Results 1 to 15 of 15
Thread: OSHA Has Some Issues
    Sep 2014
    I am doing the 30 hour OSHA course because here in NY every 5 years now the city demands you retake the test.
    I am taking the test and the test is mostly about playing games with the English language that I have concerns they are not totally fluent in.
    Here are some excerpts from the materials you are supposed to learn.
    In this first example, they are instructing us to make sure that pipe joints or vessels that carry flammable gas or liquid be liquid tight. Ha-ha
    If you are not familiar with the difficulty of sealing a leaky joint carrying gas verses a joint carrying liquid, this might not be as funny to you. It is probably ten times harder to seal a joint that is going to carry a gas then it is to seal a joint that is going to carry a liquid.
    Name:  OSHA Ignition Hazards.jpg
    In this next example they claim that if you have a bad valve on a tank and it is not the packing nut or gland nut as they put it that is leaking. And the regulator stops the leak, you can keep using the tank. Now call me crazy but when the regulator on this tank goes, or there is a fire at the regulator what are you going do?
    Name:  OSHA Compressed Fuel Gas.jpg
    Sincerely,
    William McCormick
    Sep 2014
    Re: OSHA Has Some Issues
    You know darn well if you leave a cylinder on the cart with a regulator on it, someone is going to use it. Because you cannot cap it and remove it from the work area.
    Sincerely,
    William McCormick
    Anchorage Alaska
    Regulation by committee. It didn't work out well for the Russians.
    MS
    I personally would want know who deems the building or structure in "Ignition Hazards" as "important".
    SA-250 TMD
    Squarewave 200
    Thunderbolt AC/DC
    1951 G.E. welder
    Sep 2014
    Quote Originally Posted by Fat Bastard View Post
    It is definitely socialist training, of that I have no doubts. KTF or Kill the Farmer is what they should call it, in reference to the book and movie animal farm. They are blaming all the problems of science and taxation on the business owner.
    Sincerely,
    William McCormick
    Jun 2015
    Kinda like whinnying republicans blaming everybody else. I hear you.
    Quote Originally Posted by Blocker View Post
    The important individual who is in said building of course.
    ---Meltedmetal
    MS
    Good luck with your recertification. Forgot to tell you that in my original post.
    Sep 2014
    Oh, thanks. If I can remember the acronyms I will get through it no problem.
    Sincerely,
    William McCormick
    Sep 2014
    The soil types and names of the different soil types are a bit much to keep with you.
    The way they play around with the words competent, and qualified is definitely not healthy for the mind.
    Sincerely,
    William McCormick
    Sep 2014
    I just took the exam early this morning. I got a 95 on the final exam. I was only averaging about 79 on all the quizzes. Just glad it is over.
    Sincerely,
    William McCormick
    Jul 2014
    I am pretty sure that when the three pig's build there houses ,there was no OSHA , Come on now straw ,stick , and at last brick.
    Aug 2012
    AR
    Quote Originally Posted by cdp1025r View Post
    Very impressive first post on a welding forum.................
    Quote Originally Posted by gxbxc View Post
    Straw pig only thought he was important, stick pig had some pull but not as much as brick pig who now owns the assets of straw and stick as well as his own and he looking at yours and mine too. Such is the world we live in. It's going to the (brick) pigs.
    ---Meltedmetal
    May 2006
    Northern California
    Are you a democrat troll?.....first post "whinnying republicans blaming everybody else". This belongs in the Off Topic area.
    Miller Millermatic 252
    Miller Syncrowave 200
    Bernard Cooler
    Lincoln AC-DC 225
    Victor O-A Set
    High Hopes.
Page generated in 1,713,269,084.65278 seconds with 19 queries
