Page 1 of 5 123 ... LastLast
Results 1 to 25 of 123
Thread: 4bt cummins jeep build log
    Sep 2014
    TEXAS
    I have been in the process of building a 3.9l 4bt cummins to transplant into a 2000 jeep tj sport
    Engine build specs
    -std pistons with ceramic coated crown
    -acd stage 1 cam
    -head completely rebuilt with new valve seats, guides, and new valves
    -all new bearings from acd
    -acd fuel pin and 3200 rpm gov spring in the ve pump
    -he341 also known as hy35d turbo from a 2004 5.9 cummins with a 9 cm exhaust housing
    -5.9 exhaust manifold cut down to fit the 4bt and ports reshaped
    LONGEVITY 250EX w/ 25' weldcraft cs310 torch
    Torchmate w/ Hypertherm powermax 85
    withFLASHCUT CNC PRO SERIES CONTROLS
    Sep 2014
    TEXAS
    Re: 4bt cummins jeep build log
    More views of the project
    Sep 2014
    TEXAS
    Few more shots
    Sep 2014
    TEXAS
    Here is are some more angles and a shot of the 2004 common rail cummins I put in my 1999 f250 in 2011
    Sep 2014
    TEXAS
    Here is a shot if when I was working on porting the head
    Sep 2014
    TEXAS
    Been working on the bell housing, it had to be modified to clear the shifter boss on the nv3550
    Sep 2014
    TEXAS
    Wrapped the exhaust manifold with titanium wrap
    Sep 2014
    TEXAS
    Started working on the turbo piping
    Jul 2011
    Utah
    Interesting build, looking good so far.
    Is that poor little jeep going to be able to hold that 750lb motor?
    Sep 2014
    TEXAS
    Quote Originally Posted by MikeGyver View Post
    Thanks, to get the 3" of lift I need I think I will have to put 5.5" lift springs in but I will have to spend a little more time researching and doing the math, I plan on strengthening the frame in certain areas as well, if anyone has ideas please post them up
    Sep 2014
    TEXAS
    Built a mout for my tubing notcher
    Sep 2014
    TEXAS
    Cut apart a intake elbow from a 24v cummins and will tig weld it back to be used in my configuration
    Sep 2014
    TEXAS
    Welded the cast aluminum intake back together
    Sep 2014
    TEXAS
    All done
    Sep 2014
    TEXAS
    Test fit the modified elbow
    Sep 2014
    TEXAS
    The intercooler also came in
    Sep 2014
    TEXAS
    Downpipe flange is welded on
    Sep 2014
    TEXAS
    Starter clears
    Sep 2014
    TEXAS
    Here is a link to the turbo mount I built
    http://forum.longevity-inc.com/showt...in-turbo-mount
    Sep 2014
    TEXAS
    Trying to find the right spot for the intercooler
    Sep 2014
    TEXAS
    Version 2.0 of the turbo set up
    Sep 2014
    TEXAS
    Started building the alternator mount
    Sep 2014
    TEXAS
    Started mocking up the air con compressor
    Mar 2015
    Mississippi
    Very nice build... Now this is going into a jeep? Lol my goodness this is going to be a tight squeeze!! The weight on the front end... what type of Axles are you going to be running? I would suggest something on the lines of a Dana w/ 4.10 gears. Your putting a 5.5 lift on the front and rear correct? Is it going to be coil over springs? Do you know the Gross weight on that engine after its all said and done with your add-ons? You will have to cut your hood and put a very large Cowl on there. with real air intakes. I am sure you have measured your clearance?
    Dec 2014
    Quote Originally Posted by jbr View Post
    You don't want taller soft springs, you want the correct height spring in a stiffer spring rate. Old Man Emu and a few other companies sell different spring rates for heavy bumpers etc. Its about a 300lbs difference to a stock 4.0L
    Lots of info in this thread on different brands and spring rates
    http://www.jeepforum.com/forum/f11/s...-rates-613756/
Page generated in 1,635,290,853.36530 seconds with 12 queries
