Scrap For Steel Targets *RIMFIRE ONLY*
8.8K views 19 replies 15 participants last post by  Crabo
I've been asked to make up some steel targets for a friends range. I want to emphasize up front that they will be used for .22LR only. No magnum rimfires, no .17 caliber hot rods, and definitely no centerfire.
That said, I've some scrap plate that's 8' x 12' x 3/8" (no, that's not a typo; they're big plates). I don't know what type they are; probably mild or A36 (side note: are the two interchangeable? I've heard conflicting answers). There's enough money in it for me to buy myself a decent plasma cutter if I can use the steel I have. So...can I? Again, .22LR only, and there would be sufficient distance to the target to prevent splashback (15yd on pistol stages, 25yd on rifle stages).
Thoughts? How can I identify my plates? Will they stand up to the abuse?
#2 ·
Key to this could simply be target design. Look at this 22 cal rimfire backstop from Cabelas. The steel is nowhere near 3/8" thick. It's the angles that help defeat the rounds. 3/8" would be over kill.
http://www.cabelas.com/product/Do-A...42-26403687-2&WT.tsrc=CSE&WT.mc_id=GoogleProductAds&WT.z_mc_id1=20021082&rid=20
You don't talk about target design so there's no real good way to answer some of this.
This one uses 8mm steel ( they don't specify type) but that's about 3/8".
http://www.cabelas.com/product/Shoo...browse.cmd?N=1100227&WTz_l=SBC%3BBRprd707976&WTz_l=SBC;BRprd707976;cat104625180
#3 ·
im going to go ahead and ask that if you read and sign this release of liability, i will say that a36 would be ok.
i wish i knew for sure, but i haven't shot much steel. . . . .but that is because i want to practice 9mm at a minimum and as close as 10 yds.
everything i read on the topic all broke off at "might be good enough for 22" can you cut a piece and try for yourself? start at 30 yds and work your way up. any dimple you can put in with less than 100 rds would throw the idea out the window
#5 ·
I wasn't worried so much about punching through as pockmarks; a dimple can cause a ricochet directly back to the shooter, while a flat plate will stop the bullet cold and/or disintegrate it. Yes, a bit of angel can be used to induce a controlled ricochet into a safe direction.
#6 ·
I bet a 22lr would even go through 1/8 lol. I remember this one time when I was trying to should a duck in this beaver damed up river and I was shooting 22 shorts and was aiming right at the duck and shot at him like 4 times wondering why i couldn't hit him so I shot will looking over the rifle at the duck and I could literally see the bullet rainbow trough the air and land in the water in front of him lol it was funny. But seriously just buy AR500 or hardox500 it not much more expensive then mild steel. I just check a couple weeks ago. Only thing is most guys sell it in big sheets. So maybe try to find a small drop piece
#10 ·
I shoot 45acp lead loads at 1/2" mild steel with no dimpling. I can shoot jacketed as well without dimpling, I just prefer to use lead on steel. 3/8" will be perfectly fine for 22. I will recommend hanging them with the chain on the backside to get a slight downward angle and so they aren't taking all of the force by being allowed to "swing" some o it out.
#11 ·
See if you can get your hands on some A514 steel plate. It's tough stuff. I got some small drops (5-6 square feet each in odd shapes) in varying thicknesses, and the 1/2" stuff makes GREAT target plates. I believe A514 meets military specs for range backstops, deflectors, etc for small arms (sub-50 Cal). My source told me they were a mix of scrap bits from the turret shields on MRAP trucks. Dunno how true that part is... but I do know it holds up just fine to a 300 win-mag
#16 ·
I built these for my boss a few months back. He had the scrap laying around and knew I needed some extra money, so he offered to pay me a little to make him some targets... I think they were 1/4", and he said his rifle shredded them the first time he shot them. What a waste. I don't have a lot of experience with firearms myself, but he does, and that's what he told me to use..so... darn. not my fault, just gave him what he asked for. but man they did look pretty good when they left the shop.
