Results 1 to 25 of 34
Thread: What are larger drill presses used for?
    Feb 2010
    Texas
    So what exactly can a big drill press like this do that a much smaller floor model could not? What is something like this typically used for?
    Background:
    > Replacing $300 beater soon
    >Looking at $600-$1000 models
    >This is $1,850 and gear driven, could swing the upcharge if I thought I'd use its potential added capabilities someday, since I dont wanna buy another drill press ever if I can avoid it
    I generally use a lot of hole saws in mild steel (3/4-2.5" holes, and twist bits (up to 1.5"), wouldnt mind having a little extra power behind things. I'm tired of going super slow through holes, and stalling my current press out using hole saws unless I use SUPER light pressure. I'd like to use my mag drill's annular cutters as well if possible
    [Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
    Feb 2008
    North of Philly
    Re: What are larger drill presses used for?
    Look at the drill speeds. Many smaller drill presses run quite fast as they are designed for wood. Often they are just taller versions of bench top models. Same head but on a taller shaft so you can use them as free standing vs on a bench. Bigger beefier ones are often designed for metal and run at really slow speeds for bigger bits.
    Ronald Reagan
    Piedmont, SD
    Spending that amount...look for power feed.
    Lincoln PrecisionTig 275
    Miller 251
    Miller DialArc 250
    Bridgeport mill
    Hossfeld bender & dies
    Logan shaper
    Jet 14 X 40 lathe
    South Bend 9" 'C'
    Hypertherm 900
    Ellis 3000 band saw
    21"Royersford Excelsior
    Two shops, still too many tools.
    Nov 2014
    Turning large drill bits, annular cutters, hole saws, countersink bits require much more torque and rigidity, the more industrial type machines will be better equiped for drilling larger diameter holes in thick steel. That grizzly unit like a lot like the l the baliegh industrial gear drive drill press
    Checkout my youtube channel: http://www.youtube.com/turbocobra
    Sep 2008
    SF bay area, CA
    Bigger drills are for bigger drill bits. Low RPM and industrial usage designed with beefier parts and bearings.
    I would look into an Ellis 9400 if set on buying new
    May 2015
    Barre Town, VT
    Do it! A gear head drill or an old camel back drill press is the only way to go for big holes. For one thing the column is large enough and the table support is beefy enough that it won't flex when putting a lot of pressure on large twist bits, and you can put as much down pressure as you want on them since it won't stall out (it might break the bit but it won't stall).
    My "collection":
    Homemade Stick Welder
    Victor O/A Torch
    AC 225
    Ideal Arc 250
    HF 90 Amp Flux Core
    HF Mig 170
    Solar 2020 Plasma Cutter
    Power i-Mig 140E
    Harris O/A torch
    HF Dual Mig 131
    140ST
    Alpha Tig 200x
    May 2013
    Central Florida
    Not only will a larger drill press allow you to use all the tools mentioned above but I like the ability to power tap which the more rigid machines allow you to do. We have a round column mill drill at work that is pretty much that drill with an x-y table. While not the best milling machine, it's awesome for turning drills and taps that our belt drive Bridgeport will not think of doing. It also appears that machine has a face mounted depth stop which on our mill drill contains a limit switch that reverses the spindle when the set depth is reached.
    TOO MANY TOOLS & NO MORE SPACE
    Check the throat depth as well. A press that is 7" post to center can't reach the center of a 16" square. Just depends what you plan to do.
    ---Meltedmetal
    Jan 2008
    Lansing, MI
    Personally, I would skip the drill press deal and go straight to a mill. You can get into a decent used Bridgeport or quality clone for what you're looking to spend on a good drill press. Sure, you'll have some increased weight and size, but what you can do with a mill is almost limitless, and second in versatility only to a lathe.
    Most are three phase, but a $75 static phase converter from WNY Converters and five minute installation, you're in business. I've owned big drill presses, and after buying my mill 15 years ago, they just sat and collected dust.
    All the tooling on a mill is standardized to its spindle taper and combinations infinite. You can use annular cutters, drills and hole saws with ease and repeatibility. Then switch to an end mill and put slots, pockets, steps into the workpiece. Key way cutters, dovetail mills, ball end mills, shell mills create an array of operations, all under the umbrella of one machine.
    Seriously Lanse, I would look into it. Since you're at a point where this has become a means of income for you, skip screwing around and get a machine that will serve you for years to come, and hold its value well. I paid a grand for my Wells Index in 2000. I could sell it for more than I paid for it today, and sell the extra tooling I have accumulated for it separately and make a nice profit. I've seen as well as bought Bridgeports for under $1500 in good condition, one for $600 and it was ready to go to work. Putting a cross slide table on a drill press works, but it's not very rigid and the extra expense easily justifies spending a little more for a real mill.
