Results 1 to 23 of 23
Thread: Thermal arc porta feed 17a feeder
Hybrid View
    Apr 2008
    NW ON Canada
    I'm looking at purchasing an older suitcase wire feeder. The thermal arc porta feed 17a. In my research I find the manual saying it will run on any cv or cc/cv power supply. I can't find anything that tells me it's a voltage sensing feeder that will run specifically on a cc power supply. Anyone have any experience with this unit running on a cc only power supply?
    The manual for the thermal arc hefty 2 suitcase feeder does specifically state it will run on a cc power supply, powered across the arc and voltage sensing. But I just can't find this info for the porta feed 17a suitcase feeder. The owner says it will run on a cc power source but I want to confirm this myself before making the purchase. Thanks.
    Jason
    Thermal Dynamics Cutmaster 52
    Miller Bobcat 250
    Torchmate CNC table
    Thermal Arc Hefty 2
    Ironworkers Local 720
  2. Likes humberto liked this post
  3. #2
    Jan 2008
    Lansing, MI
    Re: Thermal arc porta feed 17a feeder
    Looks to be it runs off 115 VAC. This one has Hobart branding, but they're likely the same. Can't say if it's an energized contactor or not, but it's not a big deal to hook it up either way. Being its a constant speed feeder (at least it appears to be from here) it will only run off CV power sources. Can't say for sure tho and the manual didn't really get specific about it.
    Here's a discussion about it too. I think Scott (Brand X) owned one, or possibly did at one time, him and Don (DDA52) are discussing it here.
    http://www.hobartwelders.com/weldtal...p/t-18009.html
    Here's a Victor manual on it. Looks to be the same thing.
    http://victortechnologies.com/IM_Upl...430429_402.pdf
    Apr 2008
    NW ON Canada
    Yes. This is what I figured. I have viewed the Victor manual already. It isn't really clear on the questions I have in regards to power supply. I'll have to pass on it seeing as I don't have a cv power supply to run it.
    Jason
    Miller Bobcat 250
    Torchmate CNC table
    Thermal Arc Hefty 2
    Jan 2005
    I had two.. hooked one up to my Shopmate for a bit.. The manual says CV and CV-CC power source in so many words. What it is really is telling you is it's for a CV power source only.. Great little two roll feeders anyway.. Had one also hooked up to a Esab 350 MPI, and Thermal-arc MST-400 all are CV-CC power supplies.. (ran on CV)
    I was able to buy two at different times. Both new from Ebay, and about $300 to $400.. What a nice feeder for that price..
    Blue Demon 140 MSI
    Blue Demon 200 AC/DC
    Esab 160i caddy
    Esab CV353
    INE 1500
    Lincoln 250 Idealarc
    Thermal LM-200
    Thermal 60i- 3phase
    Thermal 15c
    Topshak 40 plasma
    Miller Regency 200/LN-72
    Viking 250 mig/2410 feeder
    Weldcote 140
    Jan 2008
    Lansing, MI
    Sounds like it Scott. I figured by the discussion you had with Don then that you either had one or had familiarity with them.
    I figure it's just a standard Miller type contact closure then? You could run that off of just about anything, even a hack wired wall outlet setup if need be. I've seen a few older 10E-30A Miller feeders run off Bobcats like that. Connect the drive to the weld current, then just pick up power for the motor off any 115 outlet. In my experience, if it is a constant speed only drive, it will have to run off CV. Still, there's a wide range of machinery that will run that unit by the sounds of it.
    Snoeproe..... what is the price on it? It may be worth picking up if it's cheap. You can modify the connector cord to support a variety of different CV machines. It wouldn't be hard and if were only talking a couple few hundred bux, that's a great price for a feeder like that.
    Be a great excuse to buy a CV power source then
    IMHO of course
    Apr 2008
    NW ON Canada
    IMHO of course
    Guy wants $500 for it. I think I'll just keep my eyes open for a voltage sensing feeder.
