Results 1 to 12 of 12
Thread: Aluminum TIG getting better....?
    Aug 2013
    Been practicing a lot with the Diversion 165. How does this look to those in the know? It's 1/8" 6061 with a nice V all the way around formed by the end piece being just a hair bigger than the inside dimensions of the rectangular tube it's welded on. Used 3/32 electrode and filler. It may be the best looking aluminum part I've welded so far but curious how a more experienced eye would view it?
    charlotte, nc
    Re: Aluminum TIG getting better....?
    if it doesnt' leak when you fill it with water, it's a good job in my book.
    performance trumps looks to me!
    PDX PNW
    You need to post a better pic. Looks good from a distance. I don't really like to step over that far myself
    Aug 2013
    There's a itsy bitsy leak in one corner. If I fill it and put it on a paper towel, there is a quarter size wet spot after an hour. I'll touch it up and should be good to go. It's an oil catch can, so no leaks allowed...
    Aug 2013
    Step over?
    PDX PNW
    Your moving over pretty far each time you dip. How about a closer pic?
    Feb 2008
    North of Philly
    I agree I'd want to see the dips a bit closer together. Maybe as much as 2-3 times as often. Far side looks a bit fast from the shape of the toe I can see. More filler may solve what I'm seeing. Lower near corner definitely has a leak potential that I can see.
    Keep in mind just because it won't leak with water, it may still leak with oil. Diesel for example is known to leak thru spots water will not.
    Ronald Reagan
    Aug 2013
    That's guys. I'll work on that feedback -- very helpful. I thought that bead spacing was about right, but now see that most of the good aluminum examples on google have tighter beads... The good news is that I touched up the corners without making it look bad, and not it holds motor oil all day without any seeping.
    PDX PNW
Size:  45.5 KBthis is for my tig cooler tank. 1/8 thick. You will have to give it a little more foot pedal when dipping more often. Just a heads up
    Nov 2013
    Very Nice,
    Jun 2014
    Quote Originally Posted by tom86951 View Post
    Its cool to see people making there own catch cans or anything else car related. What type of car is this going on? I was going to do this as well as all my hotside parts and exhaust but I ended up getting rid of the car...
    Feb 2011
    Martinez CA
    I like to set up a tank weld joint so its Edge to Edge, that way the material thickness stays uniform and looks nice.....Closer dabs makes for less chance
    of a pin hole leak.....
    http://im1.shutterfly.com/media/47b8...?tn=-202827091
    Water tank for washing MX bikes from Motor home
    Miller Dynasty 350
    Twenty Six Hammers
    Three Crow Bars
    Big Rock
Page generated in 1,624,195,016.79525 seconds with 14 queries
