypertherm PowerMAX 30
    Smith O/A Torch Set
    Plus much much more
    Jun 2010
    raleigh nc
    key words might be "aluminum casting" - I would not be suprised if the chinese knock of tials are made with "any metal that can be poured into a mold"
    hobart handler 140
    Mar 2008
    Greater Seattle, WA
    Watch out for over-penetrating into the inside of the boost tube, if its not pristine clean inside. Especially if the tube has been used, it will likely have some oil film inside it that if your puddle penetrates all the way over to it, will cause immediate porosity in your weld.
    The only problem area I had when welding this one pictured, was the only spot where my puddle penetrated all the way to the inside of the tube (which had not been drilled, and cleaned only on the outside.)
    After you drill the hole, you can look or feel inside there to see where your weld bead penetrated all the way through. See if there is a correlation between where you believe the casting had a void, and where your weld bead penetrated through to the inside of the tubing.
    Dec 2005
    Sacramento
    Thanks for the help guys. Dan I will give those settings a try. I have made a few bolt on flanges from good billet stock before, but recently I have got a couple of real bad parts. They have been the SSQ style with the clip in style, like the one pictured above, so I could not just make it real quick.
    Maybe I will make a couple and keep them on hand.
Page generated in 1,628,122,768.84006 seconds with 12 queries
