Page 2 of 9 FirstFirst 1234 ... LastLast
Results 26 to 50 of 202
Thread: I became caretaker of Caterpillar D315 Lincoln 300x2 Twin Arc welding machine today
    Visalia, CA
    Re: I became caretaker of Caterpillar D315 Lincoln 300x2 Twin Arc welding machine tod
    it looks like the "missing brush" is on the exciter. . . .which was apparently made in spanish cause i dont understand it. . . . . . .
    ive jumped a few times scrolling down and seeing it that way, but it was apparently run for a while like that so im guessing its factory. . . . . kind of weird
    bosses stuff:
    trailblazer 325
    maxstar 200
    my stuff:
    sa 200
    fronius transpocket 180
    100 amp Lincoln w/f
    97 f350 DIT
    Kevin
    Jul 2014
    Bulldog Heaven at the end of my chain
    If you consider cleaning up the commutator with sandpaper do not use emery cloth!! The abrasive is conductive and will wreak havoc with the machine electrically if used and not cleaned out thoroughly. When I mean thorough, I don't think you could clean it up sufficiently and it remain together.
    Best purchase a commutator stone to dress this item.
    Slob
    Purveyor of intimate unparalleled knowledge of nothing about everything.
    Oh yeah, also an unabashed internet "Troll" too.....
    Visalia, CA
    bwparts.com
    stumpfweldingsupplies.com
    billswelderrepair.com
    weldmart.com
    all good sources of information and helpful people in my experience. i hope i didnt leave any out
    bosses stuff:
    trailblazer 325
    maxstar 200
    my stuff:
    sa 200
    100 amp Lincoln w/f
    97 f350 DIT
    Kevin
    Aug 2015
    nw indiana, usa
    4th pic is left side of exciter, 8th pic is right side of exciter.
  5. #30
    Aug 2015
    nw indiana, usa
    I hope 1 day to make the welder run and look like this project i just finished, i'm nuts 4 old Caterpillars.
  6. #31
    Aug 2015
    nw indiana, usa
    Quote Originally Posted by 92dlxman View Post
    Its 60 years old and 4 sure messed with, i wouldn't take anything as factory. thanks every1
  7. #32
    Feb 2009
    Central Illinois
    There is a like machine on ebay now. This one is set up for dual operators. I don't think this one is as old as your machine.
    http://www.ebay.com/itm/221837013504...%3AMEBIDX%3AIT
    Dan D
    Manipulator Of Metal
  8. #33
    Mar 2015
    Did you get this machine to weld I was just curious ?
  9. #34
    Aug 2015
    nw indiana, usa
    not yet, picking up new axles 4 it this week, got 2 make it mobile b4 going further
  10. #35
    Aug 2015
    nw indiana, usa
    the ebay machine above has been purchased by a caterpillar collector and heading to Minnesota, its a 1963 model using a cat d311-h engine.
    Name:  D311 Twin Arc Welder 001.jpg
  11. #36
    Aug 2015
    nw indiana, usa
    brochure pages of my Cat d315 twin arc welding machine.
  12. #37
    Aug 2015
    nw indiana, usa
    Today i recoupled the welder to engine, removed brushes, cleaned commutators, reinstalled brushes. I noted the chips and grooves the brushes showed b4 installing. They maybe original to the machine. I covered 6 bare wires in control boxes and 1 on the exciter temporary with tape. Machine #1 would strike arc but not able to continue a bead, but more than just sparkle. [kinda hard 2 explain]. Machine #2 seemed to weld ok but not super with the 1/8" rod i had. 1 brush tension spring mount tang broke while messing with the exciter brushes and didn't hold correct tension. Am i correct assuming both machines work off 1 set of exciter brushes, and can i move the exciter brushes to the other mounts? thanks 4 looking & help.
Size:  49.9 KBName:  SAM_0010.jpg
Size:  42.7 KBName:  SAM_0011.jpg
Size:  57.9 KBName:  SAM_0012.jpg
    the gobs in the center r from machine 1, the beads left and right of center r from machine 2.
    The welding machine commutators kinda glazed up after a hour of running????
  13. #38
    Aug 2015
    nw indiana, usa
    Thought i'd share some info from Lincoln about this 2 operator welding machine, mentions my code number at bottom of page.
    wiring diagram 4 my machine.
  14. #39
    Mar 2009
    That's pretty neat.
  15. #40
    Nov 2014
    Buffalo NY area
    I saw your build on smokstak - cool! This place is the Lincoln experts.... judging by the weld and the appearance of the machine I wonder if the exciter is doing its thing, and is all the juice reaching the main generator?
    Use a bigger hammer.
  16. #41
    Aug 2015
    nw indiana, usa
    Quote Originally Posted by nickel_city_fab View Post
    I have a local help who is proficient with motors and generators. We are going to repair and rewire everything we can reach. Every connection is rusted/corroded bad.
    I been reading alot about the Lincoln builds here, especially the shortys, i guess i'm working on a extra longy being the hood is just under 10'.
    Its in disassembly now.
  17. Likes John Baptist liked this post
  18. #42
    Nov 2014
    Buffalo NY area
    Quote Originally Posted by wrenchguy View Post
    We don't see too many of those around here, yours might be the first one that I know of anyways.. congrats! Somewhat rare beast you have there as far as I know. Hope you document it as much as possible, somebody else might need the info someday.
  19. #43
    Aug 2015
    nw indiana, usa
    more taking it apart.
    gallon can of thinner for size comparison.
    reactor for machine #2 that wouldn't make a bead, it has disconnected/broke electrode strap at the connection at the bottom outa sight.
  20. #44
    Aug 2015
    nw indiana, usa
    more taking apart which i'm good at.
    at point of pencil cardboard broken away with windings showing.
    skid turned into trailer.
  21. Likes John Baptist liked this post
  22. #45
    Oct 2011
    Elkhorn, WI
    Nice Job so far Mike! Keep at it even if the weather turns foul! Jeff
  23. #46
    Aug 2015
    nw indiana, usa
    Quote Originally Posted by drujinin View Post
    yep, getting the bigger stuff done outside that i can't get in the shop because of other projects, thanks
  24. #47
    Moose Lake, MN
    Looking good Mike. Man you have really got into yours. I got mine setting in the shop also. Will have to start a post with some pictures one of these day. Just been real busy with to many other projects. I hope I dont need have to go as deep as yours. Mine welded great when I played with it one day but need paint and some cosmetic work along wih new axles.
  25. #48
    Aug 2015
    nw indiana, usa
    can someone provide the test values of the fdr 125 b exciter coils used on my sae 300 welder ?
  26. #49
    Aug 2015
    nw indiana, usa
    In conversation with a old school welder repair guy about this exciter and missing brushes he said "it is a optional oversize exciter but the second set of brushes weren't installed but could be if needed for another 15 amps." he said "most likely for a early style wire feeder or other accessory. "
  27. #50
    Aug 2015
    nw indiana, usa
    pounding out dents, taking most parts to bare metal removing loose and feathering the mill scale, priming and finish paint. 1 bite at a time.
    bare metal fuel tank in back ready for primer
Page generated in 1,632,482,137.29572 seconds with 13 queries
