Results 1 to 25 of 43
Thread: welding clamps
    Pensacola , Fla
    welding clamps
    HI
    Not my idea but here is what I made for a welding clamp. I made different end parts to attach to welding table and metal to weld. the balls are 1" ball bearings tig welded to the bolt, angle, and v-grip.
    have fun
    Tom
    Jun 2010
    Butte, Mont
    Re: welding clamps
    I like that is WAY COOL!!!
    Jun 2007
    Wadsworth Ohio
    Re: welding clamps
    Very Very Cool
    I'm not smart enough to use something like that. Looks like the terminators arm.
    Dave Reber
    Wadsworth Ohio
    Nov 2008
    Lincoln, Ne.
    Re: welding clamps
    Very well thought out and constructed. Thanks, man.
    (Retired) Professional firefighter, amateur everything else I try to do...
    Oh yeah: Go Big Red! (You know: one of the 12 members of the Big 10 cuz we left the 10 members of the Big 12...)
    Feb 2009
    Coastal NC
    Re: welding clamps
    Like said "very cool". They look great and functional to.
    Two thumbs up.
    Western PA
    Re: welding clamps
    Now, where is that can of 1" ball bearings???
    Nice job.
    Cleveland, Ohio
    Re: welding clamps
    That is neat! This got the little gears in my head turning... Did you bevel the holes that sandwich the balls? How much weight can you suspend from one of those arms? Thanks for posting.
    Lincoln ac/dc 225/125
    Millermatic 211 w/ Spoolmatic 100
    Miller 330 a/bp
    Dynasty 200 dx
    Nov 2004
    Southern Montana
    Re: welding clamps
    I've been thinking about making a mono-pod mount for my new camera for shooting close-ups, and you've just saved me experimentation time. Thanks for the great idea!
    Apr 2010
    North Carolina
    Re: welding clamps
    I like the idea. Now if I can just find some 1" ball bearings!
    Mar 2005
    Re: welding clamps
    www.mcmaster.com
    PN# 9528K33 $13.05 pack of 10
    Re: welding clamps
    wow, that is AWESOME!
    brilliant.
    Nov 2010
    Re: welding clamps
    u should patent it. it looks like a fantastic design.
    Jan 2009
    Re: welding clamps
    careful, I think it IS all ready patented.......
    Tustin, CA
    Re: welding clamps
    That is trick. Will definitely be borrowing that...
    Jun 2008
    Vancouver, BC (formerly Cape Breton)
    Re: welding clamps
    I may just make one. I'm regretting tossing out that tobacco can that was half full of 3/4" ball bearings!
    Lincoln AC225 & MigPak 140, Lincoln Magnum SpoolGun, Miller Spectrum 375-X Plasma, Syncrowave 200 TIG, Millermatic 252 MIG, Miller Digital Elite, General 7x12" horiz/vert bandsaw, 3' box/pan brake, 20 ton press, milling machine, 12x28 lathe, etc.
    Nov 2010
    Alberta, Canada
    Re: welding clamps
    Awesome idea, well executed! The idea has worked its way onto my never ending "gotta build that" list. Thanks for posting.
    Gord
    Mar 2008
    East Texas
    Re: welding clamps
    Great idea.
    Can you give details of the joint plates. What sizes are they and how you fab'd them?
    Need to make a couple for myself......excellent work.
    Glenn.
    Sign on East Texas payphone: Calls to God 40 cents......it's a local call...
    Pensacola , Fla
    Re: welding clamps
    Hi
    Sounds like Mcmaster's has a better price I paid $20 for 10.
    The plates on the clamps are 3/8" X 3" X 1-3/8" the holes are 3/4". I did bevel the holes but that caused a problem with the range of motion. Just take the edge of the hole for the ball to seat in. Bolts are 3/8" X 16 treaded on one plate works fine be 3/8" X 24 may be better. I cut 2 plates and tack welded them together in opposite corners and dilled the holes then brole them apart for final shaping. When I cut the corners off that took off the tack welds and released the plates for final shape.
    As you can see in the pictures the bevel in out on the plate. I dimples the bolts and shafts for better centering of the bals before welding.
    have fun
    Tom
    P.S. where I got the idea from
    http://www.youtube.com/user/lazzemet...28/OnpOa9WtF7o
    Sep 2010
    Brooklyn NY
    Re: welding clamps
    I have very little space in my shop & I do a lot of small stuff so I built something similar to this but I used a pre fab articulating monitor mounting arm
    & it does the job great & can also carry quite a bit of weight & hold it firmly in place & be repositioned very easily...
    I also ran a 4 gauge grounding cable from the vice grip to the table so anything that's clamped is grounded without grounding through the articulating balls
    the vice grip mounted is made as a purge connection but it can just as easily be used for non purging applications too
    yours is an awesome idea too, I would have loved to build something like that but I'd be afraid that it will loosen up a lot & sag with anything a little heavy...
    miller 330a bp TIG
    miller dynasty 200DX TIG
    millermatic 185 MIG
    thermal dynamics cutmaster 101 plasma cutter
    snap-on YA5550 plasma cutter
    hypertherm powermax 30 plasma cutter
    baileigh CS225 cold saw
    etc....
    West Texas
    Re: welding clamps
    I got some ball beaings from a pump company.The top thrust bearings (balls) in some of the gearheads
    are 1 inch or bigger sometimes
    Millermatic 210
    Miller Thunderbolt
    Lincoln Weldpak100
    Jet Bandsaw
    Hypertherm Powermax 45
    1 Big Box of Bandaids !
    Victoria, BC
    Re: welding clamps
    Wow, I've had this exact device in my head for a while. Just haven't gotten to it! Nicely done! I got the idea from those little electronic soldering holders with the magnifying glass.
    Jun 2010
    Butte, Mont
    Re: welding clamps a jig i made
    a jig i made to be in the center of the ball Name:  02-02-11_1333.jpg
    Aug 2008
    virginia
    Re: welding clamps
    cool idea, i wonder with this same similar setup upscaled useing trailer hitch balls as your pivot points to work with larger metals might just be what i need for some ajustable jigs i need. thanks for the idea
    If you like my stuff you can find me on Facebook.
    https://www.facebook.com/theangryanv...ngryanvilforge
    Dec 2009
    Las Vegas, Nevada, USA
    Quote Originally Posted by T E B View Post
    T E B:
    What's the story on this vise mounting? Is the vise mounted to a corner plate with locking pin, for quick vise swap? er.. call it the flat plate equivalent of a receiver mount for your vise?
    oops.. apologies for going off topic..
    Nice job to the original poster for a cool application...
    Jun 2010
    Butte, Mont
    Re: welding clamps
    Hear is the thread on the v vise http://weldingweb.com/vbb/showthread.php?t=43455
Page generated in 1,624,029,210.32303 seconds with 12 queries