    If you need to turn really big drills, that's another story, but I've tapped 3/4"-10 on mine with no problem and cut some pretty big holes with cutters and even bits.
    That's what I would do anyways.
    IMHO of course
    May 2010
    Port Orchard, WA.
    Me too. Actually the mill is the cheap part, it’s all the crap you have to have that costs so much!
    Don’t pay any attention to me
    I’m just a hobbyist!
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Jan 2015
    Florida
    Came here to post this.
    Lincoln PowerMIG 350mp
    Everlast PowerTIG 210EXT
    Hypertherm PowerMax45
    You merely adopted the iron, I was born in it, molded by it.
    city of Four Flags
    [QUOTE=7A749;5955241]I would skip the drill press deal and go straight to a mill. [QUOTE]
    I'll join the dog pile
    Jan 2008
    Richmond, Virginia
    On smaller knee mills, watch out for the drilling capacity, especially with power feed. Bridgeport Series 1 is only rated for 3/4" in mild steel. That's why they make the big radial drills for drilling 1" and up.
    Syncrowave 250 w/ Coolmate 3
    Dialarc 250, Idealarc 250
    SP-175 +
    Lincwelder AC180C (1952)
    Victor & Smith O/A torches
    Miller spot welder
    Nov 2013
    Livingston, New Jersey, United States
    If you don't want to go with Bridgeport mill get a radial arm drill takes up a little more room but you could do some serious drilling then I would love to have one.
    Jan 2008
    Lansing, MI
    Somehow, I don't see Lanse putting a radial under his carport
    Last I knew, he had a basic cement pad with a steel prefab carport very similar to mine.
    Gonna need some serious footing for a big drill. I wouldn't roll one into my carport
    city of Four Flags
    Boring head
    Obviously any machine has it's limitations so we may be throwing out ideas based on OUR needs and not what Lanse will be doing.
    Jan 2008
    Richmond, Virginia
    Mo bigga, mo betta.
    SP-175 +
    Miller spot welder
    Jan 2008
    Lansing, MI
    I want one!
    A local press repair place had a nice older Giddings & Lewis boring mill they ended up selling for like $3500.
    It was a good sized machine, I would have bought it in a second if I had a place to put it.
    Jul 2012
    Chicago, IL
    I've got a large knee type mill, and a "large" drill press. Drill press is much faster to configure for large or odd shaped parts without messing up the setup on the mill. Personally, I think they both have a place in any shop. If it's a hobby shop, or "work after real job" kind of shop, go straight to the mill. But if time is a factor, get both. Bench top drill presses are great for wood. That's it.
    Personally, I don't like any thing Grizzly. Keep an eye out on Craigslist for an older, good drill press. Variable speed drive is also a huge plus!
    CEP, how much Chinese equipment can you shove in one corner??
    John 3:16
    (2) Miller Pheonix 456
    (2) Millermertic 252
    Dynasty 210DX
    Hobart 210MVP
    Doringer D350 SA Cold Saw
    Scotchman 350LT Cold Saw
    Webb 10x50 Mill
    Webb 15x40 Lathe
    Geka Bendicrop Ironworker
    Jan 2008
    Richmond, Virginia
    I think Carlton and American Pacemaker were the Cadillacs of radial drills. Something about the quill/bearing setup that made them better for boring/tapping than some others.
    SP-175 +
    Miller spot welder
    May 2010
    Port Orchard, WA.
    Quote Originally Posted by Econdron View Post
    Oh I got more, just not in that corner is all.
    Carl
    Dynasty 300
    V350-Pro w/pulse
    SG Spool gun
    1937 IdealArc-300
    PowerArc 200ST
    3 SA-200s
    Vantage 400
    Feb 2008
    North of Philly
    Mo bigga, mo betta.
    Man what's that a 6" twist drill?
    Ronald Reagan
    Jan 2008
    Richmond, Virginia
    Per the caption, 5". 50 H.P. motor. Enough to put a twist in your knickers.
    SP-175 +
    Miller spot welder
Size:  62.8 KBName:  image.jpg
    Lanse, whatever you do, don't get rid of your old drill press. It'll be worth more to you to have around than whatever money you could get for it.
    Trust me.
Page generated in 1,713,280,122.29064 seconds with 19 queries
