Page 2 of 5 FirstFirst 1234 ... LastLast
Results 26 to 50 of 123
Thread: 4bt cummins jeep build log
    Sep 2014
    TEXAS
    Re: 4bt cummins jeep build log
    I am using these springs from a 1979 bronco
    Sent from my SM-G900V using Tapatalk
    LONGEVITY 250EX w/ 25' weldcraft cs310 torch
    Torchmate w/ Hypertherm powermax 85
    withFLASHCUT CNC PRO SERIES CONTROLS
    Sep 2014
    TEXAS
    Air con bracket progress
    Mar 2015
    Mississippi
    Yea that springs right there will hold some weight lol(I am referring to the spring on the right). I forget, but the shock rides on the inside of the spring and it all sits on top of the front leaf springs correct? Have not looked at that model jeep in a long time. How much longer until you start working on the truck itself? You just about have the diesel wrapped up. Just a few more bells and whistles.
    Dec 2014
    Quote Originally Posted by AndrewDavenport89 View Post
    There are no leafs on a TJ, it is a coil spring setup, you would never have both as that would make for a very intersting ride with 2 springs constantly fighting each other and the shocks are outside the springs.
  5. #30
    Sep 2014
    TEXAS
    Quote Originally Posted by MountaineerMetal View Post
    Thanks for answering that
  6. #31
    Sep 2014
    TEXAS
    1979 bronco springs are installed
  7. #32
    Morton, Washington
    Quote Originally Posted by MikeGyver View Post
    Interesting build, looking good so far.
    Is that poor little jeep going to be able to hold that 750lb motor?
    I'm curious also. I have a friend that installed a 4bt in an Expedition. Before he found some beefier springs the fenders where rubbing. He was hoping to get by with the stock setup. It did fine after the heavier springs were installed.
  8. #33
    Sep 2014
    TEXAS
    Alt bracket is almost done
  9. #34
    Sep 2014
    TEXAS
    Recent progress
  10. #35
    Sep 2014
    TEXAS
    Here is a closer look at how I mounted the air con compressor, it is not completely done as of now
  11. #36
    Sep 2014
    TEXAS
    Started tearing down the jeep and get ready to fit the 4bt cummins and build motor mounts
  12. #37
    Sep 2014
    TEXAS
    I broke the dipstick shroud so I made a new out of stainless steel
  13. #38
    Sep 2014
    TEXAS
    Started fabricating the heater core plumbing
  14. #39
    Sep 2014
    TEXAS
    Gasser is out
  15. #40
    Sep 2014
    TEXAS
    4bt cummins / Ford bellhousing mocked up on the nv3550 transmission
  16. #41
    Sep 2014
    TEXAS
    Added some color to the transmission
  17. #42
    Sep 2014
    TEXAS
    Transfer case got a coat of por15
  18. #43
    Sep 2014
    TEXAS
    Here a different angle
  19. #44
    Sep 2014
    TEXAS
  20. #45
    Sep 2014
    TEXAS
    The face off
  21. #46
    Sep 2014
    TEXAS
    Got the flywheel back from the machine shop and went to work on the clutch, I sourced a new pilot bearing from the local bearing supply but the minor diameter is 1mm to large so I made a bushing the is pressed into the bearing and has a good slip fit over the input shaft
  22. #47
    Sep 2014
    TEXAS
    It's getting crowded in here
  23. #48
    Sep 2014
    TEXAS
    Started fabricating the turbo oil supply line
  24. #49
    Sep 2014
    TEXAS
    Photo op of the tig welder
  25. #50
    Sep 2014
    TEXAS
    I have been away for a while but I am back on the Cummins project building motor mounts
Page generated in 1,713,305,530.86402 seconds with 19 queries
