Results 1 to 5 of 5
Thread: Welding Turn Table Part 7
    Jan 2008
    Hayward, CA
    In this video Rob will embark on creating a welding turn table from things found lying around his garage and around the Longevity shop. In part one he will plasma cut rim to create a base for the turning mechanism. Also Rob will go over the theory of the creation of the welding turntable and how it will work. Rob uses Longevity's Innovator 255i to plasma cut the rim. For more information on the Innovator 255i follow the link below:
    http://www.longevity-inc.com/innovato...
    Portable MIG-TIG-STICK Unit
    The LONGEVITY PROMTSŪ 200i combines 3 welding processes in 1 machine with an impressive 200 amp MIG welder, 200 amp TIG welder, and 170 amp STICK welder.
    Easy Push-Button Setup
    The PROMTSŪ 200i is very user friendly! All the
    adjustments are properly spaced and coded which allows
    for easy on-the-fly adjustments. The grouped and coded
    system allows the user to see the settings quickly and
    make necessary adjustments easily, allowing the welder
    to more efficient in the workspace and a fine shaped arc!
    Powerful, Reliable, Efficient IGBT Technology
    Longevity offers cutting-edge technology in the
    PROMTSŪ 200i by including IGBT semiconductors inside
    this unit. IGBT technology makes this unit more reliable
    than other comparable units using old-fashioned
    technology. By using IGBT components, LONGEVITY is
    able to offer a potent welder that is lighter and more
    space-efficient than its outdated counterparts.
    Digital Amp and Volt Meter
    By using digital meters, LONGEVITY gives the operator
    instantaneous outputs which are easily read while welding.
    This allows the user to dial-in their favorite settings
    accurately, again, and again!
    Larger Wire Spool Capacity
    LONGEVITY understands the importance of time and
    money. With this PROMPSŪ 200i, you are able to use 11lb spools for longer welding times without having to
    change the spool. This also saves you money as you are
    able to buy larger spools at greater discounts. Do not
    need to use that much wire? No worries. You are able to
    use small 1lb rolls of wire without additional equipment!
    Burn Back Control
    LONGEVITY uses Burn Back Control to prevent excess
    amounts of wire from sticking out by providing extra arc
    time without feeding. This allows the user to make
    excellent re-starts as smooth and painless as possible.
    Stick With Adjustable Arc Force
    With Arc Force, you are able to adjust the inductance of
    the arc for either a crisp arc or soft arc with a fluid puddle.
    This will allow for greater control of your welding
    parameters.
    LONGEVITY
    Phone: 877-566-4462
    Jun 2007
    Re: Welding Turn Table Part 7
    progress? keep us in the loop!
    Nothing Ever Got Done By Quitting, Never Give Up.
    Delaware
    I guess Rob went on a long vacation or ran out of parts
    Delaware
    Well I guess Rob gave up on building a turn table
    Jan 2008
    Hayward, CA
    " frameborder="0" allowfullscreen>
    LONGEVITY
    Phone: 877-566-4462
Page generated in 1,713,275,148.89322 seconds with 18 queries
