Results 1 to 25 of 35
Thread: You Have to check this out!!!
    Here's one for all you pocket engineer's. How do 40 ton bridge beams bend on their own after being installed? Do you think heat straightening would work?
    http://news.nationalpost.com/2015/03...dge-expansion/
    May 2010
    Port Orchard, WA.
    Re: You Have to check this out!!!
    I think I know those guys who did the rigging. I worked with them before, they could break a cannon ball!
    Donít pay any attention to me
    Iím just a hobbyist!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    They're trying to figure what caused it. My off the wall guess would be the beams were held straight when welded and had a lot of built up stress or the welding of the stiffener plates wasn't done properly.
    Delaware
    The pigeons did it.
    May 2010
    Port Orchard, WA.
    It will be interesting to hear what did happen.
    When all the I-90 work was going on across Mercer Island to Eastgate. A crew placing the prestressed concrete I-beams didn't secure them properly. Wind picked up over night, and blew the beams over. Prestressed concrete beams are really strong standing up right, not so much on there sides.
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Apr 2014
    Greensboro, North Carolina, United States
    Ouch! Looks like a Friday afternoon "critical lift". When in doubt wait until Wednesday, nothing good happens on a Monday or Friday. It seems the rigger and signal men need new careers. I bet the crane operators will get all the blame, mostly the crane down below. He must have thought the thumbs up from the signal man meant good job
    Thermal arc 211i
    Ck flex-loc 150 & 130
    Clamps, saws & grinders
    Harbor freight 80 amp inverter
    Sep 2009
    Sedona, Arizona
    since three warped the same way, I'm thinking the earth shifted or something equivalent that caused the "beams" to bend and buckle in the same direction. Crazy regardless.
    Nov 2010
    Houston Pennsylvania USA
    I wonder what the time frame on the movement was......cause I would be like freaking out man.
    Oct 2013
    Houston, Tx
    I tried to tell that guy not to weld his section with his 110 volt MIG.
    Hobart Beta-Mig 251
    1972 Miller AEAD-200LE
    Miller 250 Twin
    Northern Ind. Hybrid 200
    Longevity Stick 140
    Longevity Migweld 200S
    Thermal Arc Pak 3XR
    May 2008
    Orange, TX
    Guess the solar storm was more than they expected.
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Jul 2014
    Being up in Canada I'd say the polar magnetism is to blame or like mechanic 416 said the pigeons did it.
    Apr 2014
    In all seriousness, is boom deflection real?
    Thermal arc 211i
    They had 6 in place and were about to place the seventh beam when they noticed 4 of them were buckling. The road could be closed for up to a year and it's a busy road so lots of headaches in rush hour. Will be interesting to see if they can figure out what caused the massive beams to twist like that.
    Feb 2015
    Fairfax, Minnesota
    Maybe cold temp in the morning, ends were welded or fastened, then warmer temps came later in the day?
    Not the same, but I've seen the electrician's PVC on a 200' barn ceiling, which was installed at 20 degrees, go completely ape when the barn was warmed to 70 degrees an hour later. It can grow two inches with that kind of length. It couldn't expand because of the light fixtures every 12 feet. It was trapped.
    Kev
    Century 100 | Miller 250 | ESAB 353
    Who is Dan Well? Everyone always says to me, "You know Dan Well!"
    Not too much temperature change. Probably within 5 or 6 deg's on either side of freezing.
    Mar 2005
    Under a Rock
    Meh...
    Weld in some cross bracing and carry on...
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
    Dec 2014
    The bridge just has a dogleg now. Don't see what the big deal is.
    Probably a million dollar plus mistake.
    Apr 2010
    Welder-Dave
    Let the video play to the end - it remains as a still-shot - and is the best top-view.
    This is what I see in the pics . . .
    Viewing left/to/right - beams #6 to #7 [rt. side] - reference: the diagonal cross-ties
    on plane, and just above the bottom flanges. They are clearly absent between beams
    #4 to #6 in the 'hard-hat' pic - all you see is sun-light ground.
    I speculate 'out-board' beams #1 to #2 have the same bottom diagonal bracing.
    This bracing effectively boxes 'the parallel', and is intended to serve as a horizontal
    'strong-back' to couple the 'sisters'.
    From beams #1 to #3 - there is a full compliment of horizontal cross-ties/full span.
    Compare the over-head [video] with the 'hard-hat' pic. In the over-head view - the
    center section cross-ties are obviously sparse/absent.
    If you closely examine still-shot #1 you can see the buckled cross-ties - 'both of
    them'
    [3 pairs] - between beams #3 to #6. Each pair is buckled-up, and consistant
    with angle-iron compression failure.
    'Fabricated beam hinging' under its' 'own-load' is nothing new. I don't expect the
    findings to be an: Engineering flaw - but field 'Lackadaisia'.
    Someone decided that: 2/ties x 3 - was just as good as - 4/ties x 4. 'They never got
    to 4'
    - courtesy of: 'accumulative transverse-loading'.
    The symmetry of the omited cross-ties produced the 'hinging' wave-form. The 'pairs'
    of angle-iron cross-ties were weaker in compression than in tension.
    This is why the beams collapsed/folded left.
    They had all of the pieces - they just didn't use them.
    If you follow the recipe you will get a cake - if you don't - you get Humpty Dumpty.
    Opus
    Last edited by OPUS FERRO; 03-18-2015 at 03:37 AM. Reason: Mech/ic416 . . . Its been a long time since I've blamed squab.
    Feb 2008
    North of Philly
    Yeah probably one of those
    "Hurry up! Quit messing with that junk. We can put the rest of those cross braces in later. 3 is fine for now. We need to get these beams set and get those cranes out of here. We're running behind and need to pick up the pace! ..."
    Ronald Reagan
    May 2010
    Port Orchard, WA.
    Boy, does that ever sound familiar!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Apr 2008
    NW ON Canada
    Sounds about right.
    Jason
    Thermal Dynamics Cutmaster 52
    Miller Bobcat 250
    Torchmate CNC table
    Thermal Arc Hefty 2
    Ironworkers Local 720
    Those are heavy beams to just bend like that.
    Nov 2012
    new york city
    isn't that why they put steering wheels in cars and trucks
    i.u.o.e. # 15
    queens, ny and sunny fla
    I did a little reading today on bridge beams and remembered that they had to delay the placing of the beams because of wind. The wind didn't cause the bending but I now think they may have wanted to make up for the delay by trying to place all the beams instead of individually bracing them as soon as they were installed.
Page generated in 1,627,081,205.47595 seconds with 11 queries