    Jason
    Miller Bobcat 250
    Torchmate CNC table
    Thermal Arc Hefty 2
  8. #7
    Jan 2005
    Steve, you can wire for 120 volt contacts too.(Yes wired for closing contactor from the factory) Pulled power from the wall on the Shopmate. Esab was a bit different, and I needed help from Dea at JustArc to wire up.. ( had help from here from our tech here, but Dea put it into English for us laymen.. Both were saying the same thing.. Told me some Miller's can wire up the same way.. It was about turning on the 115 volt contactor in the machine.. Interesting to say the least.
    Still have the email...
    Scott,
    Sorry about all of the delay, I am old school when I try to read and draw schematics. For the past few days I have been on the run and using my phone.
    Your diagram may not work. I would recommend the following;
    Change your feeder back to "contact closure" and wire as follows moving the Thermal Arc wires to the ESAB pins;
    Esab Thermal Arc
    A 115 vac hot E and A
    B 115 vac neutral F
    C Contactor B
    D Ground G
    The reason for this is that when Miller and Esab use this three wire system it is easy to get the 115vac neutral in the wrong place and it will drive you nuts trying to figure out why it should work being AC but there is no "polarity" or "difference of potential". Or worse you put 115 on top of a 115 trying to get out!
    Again sorry for the delay, keeping you up and running in a timely manner is important to both of us. I am happy to help and look forward to hearing from you again. I would not think of charging you for this if it helps and you come back later...or spread the word, thanks
    Take care
    Dea
    Blue Demon 140 MSI
    Esab 160i caddy
    Esab CV353
    INE 1500
    Thermal LM-200
    Thermal 60i- 3phase
    Thermal 15c
    Topshak 40 plasma
    Weldcote 140
  9. #8
    Jan 2008
    Lansing, MI
    Pass for sure.
    I'm sure it's worth that to someone, but not to me...
  10. #9
    Dec 2020
    Hello friends I bought 3 cheap thermal arc 17A, I am repairing them of the 3 I have 1 repaired. I can use this feeder with a miller XMT304 CC / CV welder. The connector has 5 cables. the 3 current and ground and 2 more. How should I connect it to that machine? Greetings from Venezuela Thanks for the help
  11. #10
    diagrams do not appear to be available on line any more for the 17A.
    I might have some in hard copy, will have to look when I get time.
    If you have figured out the function of each wire in the control cable I can help you connect to the XMT unless it is a new one.
    I am pretty sure it needs 115 volts to operate. On other older feeders. of the five wires two should be power, one is ground and the other two are contactor control.
    If Your XMT has two circuit breakers on the back panel then you have 115 volts in the 14 pin feeder plug if only 1 then only 24 volts is available.
    In the XMT owners manual there is a chart showing how each pin is used.
    There is a couple of ways a feeder can be connected to the XMT.
    one way uses an isolated contactor control and the other uses a voltage return.
    You should be able to download owners manuals from millerswelds.com.
    look at the s-52 feeder for a 117 volt feeder. s-22 for a 24 volt feeder.
    Both use a hot return. you can get 115 volts from pins I and K.
    you can use A to B for isolated (dry) contactor control.
  12. #11
    Found a copy of the owner's manual.
    send me your e-mail by private message and I will send it to you.
    these units do operate on 115 volts. pins e and F . pin G is ground.
    A and B is contactor control no power, just relay contact closure.
  13. #12
    Milwaukee, WI
    ccawgc,
    I took some pictures of my ThermalArc Fabricator and 17A feeder that I PM'ed you about (to see if you might have manuals). The welder if a Fabricator with analog dials and I haven't seen any other pictures of one like mine. I've messed around with it, and I think that it will weld, but I haven't actually tried it. Problems that I've had (and think that I've fixed) were a missing 7-1/4A fuse on the welder front panel (replaced w/10A button breaker), stuck contactor in the machine (freed up) and a bad selector switch on the feeder (3-position switch - bypassed).
Page generated in 1,713,301,046.45117 seconds with 20 queries
