thermal Arc 251
3.9K views 5 replies 5 participants last post by  ccawgc
Hey any body out there use or own a fab 251 thermal arc? If so how well did work? did it hold up? where are they made? any kind of info would be helpful !!!! does any body know if I could get a miller 30A spool gun to work with it, or would I have to use the more expensive tweco eliminator to get a good spool gun for aluminum welding ?
Thanks Sport
#2 ·
Are you running this off a gen and if you are why don't you just get something like a LN25 from Lincoln. I believe you should be able to run a spool gun directly off the TB or at least with a control box. I like Thermal Arc products and would not hesitate in buying one but in reading some your previous post I'm wondering if your trying to be mobile?
#6 ·
Most of the fabricators were made by cigweld for thermal arc. Cigweld is an overseas division of Thermadyn
To use the 30A you will also need a wc24 or a wc115 control box.
The wc155 is the easiest. but you need 115 volt external supply to run it.
You might be able to power a wc 24 from the 251, If not You may have to add a step down transformer. 240 volt to 24 volt.
Best thing to do is call thermal arc tech support and ask jeff.
