Page 2 of 18 FirstFirst 123412 ... LastLast
Results 26 to 50 of 426
Thread: Metal Core
    Mar 2014
    Re: Metal Core
    Quote Originally Posted by welditforyou View Post
    I'm curious as to why my shop uses tri-mix with 2% oxygen. It gets EXTREMELY hot (I know welding is hot). I need to seek an answer to that question.
    HT, what's your take on the matter.
    Jim
    Jim,
    I'm thinking it might be a case of your company having been mislead by your welding supplier into thinking you need a more expensive shielding gas product than what you really do. If I'm not mistaken you mentioned in another thread that you were using ESAB Coreweld C6. According to ESAB's product data sheet the recommended shielding gas is either 75/25 or 90/10 (Ar/CO2).
    It might be a good idea to print what's at this links off and pass it up the food chain where you work. Who knows, there might be an attaboy in it for you for saving the company some money.
    http://www.esabna.com/us/en/products...Code=268&tab=2
    One thing to be cautious of though is to make sure a change in shielding gas won't effect your WPQ (welder procedure qualification). I can for see some body maybe raising the concern that it would be an essential variable that would require recertifying it. If I were in your position I think I'd recommend to my supervisor that we at least got a bottle of 90/10 and do some test welding with it.
    As to running metal core just being plain old hot I can certainly sympathize. I've got to find a different style welding cap that will keep both my ears covered because right now the skin on the backs of both of them are peeling off. More than once I've had the 400 amp Bernard guns we use so hot you don't even want to hold on to it by the very back of the handle (and you don't even want to think about touching the goose neck). Even with holding 5/8 to an inch stick out I've had the end of the nozzle glowing red at times and some of it smoke off. Running with 28 volts and around 300 amps all day is definetly not for the timid.
  2. Likes Apache Old Man liked this post
  3. #27
    Mar 2014
    Re: Metal Core
    I like that, I'm going to use that one.
    Jim
    Along those lines......
    If some one ever points out a porosity hole in one of your welds the line of BS goes..."well to the untrained eye that may look like porosity but to those of us that really know what we're doing it's just a pre-placed stop crack hole".
    When welding on bucket lips if any one pointed out any spatter to me they'd probably hear something along the lines of it not being spatter just additional "wear protection beans".
  4. #28
    Missouri
    Re: Metal Core
    HT,
    I'm going to print that document and submit it up the chain with that very thought of saving the company money. I will either get the attaboy or a pink slip (smile with a beer).
    The addition of the oxy makes it burn hotter as it does with anything. (cotton fabric typically doesn't burn, it smolders. Now add oxy and it will go up in flames.)
    We'll see what the company has to say.
    Thanks.
    Jim
    Jim,
    I don't mean to be argumentative and cantankerous,
    but I am getting older and a bit crotchety!
    Addendum; AND CRANKY
  5. #29
    SoCal-LA
    Re: Metal Core
    Quote Originally Posted by HT2-4956 View Post
    Dam Terry, you're doing some really nice work at your place. What are those rolled cylinders of expanded metal for?
    Those are arena groomers. They get dragged behind a tractor.
  6. #30
    SoCal-LA
    Re: Metal Core
    Quote Originally Posted by killdozerd11 View Post
    Terry what's up with all that steel...Last time i was there shop was full of 1" aluminum
    Last year was painfully slow. The alum is coming back in and I hope it keeps coming.
  7. #31
    SoCal-LA
    Re: Metal Core
    Quote Originally Posted by ManoKai View Post
    @ shovelon - are you fabricating a time machine or a Telsa human transporter? Very cool work Terry. As a related aside, WHY did you select metal core to weld the the assemblies? Totally asking, new to metal core. BTW, the welds look metronomic and robotic. Awesome!
    I chose metalloy vantage cored wire to fill gaps, and keep the spatter to a minimum. It works pretty good for that. Goes into spray really fast. Those welds on the sheet was with C10 gas. The dome was with c25. For the screens I just use 70s-6.
  8. #32
    May 2010
    Port Orchard, WA.
    Re: Metal Core
    OK, lets teach an old dog a new trick! One of the members here was gracious enough to ship me a roll of Hobart Fabcor CVN .045” Metal Core wire. Going to try my luck first thing in the morning! I was surprised to see my Lincoln V350-Pro has a place in the menu for Metal Core.
    Don’t pay any attention to me
    I’m just a hobbyist!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
  9. #33
    Mar 2014
    Savannah, Georgia
    Re: Metal Core
    At what point do hobby weldors get to use the excuses: "pre-placed stop crack hole", "wear protection beans", or the 'evil spirit release fissure?
    I really have no idea what I am doing.
    Two Shop Cats (not Bobcats...real cats)
    Miller DialArc 250 AC/DC
    Scratch-Start TIG Setup
    MIG 175
    Plasma Cutter
    O/A
  10. #34
    Nov 2011
    Canada
    Re: Metal Core
    We use MCAW at my workplace, .045 but we're told to use it only on 3/8" thickness and up, some exceptions are made for 1/4" depending on the welder/fitter. On stuff thinner than 3/8" we are using .045 hard wire. We use 75/25 for both wires, which in my opinion could be changed. I would prefer to use 90/10 when using the metal core wire but because it costs more I'm guessing, the owner won't get it.
