Results 1 to 20 of 20
Thread: How short do you let filler rod get?
    Long Island, NY
    Not that the price of filler rod is a big issue, but what do you do with all the filler rod stubs? I was watching a youtube video where a guy was OA welding and just fused the stub onto a fresh rod so as not to waste it. I tried it tonight with tig rod and it worked ok. Do most folks just toss the stubs? And if so, how short do you let them get before your fingers start burning? I guess part of that answer depends on how many amps you are welding at. Just curious.
    Dynasty 280DX
    Coolmate 3
    Lincoln AC 225 Tombstone
    Victor Oxy/acetylene
    Dec 2009
    Stevens Point, WI
    Re: How short do you let filler rod get?
    Normally down to around 1.5-2".
    Tube channel: https://youtube.com/@VPTfab
    Sep 2014
    Quote Originally Posted by VPT View Post
    Yep, just before you burn digits.. done.
    -Niche
    Big Lake/Monticello MN
    Quote Originally Posted by NicheFab View Post
    -Niche
    Be honest - the weld is almost done and it's going great, "I can make it" - two dips before the end you burn your fingers
    Syncro 350
    Nov 2010
    Houston Pennsylvania USA
    I don't weld for Nasa..............but I could. I hold stubs in pliers to tack. I don't like to waste stuff.
    Jan 2008
    Lansing, MI
    Depends. Sometimes I'll let it get down to a little over an inch, sometimes, I'll get a new rod with 6" plus left.
    I still save the short rods in a coffee cup, and will use them later for tacks or whatever.
    Of course, I'm just a garage hack so it doesn't really matter. The AAACE pays for all my supplies.
    CT
    don't cut your rods in half if you can help it. You will have 50% fewer stubs that way. I run them down to about 2 inches and throw the stubs away.
    Miller Multimatic 255
    Dec 2009
    Stevens Point, WI
    Is my cup half full or half empty?
    Jan 2006
    In A Nice Comfy Chair
    3/4 inch with 1/16....
    ...zap!
    I am not completely insane..
    Some parts are missing
    Do not attempt.
    Long Island, NY
    Wow Zap, your hands must be impervious to heat!
    Dynasty 280DX
    Coolmate 3
    Nov 2014
    san antonio texas area
    I have been practicing with 3 inch coupons so by the time I get to the end of the weld not only is there a hot arc to deal with but hot metal too. if the rod is less than 4 inches I grab a new one to practice on the next coupon. Feeding the rod is half of the practice process for me anywya. I like the idea of fusing the old rod to a new one. I have been fusing the 4" left overs together. Doesn't seem to make a difference practicing. Nothing I do is structural.
    Syncrowave 210
    HH140
    Victor O/A
    Jan 2006
    Quote Originally Posted by Heartdoc View Post
    More like "No Brain No Pain" according to Mrs.zap.......
    ...zap!
    Do not attempt.
    Nov 2014
    PDX PNW
    ^^^ lol funny stuff. I Toss mine into the filler bucket with about 5 inches or more. I know guys that weld them together or use pliers to use the last few inches. Once you stop tho and your filler is only 5 inches long seems like a wast to only weld an inch inch with that filler again unless you have somthing short like an inch to weld. Like Dave was saying earlier you think you can make it to the end alot then with one or two puddles to go and you burn your hand and run out.
    Morton, Washington
    Is that 3/4" AFTER you've fused all the shorts together?
    http://weldingweb.com/vbb/showthread.php...ng-Filler-Wire
    Jan 2006
    I only save/fuse 3/32" filler...
    1/16 is too small to deal with...
    ...zap!
    Do not attempt.
    Sep 2014
    Well, ok.. I cannot say that it has not happened in the past, cause I have burned my self all kinds of stupid ways
    I was going to comment in the "I caught myself on fire" thread that I have on a couple of occassions finished my bead before tending to the fire, but didn't want to be a bad influence..
    Jan 2008
    Richmond, Virginia
    Depends. Sometimes I'll let it get down to a little over an inch...
    Is that when you're wearing the blue dress?
    Syncrowave 250 w/ Coolmate 3
    Dialarc 250, Idealarc 250
    SP-175 +
    Lincwelder AC180C (1952)
    Victor & Smith O/A torches
    Miller spot welder
    Haha! Yep, here too
    Syncro 350
    Jul 2011
    Bossier Parish La.
    Would that happen to be the famous blue dress with the notorious stain on it??
    Nov 2013
    Livingston, New Jersey, United States
    I uae 4inch Vise Grips you can burn them down to nothing.
Page generated in 1,713,300,874.66625 seconds with 18 queries
