PRICE: $340
SHIPPING: $65
Manual: http://www.millerwelds.com/om/o1545a_mil.pdf
This unit is a portable semi-automatic wire feeder which operates on the arc voltage from a constant current or constant potential dc arc welding power source. All components, including the wire supply, the two drive roll feeder and permanent magnet motor are housed in an impact resistant, molded thermoplastic case.
The case is designed with an integral, molded handle with a lifting eye for suspending the wire feeder over the work area. It also has positive latches securing the side door to prevent wire contamination.
FEATURES:
Input Welding Circuit Rating: 15-100 Volts, 500 Amps
Electrode Wire Diameter Capacity: .030 thru 5/64 in.
Wire Spool Capacity: 10 & 15 lb. (8in. spools, 14lb. coils)
Wire Speed Control
OPTIONS INSTALLED
Shielding Gas Valve
Welding Volt Meter
Wire Speed Meter
ADDITIONAL PICS: http://dallas.craigslist.org/ndf/tls/4863798277.html
SHIPPING: $65
FEATURES:
Wire Speed Control
OPTIONS INSTALLED
Shielding Gas Valve
Welding Volt Meter
Wire Speed Meter
