Results 51 to 75 of 87
Thread: what size is your shop?
  1. #51
    Jan 2008
    Lansing, MI
    Re: what size is your shop?
    Hahaha
    Here's something you'll like. It just a baby compared to the big ones, but she's all mine
  2. #52
    Nov 2014
    My shop is exactly like every man's here-It is too small, and just like you, when I built it myself, I was thinkin it would be too big. Even if tomorrow I built one that echoed, it would be too small next week.
    That's just the way it goes......Kinda sorta like Boyle's Law where a finite amount of gas will fill a space no matter the size, huh?
  3. #53
    Jan 2008
    Lansing, MI
    Quote Originally Posted by wornoutoldwelder View Post
    Don't matter how big you go, it'll never be big enough.
    My garage is pretty full, near everything is on wheels so that helps. I used to have a surface grinder in there too, but that's been gone for awhile.
  4. #54
    Delaware
    20' X 24' heated and air conditioned, 20' X 18' pad in front ( car port will be add to the pad next month,NOT for the car" and 12' X 24' storage unit in the rear with a 8' X 20' add on.
  5. #55
    Oct 2013
    NOVA
    So I am on my 5th shop.
    1st was as a helper at the body shop 4 bays wide, 2 cars deep for one guy and a helper. Seemed huge, but we managed to fill it occasionally.
    Second was 16 x25 with a roll up on a 16' wall. TINY. Couldnt do much more than a drill press and a couple work benches.
    Third was 22x50. I am always amazed at what we did in that shop. Roll up was on the 22' wall. It was always tight, but it was just big enough to really work out of.
    Fourth is technically current shop. Total of 90 wide but has 3 sections of 35x30, 30x30, and 24x30. For a total of around 2900sqft. Definitely better than anything previous as i got to purpose build most of it, but it is still a compromise as i was fighting with the office folks for footage.
    Just signed lease addendum that give me an additional 2200 in a 70x30 chunk.
    Having fought with all of these over the years, only thing I can say for sure is depth from the roll up is gold. Right now I have a dock and a ramp both in the 30x30 chunk and I cannot pull in my work truck because of a workbench up against the back wall. 36' is a minimum but 40 is better.
    Multimatic 200
    Ellis 1800
    Haberle S225 9" cold saw
    MM 300; Spoolmate 30A w/ WC-24
    TB 302G
    Dynasty 280 DX Tigrunner
  6. #56
    Piedmont, SD
    Quote Originally Posted by Drooopy View Post
    I'll say it one more time, while the expense may not seem to be worthwhile, a minimum 40' depth can change a shop into a working delight instead of one that is nearly unusable.
    Lincoln PrecisionTig 275
    Miller 251
    Miller DialArc 250
    Bridgeport mill
    Hossfeld bender & dies
    Logan shaper
    Jet 14 X 40 lathe
    South Bend 9" 'C'
    Hypertherm 900
    Ellis 3000 band saw
    21"Royersford Excelsior
    Two shops, still too many tools.
  7. #57
    Big Lake/Monticello MN
    Quote Originally Posted by WyoRoy View Post
    +1
    Mine is only 32' deep - it makes many things more difficult.
    Trying to cut 24' steel in a 26x32 shop is cumbersome at best - saw has to be moved around - need room to move it and still have a big table to work on.
    Table is about 5x9 and is on wheels, takes some fiddling around until the metal stack gets cut smaller.
    Vehicle length + engine hoist gets tight sometimes.
    26' width means the tools on the side walls are very close to any vehicle being worked on (two stalls).
    Very little room to move a welder past a vehicle - and the table is now in front of the vehicles.
    I think 40x40 will be my new "smallest practical" size requirement
    Syncro 350
  8. #58
    Oct 2012
    Quote Originally Posted by MetalJunkie View Post
    I have a 30X40 and it is fine. Just a pain in the but to sweep.
    Use a leaf blower
  9. #59
    Nov 2010
    SE Nebraska
    Mine is 40x72 with 40x45 heated and cooled and the other side is just cold storage thus far. I'd highly reccomend in-floor radiant heat! once you have it you'll never regret it. My next shop will be 60x80 just shop and have another part for storage. I've WAY outgrown this building.Name:  shop.jpg
Size:  56.3 KBName:  floor heat.jpg
    -Doogie
    Miller 350P
    Miller Trailblazer 325 EFI w/ Excel Power
    Lincoln LN25 suitcase welder
    XMT 304/22a feeder
    Miller Syncrowave 350LX
    Miller Econotig
    Hobart Handler 140
    (2) Uni-Hydro 42-14
    Hypertherm 65 plasma
    WEBB Gap bed lathe
  10. #60
    Aug 2006
    St. Paul Park MN
    128'x40' with 16 ' ceiling. insulated, heated, bathroom and office. The one regret, I didn't make it 50' wide.
  11. #61
    Quote Originally Posted by derekpfeiffer View Post
    In-floor heating is awesome
    Only worked in one that had it - wish mine did.
    Syncro 350
  12. #62
    Dec 2009
    Stevens Point, WI
    I work out of a measly 25x36 shop. A dog house to most of you.
    Tube channel: https://youtube.com/@VPTfab
  13. #63
    Feb 2013
    Sweet Home Alabama
    I was just thinking back to my first work area and it was under a big walnut tree. However when it rained or was bad weather , I had to cover stuff up with a tarp. Then I moved up in the world and got to use an 8 x 12 shed. Sometimes big is not always better . I believe if I had one of the new 65 x 600 ft long poultry houses like they are building in our county , I could eventually fill it up with stuff if I lived long enough.
