Results 1 to 14 of 14
Thread: Flashback
    Jan 2006
    In A Nice Comfy Chair
    Flashback
    Here is a link that was provided by a member about Flashback.
    http://www.toolboxtopics.com/Gen%20I...0Flashback.htm
    It happened to me so I thought it's best to make this a stickey..
    Thank you jbmprods for the link!
    ...zap!
    I am not completely insane..
    Some parts are missing
    Do not attempt.
    Jan 2006
    chico ca
    Re: Flashback
    your welcome Zap and glad it was just a wake up call. good idea you have hear to. lots of folks will see it.
    225NT bobcat
    AEAD200LE
    Scott 125
    mm175, mm252 w 30A, PT225
    mm211, TA 181i
    Hyper Therm 380, cut master 52
    9100X & XX, Digital Elite
    6 Victor sets
    smith little torch, meco midget
    kalamazoo band saw
    steel max saw
    evoulution circular saw
    May 2007
    Okanagan Valley.
    Re: Flashback
    A good combination is to have flashback arrestors at the regulators and check valves at the torch end.
    The check valves are nice because they don't add a lot of bulk at the torch end.
    And these are the arrestors.
    Aug 2009
    Re: Flashback
    When you inspect torches, keep an eye out for indications of internal fire damage such as heat discoloration.
    This now-much-shorter Victor mixer left parts of itself in the tube when it melted. I guess the Smith and Airco designers have a point. Tip-mix torches don't do this:
    Apr 2012
    Michigan
    Re: Flashback
    good post...this is good to know...i always lite my torch with mixed gas so it does have all the black smoke.
    Quote Originally Posted by zapster View Post
    ...zap!
    Oct 2010
    NC
    Re: Flashback
    I would recommend investing in a newer torch with built-in flashback arrestors and reverse flow check valves. It is too easy to get in a hurry and not take the time to put these in the line to the regulators separately.
    Ranger 225
    Weld Pac 100
    Power Mig 180C
    Magnum 100 Spool Gun
    Hobart EZ Tig 165i
    Surf for cardiovascular exercise. Saltwater is good for you.
    new york city
    Re: Flashback
    under what circumstances would anyone use acetylene over 15lbs? i find 10 lbs works fine for everything from sheet metal to 3" plate by changing the cutting tip to the correct size.
    Re: Flashback
    This one provides an excellent visual of what takes place during those undesireable conditions.
    [ame]http://www.youtube.com/watch?v=xwOkUxe8Xy8&list=PL47639173BE8AF3F8&featur e=player_embedded[/ame]
    Save Second Base!
    Re: Flashback
    Just reposted it Steve. Someone else did awhile back and I think the entire video series on proper setup and use should be a must watch for newbe OA torch users as well as a refresher for seasoned operators.
    Save Second Base!
    Feb 2013
    Kentucky
    Re: Flashback
    Great thread with great info!.. The YouTube was nice too! Showing what can happen during a "flashback''!
    How many on here have the flashback arrestors on their O&A setup ?
    Thanks!
    Hobart Handler 190
    Hobart Spool-Gun 100
    Lincoln 225 AC
    Miller & Pipeliner Hood
    Dewalt 14" Chopsaw, Grinders
    Harris O/A
    Victor Torch
    Custom Built O/A Cart
    Custom Welding Cart
    Heavy Duty 16 Speed Floor Drill Press
    Pipe-Bender
    Drill Doctor
    Apr 2012
    Western Kentucky
    Re: Flashback
    Quote Originally Posted by WelderBill View Post
    Thanks!
    I was first introduced to acetylene welding 47 years ago when my dad welded aircraft tubing. He never had flashback arrestors on his equipment. He never had a flashback because he followed proper procedures. With that being said, I believe he was more lucky than good. This stuff can happen to anyone.
    The older you get, the more safety conscious you become. Some call me paranoid, worry to much, etc. I've installed flashback arrestors on my torches, because I'd rather be a worrywart, than a dead wart.
    Build many useful items for around the home and for friends
    A great and useful retirement hobby
    Syncrowave 200
    Millermatic 252
    Spoolmatic 30A
    Spectrum 625 X-Treme
    Victor O/A torches
    Dewalt angle grinders
    Dec 2011
    Re: Flashback
    I was thinking of putting flashback arrestors on my Victor med. duty torch handle but the 3/8 sizxe seems nonexistent.
    Maybe I am missing them but all seem to be 9/16.
    Doing the best I can with what I got
    Nov 2011
    Detroit, MI
    Re: Flashback
    Thanks to the member that originally provided Zapster with the link that started this thread.
    Way too many guys using torch rigs and don't know how close to a (catastrophic) failure they are at.
    How do you know the blacksmith's dog? When you hollar at him he makes a bolt for the door!
    Re: Flashback
    I cannot see the video, youtube says the video does not exist.
    Sincerely,
    William McCormick
Page generated in 1,713,281,987.28605 seconds with 21 queries
