Results 1 to 8 of 8
Thread: longevity forcecut 80i
    Jan 2011
    had to cut out some 1/4 inch 6061 from a scrapped project for some stands for a aluminum fuel tank (vids of that project later) so i decided to make one of just the plasma cutter.... its a hi-def cutter and kicks the snot outta my old thermal dynamics cutter
    migweld 250p
    arcmate 205
    weldall 250pi
    forcecut 80i plasma
    '07 pro 300 miller
    '08 trailblazer 302
    mm350p
    dynasty 700
    dynasty 200
    deltaweld 452
    xr-a 50ft push pull feeders and gooseneck
    Jul 2006
    Texas
    Re: longevity forcecut 80i
    Quote Originally Posted by LONGEVITYPerformance View Post
    .... its a hi-def cutter ...
    The 80i doesn't have anywhere near the current density to be classified as high definition, not to mention that high definition systems usually use dual-gas systems.
    Jan 2011
    yes, i know... it doesnt use dual gas for plasma, however, it has tons more definition than my cutmaster has. tons more. ive seen plasma machines that cost upwards of quarter mil that are truly hi-def... was only trying to say that for the price tag, this machine has great definition... i should have worded it differently and thanks for pointing this out to me
    migweld 250p
    arcmate 205
    weldall 250pi
    forcecut 80i plasma
    '07 pro 300 miller
    '08 trailblazer 302
    mm350p
    dynasty 700
    dynasty 200
    deltaweld 452
    Nov 2010
    California
    Stan, your posts might carry more credibility (especially in a sponsored forum) if you deleted the "No ads - Just Advice" from your signature line.
    That video was 100% ad and 0% advice.
    Just throwing it out there.
    Miller Dynasty 200DX
    Millermatic 210 w/ Spoolmate 3035
    Hypertherm Powermax 380
    JD Squared Model 32
    Multiple fabrication tools & equipment
    Full Powder Coating Setup
    Jan 2008
    Hayward, CA
    MillerFab,
    I take full blame for that line in the signature. Our plan was to have someone credible not pushing our equipment as a sales man. Someone that uses our equipment daily and shows whats is capable off. However, i can see the conflict this may cause as advertising.
    Stan did not write that. Our staff did when this performance account was created. We dont want to mislead so it will be removed. You are the second person who complained about this.
    Our customers enjoy the videos and hopefully more welding web members will as well.
    Simon
    Jul 2006
    Texas
    ... it has tons more definition than my cutmaster... this machine has great definition...
    To quote Inigo Montoya: "You keep using that word. I do not think it means what you think it means."
    What exactly is your definition of "definition" in the context of plasma cutting?
    Jan 2011
    narrow kerf. and when hooked up with nitrogen instead of compressed air, it even leaves a glossy finish on aluminum. throw o2 at it and it leaves a glossy finish on carbon steel as well.... ive run both hypertherm and thermal machines and neither would produce the way this one does. only machine ive seen close was a panasonic, but was cost prohibitive
    migweld 250p
    arcmate 205
    weldall 250pi
    forcecut 80i plasma
    '07 pro 300 miller
    '08 trailblazer 302
    mm350p
    dynasty 700
    dynasty 200
    deltaweld 452
    Nov 2014
    how much did that plasma cutter cost you
Page generated in 1,627,438,145.63212 seconds with 10 queries