    I like the post on the heated floor. Other threads on bi-fold doors and all the information you guys have provided. Thanks for sharing.
    We have been going from Ice to 10 inches snow to 70 degree yesterday to Ice again today here in Alabama. I checked our metal building and everything inside looks like it has rained due to temperature changes. Drill Press Table has actually rusted (surface rust ) in three days. Our humidity is so high here in Alabama . Our building is well insulated other than the roll up doors . Other than putting in HVAC for the tractors and tools , does anybody have a good suggestion on how to control this? ( Move to a drier state????) We thought about enclosed another insulated room in the barn and putting all the tools , welders in and running a dehumidifier most of the time. Richey
  14. #64
    Feb 2013
    Sweet Home Alabama
    OOps didn't finish. In later years as our business grew we went to a 30 x 40 which seems like a football field compared to where we started. When we out grew out of it in the 70s we rented half of an 80x 80 and then we were in tall cotton. Grew some more and build an 80x 200 with over head 10 ton cranes in the early 80s . That was too small added on 80w x 100 feet. Before we sold in 91 we were thinking ...........What were we thinking?.....We needed a 200x 600 cause we had run out of space. Items we handled were sub assembled and again we would be out on the yard having to use 60 ton cranes to assemble and complete the job. If it rained or was bad weather we had no where to work. That's why I made the statement that what size is the right size . I have a friend that teaches welding at the tech school and his home shop for his part time business is 30 x 30. Well organized and he sell a lot of stuff out of it. He doesn't need to grow and has a great business . His shop is just right for his needs. So bigger is better or is bigger just more space to pile junk?? I think we all know its sums up to the needs of the particular individual. Good luck with your shops guys. That's my $14.00s worth of advice.
  15. #65
    Jan 2005
    cullman co., Al.
    Hello everyone, My shop is 40 x 48 with 2 roll up doors. I have 2 entry doors and 4 windows and a concrete floor. It has 3 rows of 4 ft. fluorescent lights down the 48 ft. length. It is roughed in for a bathroom. The walls are 9 ft. tall. It was a year old last Sept. I like it a lot and wished I had built it sooner.
  16. #66
    Sep 2009
    Sedona, Arizona
    1000' sqft. I need a bigger boat. Press brake isnt going to fit.
  17. #67
    Sep 2009
    Sedona, Arizona
    Quote Originally Posted by tbone550 View Post
    At least you're not considering a quonset hut style. That's what mine is, and I swear one day when I'm rich and famous I'm going to build a huge shop right over top of that quonset, and then tear down the quonset. At least the quonset will never fall down from snow or wind load. And I'm sure it was cheap for the previous owner to put up.
    What dont you like about the Quonset hut? I was thinking about using a quonset hut for my welding, shear and press brake stuff but use a larger shade structure for the cold saw, plasma torch and other dirty jobs that I can keep the area clean with a hose. Something like this for a shop ... and a house someday.
    Use shipping containers with storefront glass/doors for office and or showroom.
  18. #68
    Jan 2008
    Lansing, MI
    Quote Originally Posted by Jimmy_pop View Post
    You rent Jimmy?
    Yeah, you need more space since the acquisition of that shear
  19. #69
    Sep 2009
    Sedona, Arizona
    Yes, I rent currently. Making plans to build a shop so I like seeing this thread.
  20. #70
    Jan 2008
    Richmond, Virginia
    ... No room for anything ...
    I forget how big my garage is. Now there's no room to extend a tape measure to check it. If there are two people in there, we have to breathe in and out alternately.
    Syncrowave 250 w/ Coolmate 3
    Dialarc 250, Idealarc 250
    SP-175 +
    Lincwelder AC180C (1952)
    Victor & Smith O/A torches
    Miller spot welder
  21. #71
    city of Four Flags
    32 X 32 X 10 which would be plenty if it was full of garden tractors and a turret lathe. I don't work on stuff the size of a lot of you guys so I don't need bays large enough for a vehicle or a trailer.
    Insulated very well and heated, have not needed A/C but my kingdom for a bathroom.....even just running water.
  22. #72
    Nov 2010
    Houston Pennsylvania USA
    Hahaha
    That looks pretty 7A. I Like Stubby lathes. I don't imagine I would have much call to go larger myself.
  23. #73
    Mar 2007
    Lookout, West Virginia
    400 glorious square feet.... it's small as f**k, but my wife was 7 months pregnant when I built it, so I was worried about spending too much money. It works, barely.
  24. #74
    Piedmont, SD
    Pops...got ya' a simple solution. Stacking. Grab yourself a pair of drywall stilts and stack 2-3 deep...maybe start with the Clausing lathe, Oreo filling in a Dialarc 250 and top it off with a cherry Miller spot welder. BTW, that Dialarc 250 is slightly less wide than it is tall...just saying.
    Miller 251
    Miller DialArc 250
    Bridgeport mill
    Logan shaper
    Jet 14 X 40 lathe
    South Bend 9" 'C'
    Hypertherm 900
    Ellis 3000 band saw
  25. #75
    Nov 2010
    SE Nebraska
    I absolutely love it!! My next shop will definitely have it as well!
    -Doogie
    Miller 350P
    XMT 304/22a feeder
    Miller Econotig
    Hobart Handler 140
    (2) Uni-Hydro 42-14
    WEBB Gap bed lathe
Page generated in 1,713,292,875.13203 seconds with 19 queries