  11. #35
    May 2010
    Port Orchard, WA.
    Re: Metal Core
    Quote Originally Posted by Tat2dHandz View Post
    All I have is C-25 gas.
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
  12. #36
    Mar 2014
    Re: Metal Core
    Quote Originally Posted by wannab1 View Post
    You don't.
  13. #37
    Mar 2014
    Re: Metal Core
    I'm guessing it will run OK with C25 (especially in short circuit mode).
    http://www.hobartbrothers.com/upload...FabCOR_CVN.pdf
  14. #38
    Mar 2014
    Re: Metal Core
    Passed my D1.1, 2G, 1" plate, full pen groove with a backing bar using .052 FabCor 86R today. The only surface that didn't have the mill scale on it was the bevel on the upper plate.
  15. #39
    SoCal-LA
    Re: Metal Core
    Excellent!
    Did the scale play with your head?
  16. #40
    May 2010
    Port Orchard, WA.
    Re: Metal Core
    This Hobart Metal Core wire is slick!
    I started out with the V350-Pro set on .045” Metal Core. Then switched it to CV Mig standard. I think I like that best. Played around with different settings on fillet welds.
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
  17. #41
    May 2010
    Port Orchard, WA.
    Re: Metal Core
    Then I etched the welds to see what they looked like. 10 more amps makes a difference in the penetration.
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
  18. #42
    May 2010
    Port Orchard, WA.
    Re: Metal Core
    Played with some V-groove welds. Need to play around with different land and gaps.
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
  19. #43
    Mar 2014
    Re: Metal Core
    CEP,
    I don't believe you'll be able to spray in an open root pass. You'll need to get it turned down in to the short circuit transfer range.
    I was using an 1/8 root opening and 1/16 land.
    I pulled the puddle when I put the roots in (both horizontal and vertical down). I switched to pushing the puddle when I did the fills and caps in spray mode.
  20. #44
    Re: Metal Core
    CEP,
    I understand you're running C25. At those voltages was the wire trying to give you spray arc like characteristics or was it more of a high energy short circuit/globular transfer? If its the higher energy short arc/globular, I am wondering if an increase in the inductance (more arc on time) might no have helped improve puddle wet out.
    ESAB Migmaster 250
    Hobart Ironman 230
    Multimatic 215
    TWECO Fabricator 181i & 211i
    HH125EZ - nice little fluxcore only unit
    Maxstar 150 STH - very nice
  21. #45
    Aug 2011
    Cape Cod, MA
    Re: Metal Core
    The pulse modes are designed for 90/10 gas. I don't think you will get the best results with 75/25. If you can score a tank of 90/10 (or 92/8 or 95/5) you will gain a whole new appreciation of your V350 Pro.
    John
    A few welders
    A lot of hammers
    A whole lot of C-clamps
  22. #46
    May 2010
    Sparks, NV
    Re: Metal Core
    When I get a tank of CO2, I plant to do some experimenting with my mixer on different %ages.
  23. #47
    May 2010
    Port Orchard, WA.
    Re: Metal Core
    Quote Originally Posted by Dan View Post
    CEP,
    Dan I'm not sure I would know the difference. With the V350-Pro set on Metal Core .045” I kept dropping the wave control to get the puddle to wet out. Funny the volts would not read on the display panel. I didn't like the results being on Metal Core .045”, that's when I switched the V350-Pro to Standard CV Mig. But like Silicon-based is saying with out C-10 it may not work very well.
    When I switched to Standard CV Mig I could get the puddle to wet out by uping the voltage. But it just hit me when reading your post I forgot all about adjusting the pinch! The sound of the weld on Standard CV Mig made me think it wanted to go into spray. Kind of a neat sound! Hopefully I can get to town this morning to pick up the engine to my SA-200, if so I'll go by the welding supply and see if they have a bottle of C-10.
    This is fun, you never see this kind of welding on a construction site!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
  24. #48
    May 2010
    Port Orchard, WA.
    Re: Metal Core
    Picked up a bottle of C-10 the other day. Played with it some yesterday morning.
    I really like this metal core! Still think I like the V350-Pro set on Standard CV Mig tho.
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
  25. #49
    May 2010
    Port Orchard, WA.
    Re: Metal Core
    Two more pictures.
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
  26. #50
    Apr 2010
    Re: Metal Core
    Looks good CEP
    What would SATAN do ??
    Miller Trailblazer 302 AirPak
    Miller Digital Elite
    Optrel Welding Hat
    Arcair K4000
    Suitcase 12RC / 12 VS
    Hypertherm PM-45
    Rage 3 saw
    Rusty old Truck
Page generated in 1,713,285,007.37292 seconds with 20 queries
